Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-12-2022, 09:14 PM   #15
TommyW
TommyW's Avatar
Drives: '13 Whiteout
lol,I go half 91 and half 100 at the track and all is well.
TommyW is offline   Reply With Quote
Old 12-13-2022, 12:20 AM   #16
norcalpb
norcalpb's Avatar
I’m gonna try this at my next track day, never thought of it.
Do you put a 93 octane tune on (if tuned) to try and eek out a couple hp?
Old 12-13-2022, 10:22 AM   #17
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
After it learns to pull enough timing, it runs just fine. A little sleepy, but fine.
Thanks. It would be interesting if anyone had done back to back tests, perhaps on a dyne, to see "what was left on the table".
I am pretty sure we can cope with the "loss"; although it would have been great if the car would run well enough, on say, 89 octane which is readily available here. My wife will not be "tracking" the car, it will be a daily driver plus taken on trips where, yeah, we might enjoy picking up the pace on country roads, and it will also be our tow vehicle but I presume the car can cope with that regardless of fuel used.
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Old 12-13-2022, 11:08 AM   #18
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
There has been tests done with 91 vs 93 on gen 1 and there was a whp10hp difference or so. Buried somewhere in the forums.
I wouldn't suggest less than 91.. these engines can get knocky on 91 as it is, less than that the engine won't be happy under heavier loads.
Old 12-13-2022, 11:10 AM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it is not optimized for the octane you are not really going to gain anything at octane levels above that, and could potentially yeild worse performance, but not likely at 12.5:1 compression.
Since you can't pump your own gas here in Oregon I have had many attendants put 87 in my car. It runs terribly, IAM drops to about .4, so only 40% of requested ignition advance.
Ultramaroon (12-13-2022)
Old 12-13-2022, 12:04 PM   #20
TommyW
TommyW's Avatar
no. I don’t have a 93 tune but thinking of adding a 95. The car runs really nice with the 91/100 combo. 91 can actually be less so everyone should throw a bit of 100 in
Old 12-13-2022, 12:30 PM   #21
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks for sparing me the trouble of a Search.
OK, just enough difference to cause angst when refilling. % loss on HP versus % savings per gallon?
Old 12-14-2022, 02:46 PM   #22
greengs
Drives: 2022 BRZ, 2022 Tacoma Pro
It is the compromise needed to run a high compression NA engine I am afraid.
Mazda3 NA has a higher compression ratio than the BRZ/GR, those only need 87.
greengs is offline   Reply With Quote
Old 12-14-2022, 02:56 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pure GDI I am assuming. You can also do things to bleed cylinder pressure like mess with cam timing.
There is also the matter of "can" instead of "should." As I said, I have had 87 put in my car, the ECU does a good job of pulling timing fairly quickly.
Old 12-20-2022, 03:23 PM   #24
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Most rich communities in California have stations like this. Here is the pump at the 76 in Saratoga California.
Doesn't even have to be a rich community. We have one in Stockton lol
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Tcoat (12-20-2022), x808drifter (12-22-2022)
Old 12-20-2022, 04:24 PM   #25
OkieSnuffBox
Drives: '23 BRZ Limited
I'd like to see that because I SERIOUSLY doubt it.
When I had my '13 Mustang GT, it was advertised as 420hp. But in the manual it said 420hp on 93, 414hp on 91.
That's basically statistical noise at that point.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
NoHaveMSG (12-20-2022), x808drifter (12-22-2022)
Old 12-20-2022, 04:29 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, tuned for 91 vs. tuned for 93, not going to be 10whp.
Now tuned for 93, but running 91 may cause some issues.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (12-20-2022), x808drifter (12-22-2022)
Old 12-20-2022, 05:55 PM   #27
RToyo86
RToyo86's Avatar
Did a little digging. Link is now dead which doesn't help much for source. 91 vs 93/94 was 6whp, and 10whp on 87 which makes more sense.
https://www.ft86club.com/forums/show...5&postcount=25
Old 12-20-2022, 07:25 PM   #28
OkieSnuffBox
Québécois are too busy eating smoked meats to know what's going on.
mixing e85 (109 octane) with e15 (91 octane) pcguru2000 Engine, Exhaust, Transmission 19 03-08-2022 11:35 PM
91 vs 94 Octane nocwage Engine, Exhaust, Transmission 27 07-15-2014 01:52 AM
93 Octane vs 91 Octane keithgold Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 01-16-2014 11:16 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
93 Octane Smokinbuffalo Northwest 20 09-02-2012 06:24 PM
