go_a_way1, MisterSheep
Old 11-11-2022, 09:20 AM   #24011
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by Kaotic Lazagna View Post
Did a quick wipe down of the engine bay since I have to wait for Autozone to diagnose my battery (that I'm sure is bad since it's an AGM type that won't charge past 12.45 volts).
I see insulation on your high pressure A/C lines. Increase cooling? Noise reduction? Birth control?
Old 11-11-2022, 11:31 AM   #24012
Kaotic Lazagna
Drives: GR Corolla
Birth control. The answer is always birth control. lol
It helped get cooler temps in my previous car, so I figured it should also help in the FRS.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
blsfrs (11-12-2022)
Old 11-11-2022, 11:53 AM   #24013
Kaotic Lazagna (11-11-2022), NoHaveMSG (11-14-2022)
Old 11-12-2022, 09:20 PM   #24014
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Reinstalled winter tires. Forgot how fun 16" wheels are.. I might need to switch to a 16" wheel in the summer.
Also gave it a bath, prepped the windshield and coated with aquapel.
The Following 8 Users Say Thank You to RToyo86 For This Useful Post:
Busybee (11-13-2022), DarkPira7e (11-13-2022), Kaotic Lazagna (11-12-2022), new2subaru (11-17-2022), NoHaveMSG (11-14-2022), norcalpb (11-13-2022), soundman98 (11-12-2022), Teseo (11-14-2022)
Old 11-13-2022, 01:03 AM   #24015
Compelica
Compelica's Avatar
Drives: 86 GT
Pulled out the dashboard piece underneath the steering wheel to investigate a rattle. Turns out there is a thermistor, and if it is disconnected the aircon would not get cold, unless it is only set to LO.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following 4 Users Say Thank You to Compelica For This Useful Post:
bcj (11-13-2022), Busybee (11-13-2022), RToyo86 (11-13-2022), soundman98 (11-13-2022)
Old 11-13-2022, 11:45 AM   #24016
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
God damn I love a nice 5 spoke. Your car looks incredible
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
RToyo86 (11-13-2022), soundman98 (11-14-2022)
Old 11-14-2022, 10:49 AM   #24017
StraightOuttaCanadaEh
Wes
Installed the two whiteline diff bushing inserts. My combo is now perrin engine mounts at the front, sti trans mount in the middle, and those two at the back. I used to have a perrin trans mount as well and I have to say I miss it. I don't miss the noise but I miss the feel. The sti trans mount is just not the same, still too mushy
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
orz (11-15-2022), RToyo86 (11-14-2022)
Old 11-15-2022, 07:21 PM   #24018
DarkPira7e
DarkPira7e's Avatar
Snow is coming tonight, may be one of the last times I could drive it so I gave the suspension pieces a final snugging up, wiped fingerprints off the hood and got a friend to record a little rip. The tires are 100tw so they have absolutely no chance of hooking when it's 30 degrees out in 2nd gear haha.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
RToyo86 (11-15-2022), soundman98 (11-16-2022), villainous_frx (11-16-2022)
Old 11-15-2022, 08:55 PM   #24019
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Bled the clutch. Drove it. Scraped the shit out of the splitter because I forgot how low it is.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 5 Users Say Thank You to Dave-ROR For This Useful Post:
DarkPira7e (11-15-2022), humfrz (12-04-2022), RToyo86 (11-16-2022), soundman98 (11-16-2022), Tcoat (11-15-2022)
Old 11-15-2022, 11:00 PM   #24020
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Seems like original TOB is starting to go at 100,000 miles. Clutch is starting to make a hissing sound, previously discussed here:
https://www.ft86club.com/forums/showthread.php?t=113891
The Following User Says Thank You to NLSP For This Useful Post:
MJones_RB (11-16-2022)
Old 11-16-2022, 04:20 AM   #24021
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Swapped in my race brake pads.
autoracer86 is offline   Reply With Quote
Old 11-16-2022, 08:10 AM   #24022
WNDSRFR
Drives: FR-S,GTI
100,000 miles on an FR-S TOB?
Congratulations, I think that's a record.
The Following 8 Users Say Thank You to WNDSRFR For This Useful Post:
DarkPira7e (11-16-2022), humfrz (12-04-2022), KMA KiCKz (11-16-2022), MJones_RB (11-16-2022), NLSP (11-16-2022), norcalpb (11-16-2022), soundman98 (11-16-2022), Ultramaroon (11-18-2022)
Old 11-26-2022, 10:02 PM   #24023
orz
orz's Avatar
Drives: Halo
OFT Mount
Got a 90deg obd2 extension cable to route the oft towards the passenger side. Just had to unclip that zip tie to feed it thru the glove box.
Now I have an access point from the passenger side for the OFT and I can hide the cable when it's not in use.
Works nicely with the Beatsonic tablet mount. Now I enjoy monitoring stuff without cables around my leg.
orz is offline   Reply With Quote
The Following 4 Users Say Thank You to orz For This Useful Post:
DarkPira7e (11-26-2022), humfrz (12-04-2022), MJones_RB (11-29-2022), Teseo (12-04-2022)
Old 11-26-2022, 10:16 PM   #24024
DarkPira7e
DarkPira7e's Avatar
I bought one of these and routed it into the glovebox, super nice! For some reason, my ECUTEK bluetooth adapter hates it though. I have to have it seated juuuuuuust right. hit a bump and bam
