Old 12-03-2022, 02:11 AM   #4901
Welp, I didn’t make it into 2nd interview. 1 less thing to worry about this month. With that said, my buddy’s work place (in Cali) is looking for event coordinator, so I’ll be sending my resume. Pay is pretty good, so see how it goes.
Well, darn.
Are you unemployed or just looking for a promotion?
ichitaka05 (12-06-2022)
Old 12-03-2022, 02:37 PM   #4902
Hey, @Spuds. Whatcha doin' with your machine? Clutch?
Old 12-03-2022, 03:28 PM   #4903
JD001
JD001's Avatar
Drives: Subaru BRZ
^^^^ Reads like a "special" code as found on "special" dating sites^^^^ Not that I know..but it does.
Old 12-03-2022, 03:38 PM   #4904
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
And i'm agonizing over what rubbers to buy for next year.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
JD001 (12-04-2022), soundman98 (12-04-2022), spike021 (12-04-2022), Spuds (12-03-2022)
Old 12-03-2022, 04:28 PM   #4905
Just sharing some bondage tips
JD001 (12-04-2022), soundman98 (12-04-2022), Spuds (12-03-2022)
Old 12-03-2022, 07:59 PM   #4906
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I'm dropping the trans for the TOB that started acting up with perfect timing. Not intending to do the clutch unless something is messed up. I'm also doing a whole bunch of stuff this winter:
-TOB/TSK1
-Coilovers/camber plates/LCAs/swaybar
-Engine/Transmission/diff mounts and subframe inserts
-Spark plugs
-Header
-diff and trans fluid
-probably some other stuff I forgot?
Also: "Build Thread"
The Following 3 Users Say Thank You to Spuds For This Useful Post:
NoHaveMSG (12-03-2022), soundman98 (12-04-2022), spike021 (12-04-2022)
Old 12-03-2022, 08:00 PM   #4907
Spuds
The Dictater
Spuds's Avatar
NoHaveMSG (12-03-2022), soundman98 (12-04-2022), Ultramaroon (12-03-2022)
Old 12-03-2022, 08:29 PM   #4908
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oil cooler?
Old 12-03-2022, 08:32 PM   #4909
Spuds
The Dictater
Spuds's Avatar
Oil cooler?
I mean I wasn't planning on it as I'm building for autocross... but that's not a bad idea...
Just don't try to convince me to take the rest of the exhaust off because if I do it's probably not going back on.
soundman98 (12-04-2022), spike021 (12-04-2022), Ultramaroon (12-03-2022)
Old 12-03-2022, 08:36 PM   #4910
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just don't try to convince me to take the rest of the exhaust off because of I do it's probably not going back on.
Not super nessicarry for autoX but it will help.
Just don't do anything I wouldn't do
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (12-04-2022), spike021 (12-04-2022), Ultramaroon (12-03-2022)
Old 12-03-2022, 08:43 PM   #4911
-TOB/TSK1
-Spark plugs
-Header
Oh, Duh... I forgot we talked about that quill sleeve kit. Good luck!
Old 12-03-2022, 09:08 PM   #4912
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Kinda makes me want to preemptively modify a stock transmission cover to accept a sleeve that will take a standard TOB.
Old 12-03-2022, 09:30 PM   #4913
I think the real culprit is the aspect ratio of the contact surface. If the cylindrical contact area were deeper, like with an extension taking advantage of the rearward available surface area, it would better resist binding and galling.
Old 12-03-2022, 10:04 PM   #4914
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ahhh. That makes too much sense.
Ultramaroon (12-04-2022)
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
