Old 05-07-2021, 02:13 PM   #71
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Whoa. That's a lotta covers. What are they all supposed to do, just cleaner aero under the car?
Cephas is offline   Reply With Quote
Old 05-07-2021, 03:09 PM   #72
churchx
churchx's Avatar
Drives: 2014 GT86
cleaner aero/increased downforce/reduced lift without cost of increased drag. Drawbacks .. i guess, slight weight increase, slight cooling decrease for tranny/diff. Overall imho worth doing. Not much ways out there with increasing dowforce w/o paying drag penalty.
The Following 3 Users Say Thank You to churchx For This Useful Post:
Cephas (05-09-2021), DylanJZA (07-26-2022), therealstoly (05-07-2021)
Old 12-09-2022, 01:22 AM   #73
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
A final thought or two as I sold my BRZ yesterday. I put about 14K miles on the car with all the bracing and none of the bracing gave me any problems. Nothing had to come out, be replaced, squeaked, rattled, bent, begat some sort of other issue, etc.
My step dad was both a professional Trans-Am race car driver/team owner and a chassis designer so I don't know anything other than... start with the stiffest chassis you can get to eliminate that from all the equations and then proceed to throw copious amounts of money at suspension and cooling. Tires and pads are throwaways and true to my upbringing, I burned through a set of Kumho V730s every oil change. Without regret.
The thing is... it's your car. I can remember taking Bear Creek Road the day after I bought my BRZ and every time it complained, I complained right along with it. Tires were shit, the lean was ungodly, brake dip was like bowing to the Royal Family, and the brake pedal hated me as much as I hated it 10 minutes into it. Steering was weird and I was certain the rear side glass was gonna be the first to go from all the flex the suspension seemed to really enjoy.
Reality was at least six degrees of separation from my first impression. It just didn't behave the way I was raised to expect a car to behave when pushed to do as advertised. There are so many variables and even though I mentioned it, it gets missed every single time. Predictability.
Bracing absolutely comes with Placebo. But it also comes with confidence. And somewhere in there you end up whittling down the variables to a much more manageable number. For you. Your own personal confidence number. So. You can be an internet **** from the PNW, as an example, or... OR. As a counterpoint, you could just keep your fucking mouth shut and not opine on things you know nothing about in first person.
It's your car. grumpy people from down under be damned... if bracing, bushings, or aerodynamic wipers give you more confidence and make you smile, pick that route. I had the most fun doing 14K miles knowing that I'd started with a whole bunch of variables and by the time I was done, I was down to the same two I grew up on. I have just enough ego to know that if I'm being airlifted out on the embankment side of a guardrail, it was either the pads or the tires.
It's your car. Do what you want.
therealstoly is offline   Reply With Quote
The Following User Says Thank You to therealstoly For This Useful Post:
NLSP (12-09-2022)
Old 12-09-2022, 10:30 AM   #74
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You know you can tag me too right?
Congratulations for missing the two simple points I always bring up when people talk about bracing.
A) People overstate the effects. As you said, there is a fair amount of placebo with bracing.
B) If you really want the performance gain start with bushings. Of course they are more work to install and people you are trying to impress can't see you have all those fancy braces.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (12-09-2022), villainous_frx (12-10-2022), x808drifter (12-17-2022)
Old 12-09-2022, 12:12 PM   #75
I'm an expert because my daddy was a racecar driver.
NoHaveMSG (12-10-2022), villainous_frx (12-10-2022), x808drifter (12-17-2022)
Old 12-09-2022, 04:04 PM   #76
norcalpb
norcalpb's Avatar
Idk if anyone has seen this, but this company Soul Function is selling braces at pretty dang discounted prices if anyone wanted to try them out:
https://www.soulfunction.com/collections/brz-frs-zn6
Old 12-09-2022, 06:16 PM   #77
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I literally LOL'd when I read that!
Whether I agree or disagree with your opinions when I've read them everywhere across this forum (and I've done both), I love that you own it, 100%.
Tatsu333 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post:
NoHaveMSG (12-09-2022), x808drifter (12-17-2022)
Old 12-09-2022, 09:23 PM   #78
glhs386
Drives: 2014 FR-S Monogram
I just installed the 4 point lateral brace on Wednesday. I'm not going to claim any noticeable performance benefits, but the quality was pretty nice for $70 shipped and being aluminum it weighs almost nothing. I had to notch some splash shields slightly with a razor blade for clearance, but no big deal.
If I didn't already have a Carbing front subframe brace installed I would have also jumped on the SoulFunction version for $80. Of the braces I've installed that one was the most immediately obvious from behind the wheel, and it's probably the one I'd recommend most to people who are skeptical of braces in general. I believe the GR86 now comes with similar front subframe braces as part of the chassis rigidity upgrades, so that should tell you something.
glhs386 is offline   Reply With Quote
The Following 2 Users Say Thank You to glhs386 For This Useful Post:
NoHaveMSG (12-09-2022), norcalpb (12-09-2022)
Old 12-09-2022, 09:58 PM   #79
norcalpb
norcalpb's Avatar
Yes the front crossmember brace can be pretty intense. I actually sold mine because it made things a little too stiff for the street driving I was doing at the time.
Do you have a source on the GR86 coming with additional front bracing, that could be potentially swapped over to the first gen?
Old 12-09-2022, 10:03 PM   #80
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol
Old 12-09-2022, 10:08 PM   #81
glhs386
I found this image, the braces don't span entirely between the frame rails but it looks like they triangulate the subframe to the unibody. Should serve the same basic function, but I have no idea if they're backwards compatible. Probably not.
Source: https://autos.chinatimes.com/20211104002950-264301
norcalpb (12-09-2022), SuperTom (04-23-2025)
Old 12-10-2022, 12:13 AM   #82
norcalpb
norcalpb's Avatar
I found this image, the braces don't span entirely between the frame rails but it looks like they triangulate the subframe to the unibody. Should serve the basic same function, but I have no idea if they're backwards compatible. Probably not.
Oh that is awesome!
I was able to find a diagram showing them. At $16/side I may just give them a try assuming those 4 front holes are there.
Subaru part #'s (couldn't find anything on Toyota's website)
50525CC000
50525CC010
The Following User Says Thank You to norcalpb For This Useful Post:
glhs386 (12-10-2022)
Old 12-10-2022, 08:20 AM   #83
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Oh that is awesome!
50525CC000
50525CC010
There's always rivnuts if they aren't. Assuming the other holes line up nice.
Old 12-10-2022, 10:45 AM   #84
gpvecchi
gpvecchi's Avatar
You need the 50515A and B parts, too. They have the holes that are not present in old cars.
TB Performance Bracing Review Zach3794 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-11-2013 10:23 PM
Cusco: Toyota 86 / Subaru BRZ Suspension & Bracing !! Speed Element Brakes, Suspension, Chassis 42 06-14-2013 03:20 PM
CUSCO Chassis Bracing & Suspension IN STOCK Free Shipping LOWEST PRICES on FT86Club!! CygnusPerformance.com Brakes, Suspension, Chassis 27 05-16-2013 08:06 AM
Cusco And Beatrush - The All Japan Strut Bracing Thread! RallySport Direct Brakes, Suspension, Chassis 1 02-12-2013 06:47 PM
TB Performance Chasis Bracing Review xclusive_brett Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-05-2013 11:46 AM
