#43 |
If the battery is ok, I bet it's the clutch switch. Prior experience here.
https://www.ft86club.com/forums/showthread.php?t=133895
#44 | |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
All of you theory’s have nothing to do with troubleshooting. You are the one that stated Ohms law. It is called law because electricity behaves exactly that way. Series circuits are voltage dividers. That is what a starter circuit is. Parallel circuits are current dividers. Go back and read the internal resistance of you battery with your VOM. |
#45 | |
#46 |
Drives: Crapcan
Or he can just reply to the thread. His last post here is 7 days ago. If he doesn't want to do the suggested and give results it's open to fuckery.
#47 |
LMGTFY
Drives: 13 FRS, 91 Miata
#48 | |
Drives: FR-S,GTI
I have the base model FR-S. Is there something wrong with my car? It's been that way since day one but it doesn't bother me because that's the way every car I have owned started. I've rented a couple Prius's that had the button. Didn't like it. I couldn't tell if the engine was running or not. |
#49 | |
Yes you have to hold the key for a couple of seconds so that it does the same as the button. The button just electronically holds for the same amount you need to hold the key in start. What happens AFTER you hold the key is exactly the same between the two. In both cases you are just sending a signal to the control modules that release the steering lock and actually start the car. Not knowing if the car starts is a Prius thing and it wouldn’t matter if it was a button or a key.
#50 |
Drives: 2014 Black BRZ Limited
Sorry for the ghosting. Just came back from a work trip.
We figured out the problem and I'm almost too embarrassed to say it lol. So I normally have to jump start my car after storing away from winter. What I tend to do is take out the fuse for the horns as the alarm will go off and I don't want to wake my neighbors behind me. What did I do the last time I took out fuses? I removed the ignition fuse. I guess this is what happens when you jump the gun and hyper focus on what it could possibly be. |
#51 |
30 minute maintenance
Drives: My18 wrxsti
6th post in this thread should have jolted a memory?
#52 |
It was one of those things that I kept over looking.
I think it's because I was more of checking if they were blown than actually seeing if they were all there. Even had a friend spend around 30 minutes looking at the fuse box. It wasn't until he asked me what was different this time that I retraced my steps and we noticed they were missing. A total facepalm moment. |
#53 | |
| 2013 Scion FR-S cranks but no start!!! | Btborja | Issues | Warranty | Recalls / TSB | 43 | 10-29-2023 10:30 PM |
| Car cranks but won't start after openflash custom tune install | kyu01186 | Software Tuning | 1 | 10-05-2021 08:28 AM |
| Long cranks and engine struggling to start. Please help! | pakunodafie | Engine, Exhaust, Transmission | 17 | 09-08-2021 03:32 PM |
| HELP! Cranks but won't start P0102 P0113 | Sum10clever | Issues | Warranty | Recalls / TSB | 2 | 09-06-2020 12:46 AM |
| Car cranks but wont start | yablonskiy11 | Issues | Warranty | Recalls / TSB | 15 | 01-02-2019 01:18 PM |
