Old 10-04-2022, 10:21 PM   #4691
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Greetings all. I’m an original owner of a 2013 FRS. Have been running a Delicious Tuning E85 Flex Fuel package for many years along with full header / exhaust and I still love it. The car has 33,000 miles on stock motor. I’ve always wanted more power, however, and the Edelbrock has always looked like it had the most potential. My question is, on E85 Delicious dyno shows well over 400 whp and a massive torque bloom. Is this a realistic expectation from this kit with their Flex Fuel kit utilizing only stock fueling?
Jeff86 is offline   Reply With Quote
Old 10-04-2022, 10:41 PM   #4692
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
From my understanding that's a big no. Without a built motor and the smaller SC pulley you won't be near that.
Every car is different and dubious vary but from what I've seen and felt in my car stock block and stock pulley will get you around 270ish on 93 and 320ish maybe on E. And even at that point they recommend a fuel pump upgrade and injectors.
IIRC you might be able to squeak by on 93 with stock injectors but will need to upgrade if you want to utilize ethanol with the SC.
So looking at that graph I'd hazard a guess that green is stock, blue is stock SC kit, and pink is built motor and smaller pulley.
aKaGorganZola is offline   Reply With Quote
The Following User Says Thank You to aKaGorganZola For This Useful Post:
Jeff86 (10-07-2022)
Old 10-05-2022, 02:28 AM   #4693
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Yeah… I was dubious as well. They indicate the graph is stock vs SC on 93 vs SC on E85. No mention of mechanicals.
Old 10-05-2022, 09:12 AM   #4694
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Of course, I would want to utilize my Flex Fuel setup with this supercharger and their tune for it. Is there any danger with that if I don't upgrade the fuel system?... or is it more a matter of not hitting numbers as crazy as those? I'm pretty sure 300+ hp would put a huge smile on my face.
Old 10-05-2022, 04:28 PM   #4695
CSG Mike
CSG Mike's Avatar
That's neither realistic, nor reliable on a stock engine.
You should start with just the kit and larger port injectors, along with a good tune and perhaps a MAP relocation kit. You'll need a clutch if you're a MT.
Old 10-05-2022, 04:29 PM   #4696
CSG Mike
CSG Mike's Avatar
An injector upgrade will be mandatory to run e85 and boost
Old 10-06-2022, 09:17 PM   #4697
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
That’s my biggest question. When I made 550 whp on my k20a2, I had 1000cc injectors, a circulating fuel system and an in-tank plus an external fuel pump. I was just wondering how they achieved their numbers since no other info was provided. Would larger injectors alone be sufficient? Also what’s the next point of failure on this engine? Throw a rod through the block or headwork to repair a rocker/spring issue?
Old 10-06-2022, 10:04 PM   #4698
CSG Mike
CSG Mike's Avatar
1000cc injectors would be enough fuel for about 650whp; stock K20 injectors wouldn't even be close.
Likewise, stock FA20 injectors can do basic boost, but not with E85.
The injectors get you fueling overhead to deliver enough fuel. The weakest link will always vary with setup.
Old 10-06-2022, 10:41 PM   #4699
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
So I’m not wanting to go crazy on this build… just want to have more fun. Would DeatschWerks 700s be up to the task on flex? Understanding that boost is controlled with your foot, I wouldn’t press my luck all that often on stock internals.
Old 10-07-2022, 02:45 AM   #4700
CSG Mike
CSG Mike's Avatar
Yes, but the ID 1050X has a nicer spray.
Jeff86 (10-07-2022)
Old 10-11-2022, 06:09 PM   #4701
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
No, you definitely will need larger injectors and recommend a fuel pump to go with it. As for power, these are realistic numbers even on a pulley one step larger.
As for injectors, I would also recommend ID1050cc as Mike stated, as this will give you head room with the direct injectors. The DW700cc injectors are good for most applications to about 380hp.
If you want reach out to us at sales@delicioustuning.com.
Thanks,
William
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Jeff86 (10-14-2022)
Old 10-19-2022, 02:54 PM   #4702
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I've officially joined the Edelbrock crew! Thanks for the feedback guys and thanks to @DeliciousTuning for the help with parts and tune. I'm super excited and will drop some pics when the kit goes in!
The Following 2 Users Say Thank You to Jeff86 For This Useful Post:
DeliciousTuning (10-20-2022), dpfarr (10-19-2022)
Old 10-24-2022, 05:42 PM   #4703
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
So I’ve got the fueling setup worked out. Now I’m wondering about spark plugs. On the k20a2 setup, I do run a colder plug than stock, but the power (and cylinder heat) is significantly more than will be with this supercharger setup. It still seems like it may make sense to go perhaps one heat range colder than stock. Do you guys recommend this?
Old 10-24-2022, 08:04 PM   #4704
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I run 1 step colder plugs and haven't had any issues
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Jeff86 (10-24-2022)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
