Old 11-21-2022, 04:38 AM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Differential sadness
Im trying to figure out the best route to handle this. Unfortunately after a long few months of some trans work I finally got my brz on the road for some tuning. Right off the bat i got what appears to be a terribly loud bearing noise. Tore the diff apart and the side bearings are fine but haven’t gotten to the pinion bearing yet. I wanna take this opportunity to get a higher gear ratio since im supercharged also the cd009 transmission gears feel short. Who sells good quality ring & pinions with a 3.58 or 3.73 ratio? Ive contacted weir weeks ago with no response and been hunting for a m85 diff from a is300 with no success.
IsaiahW is offline   Reply With Quote
Old 12-01-2022, 11:36 PM   #2
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Sadly, I have no suggestions for you, but you *might* want to re-post this in the "Engine, Exhaust, Transmission" section rather than the classifieds if you're looking for an answer.
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
RT-BRZ (12-02-2022)
Old 12-02-2022, 10:11 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I've been casually looking for a 3.9 or 3.7 FD too and cant find them. Best of luck
Old 12-02-2022, 11:45 AM   #4
IsaiahW
IsaiahW's Avatar
Its two options purchase a m85(rare manual 3.7) or m98(auto 3.9) is300 used diff but it’s risky because you don’t know what the diff went through. Alternatively hit up weir performance(call him) or nitro gear for gears to rebuild your current diff. Thats the expensive route but you’ll have fresh new bearings, fluid, gears, etc also parts and labor are under warranty. Ebay shipping prices are terrible due to the weight of a used diff so its better to just rebuild instead
Old 12-02-2022, 11:48 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have bought two diffs on ebay and both were free shipping. Price was comparable to local pickup on offerup or FB Marketplace.
Old 12-02-2022, 12:31 PM   #6
IsaiahW
IsaiahW's Avatar
Part of it was me being picky looking for the nicest one with low miles i live in va so most of the diffs were coming from cal.
Old 12-02-2022, 12:31 PM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The M85s I've found on eBay I've been able to get free shipping for. I shipped a diff before and it was only like $120
Old 12-02-2022, 12:38 PM   #8
Breadman
Breadman's Avatar
The last time i found a used one with a lsd i forget which ratio, it was 900$ used. So I will be 100% passing on a more expensive option for the time being. Also did you use a kit for your cd009 swap? It is only a matter of time before i turn my gearbox into spare parts
Old 12-02-2022, 12:54 PM   #9
IsaiahW
IsaiahW's Avatar
I used the mazworx favq kit
Oem differential dreamwonder Transmission and Driveline 10 01-25-2022 08:04 PM
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
ISO Differential andrew5826 Want-To-Buy Requests 0 07-01-2020 02:19 AM
Differential DonZilla Southern California 7 09-01-2016 05:07 PM
Frs Sadness Dragonist Scion FR-S / Toyota 86 GT86 General Forum 9 08-26-2012 02:47 AM
