Old 10-27-2022, 11:35 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Wally86 View Post
I wouldn't see a doctor unless it does that for more than four hours
i'm told that's only if you're boosted.
i'm told naturally aspirated is fine to run for longer.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
villainous_frx (10-28-2022), Wally86 (10-28-2022), x808drifter (10-28-2022)
Old 10-31-2022, 01:14 AM   #16
euniqe
euniqe's Avatar
Drives: 2012 Toyota 86 GT
Looks like the connector for the wheel speed sensor. When I broke mine, the cooling fans would stay on whenever accessory was on, the check engine light stayed on, and it would run weird. Bought a new sensor, plugged it in and cleared the code with my bluetooth OBD dongle and Torque Pro. Good as new. Honestly reckon once you clear the code it will be fine.
euniqe is offline   Reply With Quote
The Following 3 Users Say Thank You to euniqe For This Useful Post:
Dadhawk (11-01-2022), NoHaveMSG (11-01-2022), whataboutbob (11-01-2022)
Old 11-01-2022, 08:39 AM   #17
whataboutbob
AutoX-10/10ths every run
+1 for wheel speed sensor. You probably have an ABS code.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
brz, check engine light, help needed, issue
Check engine light then a traction control light then just a check engine... and then Jstyle Issues | Warranty | Recalls / TSB 13 02-15-2021 05:10 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
