Old 11-26-2022, 03:04 PM   #1485
funkjaw
Drives: 16' WWB
Are they filling your system too? Mine hasn’t been as cold as I would like, but it works.
I'll ask them too. I have one of those cheap AC pumps at home that I have been using, but I think their equipment might be better at truly evacuating the system.
funkjaw is offline   Reply With Quote
Old 11-26-2022, 03:51 PM   #1486
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Had my first hose leak at the same spot. Second hose leaks a the valve core. I plan to take the first hose that leaked and have it repaired as well. I wonder how many others out there have had issues just haven't posted up about it yet?
Originally Posted by funkjaw View Post
AC update: Some time ago I posted how I found the high side hose leaking so Kpower sent me a new high side hose to replace it. The new hose worked well for about 3 weeks or so but eventually started leaking in the same exact spot as the old one. I got tired of dealing with it so I just left it and would top off the AC as needed. Well today that hose blew apart at one of the crimps:
At this point I'm just gonna take the hose to an AC shop here in Austin and pay to have one made; as I don't trust the quality control of the A/C lines that Kpower makes for this kit.
Will update once I get the 3rd new line in.
captain awesome is offline   Reply With Quote
Old 11-26-2022, 09:27 PM   #1487
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Originally Posted by suvig93 View Post
I did read issues about the sensor grounds in the loom, has more people experienced this? Should this be on my fix list?
Originally Posted by captain awesome View Post
I haven't done the added ground wires but will at some point. I've driven roughly 14k miles on the swap without the fix so it will work just fine without it set up right.
So I’m still really torn on all this and issues with the wiring harness. I read about the ground wires being an issue but what ended up being the solution? Thought I had it bookmarked but I lost the page I think.
With the Haltech on BF discount, do y’all still think the KPower wiring harness is still worth it, or do you guys that have been running swaps for awhile wish you had gone in another direction?
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 11-26-2022, 09:40 PM   #1488
captain awesome
Wears Pants
This is the fix:
Originally Posted by RedReplicant View Post
Success, both oil temp and pressure are working as expected now.
TLDR: Move the oil sensor ground to sensor ground instead of normal ground
I talked to Gerald and he agreed with my grounding idea, so I made a list of grounds at the junction box, as shown left to right:
1. VTC solenoid / oil sensor
2. Crank position sensor / VTEC solenoid
3. Both cam position sensors
4. Ground ring, back of head
5. Coil 2
6. Coil 4
7. Coil 3
8. Coil 1
9. Ground ring, front of head
10. AC1 pin 44
11. AC1 pin 40
12. AC1 pin 37
I decided the cleanest way would be to add a new sensor ground junction box, so I bought:
1x https://www.corsa-technic.com/item.php?item_id=1697
1x https://www.corsa-technic.com/item.php?item_id=1698
10x https://www.corsa-technic.com/item.php?item_id=1104
10x (bought spares / expansion later) https://www.corsa-technic.com/item.php?item_id=698
1x https://www.corsa-technic.com/item.php?item_id=381
1x https://www.corsa-technic.com/item.php?item_id=291
Depinned ground junction box pin 1, cut off the second wire, pinned the VTC solenoid into the existing junction box, pinned the oil sensor into the new junction box (sensor junction box)
Depinned AC1 pin 34, cut one of the wires, pinned it into the new sensor junction box, soldered/heatshrank a new wire from the wire I cut on AC1 to the sensor junction box.
Nice thing is the junction boxes clip together to keep everything tidy. I think a cleaner way would be to crimp a new pin for AC1 instead of splicing, but whatever. I also intend to move the cam sensors and crank sensor to my sensor junction box since Haltech expects them to be sensor grounded.
This is an improperly working sensor graph (green line, bottom graph)
This is what a working sensor graph looks like (green line, bottom graph)
Old 11-26-2022, 09:53 PM   #1489
RedReplicant
Drives: None
If you want to integrate with stock CAN and you're going to be running Haltech (and I think it is worth it for DBW) you're saving something like $1200, but you also get to make your own harness / figure out the pinouts / buy all of your own connectors / etc.
While I have had some qualms with the KPower harness I'd gladly pay the money again if I was starting over. The base map is drivable to a tuner, but I would never consider putting track time on it.
I've clearly been pretty vocal about some of the short comings of the swap, but honestly, it gets a lot right. We've got someone here who has been daily driving a swapped car with relatively few issues for like a year / 14k miles and I've got 7 events on mine without a single issue swap issue (stupid transmission) other than some exhaust bolts rattling loose.
I think it is pretty legit that a Honda FWD motor can be turned 90*, put into a modern Subaru chassis, and work pretty much like stock. It can also probably, with proactive part collection / motor prep, be completed in a weekend if you're sufficiently motivated.
RedReplicant is offline   Reply With Quote
Old 11-26-2022, 10:48 PM   #1490
Kelse92
At the track
Thanks guys!
It's really a matter of a time thing for sure. We're capable around here of building our own wiring harness, but with not much winter down-time around here we could easily eat up 6mos before really getting moving on a project, so plug an play is always a better answer, I just don't want to be majorly frustrated with stuff once its in lol
Old 11-26-2022, 11:16 PM   #1491
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
When you say a cheap pump, do you mean this?
Or do you mean this?
Old 11-27-2022, 04:36 PM   #1492
RedReplicant
Drives: None
Realized I have an event next weekend and I also don't want to deal with pulling this stupid board out again.
Old 11-27-2022, 06:01 PM   #1493
ML
ML's Avatar
Drives: 13 White MT FR-S
well that's one way to do it!
Old 11-27-2022, 06:59 PM   #1494
RedReplicant
Drives: None
Only way to do it without a board revision
Old 11-27-2022, 08:13 PM   #1495
ML
ML's Avatar
Well there is also this way too with a PDM but I have been trying to keep my mouth shut about that.
Old 11-27-2022, 08:54 PM   #1496
RedReplicant
Drives: None
That is definitely the nicer way to do it
Old 11-27-2022, 09:39 PM   #1497
redlined600
redlined600's Avatar
Drives: Fr-s
That's awesome!
Since it was black Friday I finally ordered the electronics package. Getting pretty close to go time!
redlined600 is offline   Reply With Quote
Old 11-28-2022, 03:35 PM   #1498
funkjaw
Drives: 16' WWB
That guy
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
