#4733 | |
Drives: 2020 Subaru BRZ (Edelbrock SC)
[video showing location](https://imgur.com/a/HITUims) The oem hose is a smaller diameter than the supplied radium hose which I suspect is why it is occurring. I am fairly certain I followed directions carefully because the smaller diameter hose supplied was used on the top port of the can but the straight port uses the larger diameter hose which connects to where I am getting the leak. What did you guys do to resolve this? Maybe I need to go out and buy an adapter? |
#4734 | |
Drives: BRZ ts
#4735 |
Yes, I was able to connect the lines with the blower installed. It wasn't easy, but it can be finessed.
CSG Mike recommended I try a step down barbed fitting from 1/2 in to 3/8 using the OEM and Radium hoses to fix the leak. I am going to try that tomorrow and hopefully resolve the problem. |
| The Following User Says Thank You to GPhilly For This Useful Post: | dpfarr (12-11-2022) |
#4736 |
Drives: 86 (FR-S)
Well I’m definitely in need of a stronger clutch. It is not holding the power at wot on a tank of E85 whatsoever. I have a competition stage 4, 6 puck on my Acura. Is that a good option for this platform? What’s the most streetable that will hold 350 whp these days?
#4737 | |
Drives: 86 (FR-S)
#4738 |
Drives: BRZ ts
It is my understanding that only the pcv catch is necessary? The other side is normally empty?
#4739 | |
"It is necessary to clean it again (MAF) because it is being continually *fouled*, over and over and over. If not by the filter which you seem to have ruled out, then by the high flow CCV (Crank Case Vent) that plugs into the back port of the Edelbrock airbox. At anything more than atmospheric pressure, that is pushing spent crankcase gasses at pretty high velocity straight from the crankcase to the airbox, and that all has to flow past the MAF in order for the engine to burn it off again in the next combustion cycle. This is good for emissions, but shit for drivability, particularly when your engine load calculation is MAF based as it is on the 86/BRZ. It is for this reason that cleaning the MAF continually normalizes your car until you've driven long enough for it to work itself into unhappiness again. It takes time for that blowby to re-foul the MAF. I've been putting a lot more effort into a bit of a case study in the last month or two, and it's appearing to me that boosted FA20 tend to have pretty damn high blowby from that CCV vent. All boosted FA20 running MAF based tuning can thus strongly benefit from a CCV based catch can like Radium's, ideally vented to atmosphere rather than recirculating: https://www.counterspacegarage.com/r...-frs-toyota-86 It is definitely a case by case basis for blow by on these cars, but there is no doubt that boost increases the flow output on that port substantially. In the past I recommended catch cans only to cars visibly exhibiting blow by, but now we can pretty much directly correlate it to the continual MAF fouling on what Edelbrock claim is a dry and not oiled filter." With that out of the way, installing the catch cans taught me an important skill for listening for air leaks. It seems when the car switches from DI to PI, the air leak whistle becomes louder and correlates with the short term fuel trim fluctuating. I have most likely had an airleak this entire time causing my car to run like shit. I'm about 90% sure. Going to do a smoke test next to see where it maybe... Last edited by GPhilly; 12-12-2022 at 03:36 PM. Reason: Important information |
| The Following User Says Thank You to GPhilly For This Useful Post: | SOCON (01-05-2025) |
#4740 | |
Nice: CSG Spec OS Giken single disc (includes fork and throwout bearing upgrade) |
#4741 | |
Drives: 2015 FR-S
Curious are you on a stock block with E85+EBSC?
#4742 |
Drives: 86 (FR-S)
Thank you for the help! Does either option utilize the stock flywheel? I've always understood that lighter weight flywheels are not advantageous for boost, but that may be my thinking coming from the turbo world.
#4743 |
Drives: 86 (FR-S)
For now, yes. I completely built the k20a2 in my other car and had it in a million pieces on tables in my garage for several months while a shop did my bottom end work. I'm not in a huge hurry to do it again lol. If I pop the motor, well that will change things. I do understand boost is controlled with your foot, however, so I'm trying to be gentle... mostly. I'm flexfuel as well so I can drop to pump gas if I'm feeling nervous.
| The Following User Says Thank You to Jeff86 For This Useful Post: | FrickingReallySlow (12-12-2022) |
#4745 |
Drives: 86 (FR-S)
I'm a little afraid that high rpms could slip on a 270 tq clutch (ACT HDSS). The OS Giken seems a better choice at 300. I'm also interested in the ACT XTSS. It seems quite up to the task if it isn't a pain to drive. What are your thoughts on that option?
#4746 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I have the ACT HDSS on my 450 hp setup and haven't had any issues. It has slipped when I've let other people drive, but they just aren't used to engagement window. I've had both a used unit and brand new unit with the 12 lb flywheel. Just don't use that moneyshift racing hydraulic throwout with it, that tore up my pressure plate (still using it though).
| The Following User Says Thank You to B T For This Useful Post: | Jeff86 (12-14-2022) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
