Old 09-23-2021, 01:58 PM   #43
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Sounds dumb, but have you checked tire pressure? With the cold weather, tires are flatter; more rolling resistance to get going. If you’re used to a certain throttle to roll and your tires are low, you will stutter.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
sato (12-04-2022), Ultramaroon (09-23-2021)
Old 09-23-2021, 02:57 PM   #44
Lantanafrs2
Drives: 2013 frs red
Does it shudder with the traction control off?
Lantanafrs2 is offline   Reply With Quote
Old 09-25-2021, 02:39 AM   #45
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Originally Posted by eman11500 View Post
Hard slip the clutch at a higher RPM and then re-engage as soon as it drops and hold it for a while? Or should I just hard slip and give it some oomph a couple times?
I slipped my new clutch at above street speeds in those acceleration zones. It helped quite a bit, but it still happened once in a while. But I pretty much doubled the clamping power with my new clutch changing engagement torque beyond the system's design.
My issue came on with a new clutch as well, before my supercharger. What's happening is the bushings aren't tuned for higher sudden torque input, so they over deflect and wind up enough to kick back their energy. Stiffer bushings deflect less and don't kick back as hard. But you gain NVH as they transfer that stiffness into body more. Especially motor mounts
Great feeling to have them stiffer though, the hysteresis on and off power is twitchy again. Came with the most NVH for the dollar, but I do like how it drives quite a bit better now too.
jeepmor is offline   Reply With Quote
Old 03-02-2022, 12:39 AM   #46
jeepmor
So should I , or should I not do the insert? I'm somewhat confused
I missed you were all stock in replacement, did you figure out your problem yet? To go from stock to mods and have issues is one thing, but stock to stock, you shouldn't have any change. I'm with Ultramaroon on that one. Catching up on most the reading, it does sound like the flywheel might be burned up a bit. Sounds like it may not have been changed. Thrashing would help seat in with the new disc better and maybe just wear its own groove in and be fine. My settled a bit after the thrashing as well.
On my rig, it's been a while now, but I can still induce the shudder. It's parking lot speeds where I have to feather the clutch a lot, the rear still starts shuddering. On my clutch job, I put in a new subi flywheel. My old one looked a little worn, but wasn't awful. My TOB failed, not my clutch. And I had a SC coming, so I bumped up the clutch strength to stage two and all new parts. Clutch is overkill at 350 ft-lbs, but feels the same weight as the stock clutch foot work wise. But it snaps closed much harder than the stock one, which is where I honestly think my issue came from.
After my experience with mods, and reading your same experience with stock components. I think you need(ed) more wear in time to reset the sliding patch of the new parts. I see the thrashing and slipping the clutch accelerate the burn in process. Especially if a used flywheel already worn into to another clutch pack. Those are smooth compared to new parts and will take a little longer to seat in.
Old 12-04-2022, 09:17 PM   #47
jeepmor
My issue ended up being a Verus fork having sloppy tolerances. Took me 30k miles, but I had it opened back up by a performance shop and they shared that they have seen it several times with Verus forks.
The Following User Says Thank You to jeepmor For This Useful Post:
soundman98 (12-04-2022)
Old 12-04-2022, 09:46 PM   #48
That's a damn shame but it makes sense. Stock fork design isn't stellar but I've always argued that it's strong enough.
Old 12-04-2022, 10:32 PM   #49
sato
sato's Avatar
Drives: Dodge Patitas
What problems could the "sloppy" tolerances cause? Just asking.
sato is offline   Reply With Quote
The Following 2 Users Say Thank You to sato For This Useful Post:
Jdmjunkie (12-05-2022), soundman98 (12-04-2022)
Old 12-06-2022, 10:46 AM   #50
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Make that 3rd now...
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
Dzmitry (12-06-2022), Jdmjunkie (12-06-2022), Spuds (12-06-2022)
Old 12-06-2022, 01:13 PM   #51
I feel dumb for walking right into it all. Forum-ers, please forgive me.
Old 12-06-2022, 07:00 PM   #52
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Sounds like that "performance" shop has a habit of installing clutches wrong, considering nobody else has had any issues.
Also: "Build Thread"
Old 12-07-2022, 12:45 PM   #53
StraightOuttaCanadaEh
Wes
My car was doing this recently and I installed the front and rear diff bushing inserts and it's doing it a lot less now. It was almost like it was struggling for traction, very strange. Installing bushings or stiff mounts at one end and not the other exacerbates this problem
Instagram: @gt86ws
Old 12-07-2022, 06:24 PM   #54
jeepmor
Sounds like someone doesn't know how these clutches go together, there is no adjustment. The performance shop fixed it, not the installation shop. The performance shop stated they did not find anything incorrect about the installation, just the Verus fork. To which they added they had seen this be a problem with this component before. They claim high wear, but mine was an issue from day one of Verus fork installation.
Old 12-07-2022, 08:54 PM   #55
Spuds
The Dictater
Spuds's Avatar
You can adjust the pedal and thus throw out bearing travel pretty easily though.
Jdmjunkie (12-07-2022), x808drifter (12-17-2022)
Old 12-07-2022, 09:09 PM   #56
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Which shop? What has Verus had to say? PRE, AR?
shuttering, transmission
Car shuttering when starting it up FRSNewb Issues | Warranty | Recalls / TSB 4 11-10-2020 09:43 AM
QQQQBall's "RE"Build FR-S Thread (PIC HEAVY) qqqqball Member's Car Journals 47 08-22-2016 09:30 PM
SWP BRZ ("Stance" to Autox) Pic Heavy BRZach Member's Car Journals 10 02-09-2016 07:35 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
