Old 10-19-2022, 04:27 PM   #23927
Grady
Grady's Avatar
This. It would never occur to me to go to the dealer first for a bolt, unless I couldn't find it anywhere else first.
I am just the opposite, always go with the OEM option first. Know it cost more but can not stand an off fastener.
The Following 8 Users Say Thank You to Grady For This Useful Post:
Dab (10-21-2022), DarkPira7e (10-19-2022), jcw99 (10-20-2022), MJones_RB (10-20-2022), new2subaru (10-24-2022), norcalpb (10-19-2022), Ultramaroon (10-20-2022), Wally86 (10-20-2022)
Old 10-19-2022, 04:32 PM   #23928
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This is what I did for my rebuild. $230 worth of fasteners was far better than "shit, where'd that solo cup full of LF bolts go.."
Old 10-20-2022, 01:34 PM   #23929
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
You mean you don't replace all your stock hardware with zinc-plated ones?
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
strat61caster (10-20-2022)
Old 10-20-2022, 02:07 PM   #23930
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Back in the late fifties a family friend replaced his 1953 Studebaker Commander DD with another one he had found. He then took his original car and stripped it down for a complete nut and bolt restoration. Mind you the car was only about eight years old. Anyway, he fixed all the rusted areas with new metal and then painted everything with several coats of zinc yellow primer before giving it it's final colour coats. Any hardware that was getting painted was zinc coated. Hardware that was not getting painted or that was exposed to the elements was switched for stainless steel. He was an engineer, what can I tell you.
When the car was finished he put it in long term storage in the back of his biggest shed. It was a decade or more before it came out.
The Following User Says Thank You to Stephen W. For This Useful Post:
MJones_RB (10-21-2022)
Old 10-20-2022, 03:28 PM   #23931
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Waiting for shims to finish the engine, valve lash is out, not by a ton but by enough that most need a size or two up to hit nominal spec, 3-4 are actually out of spec. Crank bearing #3 had some light damage so the rod was the big one, block should be good to be put back together and kept as a spare, might need a new crank though.
As a note, d4-s does not eliminate buildup on the intake valves, a few were pretty grimy after 117k miles, cleaned up the buildup on the combustion chamber as well. Some flashing on the intake tells me a diy port job would yield gains, but not worth the effort for the average Joe (or those competing where the rules prohibit it). Also lapped the valves because there was some pitting and the service manual recommended it.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
bcj (10-20-2022), RToyo86 (10-20-2022)
Old 10-20-2022, 03:34 PM   #23932
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Even pure port injected engines and carbureted engines have about as much buildup as what you have on your valves. That's really not bad.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
strat61caster (10-20-2022), Ultramaroon (10-20-2022)
Old 10-20-2022, 04:30 PM   #23933
strat61caster
You’re right, guess I’m just surprised how necessary a good old fashioned tune up still is. Never really had a car get to this age and for me to consider it worth doing.
ineedyourdiddly
Old 10-20-2022, 05:00 PM   #23934
As usual, MSG and I are on the same page.
NoHaveMSG (10-21-2022)
Old 10-20-2022, 09:08 PM   #23935
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Made a carbon flip panel to cover the ugly knobs
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following 6 Users Say Thank You to Raven86Project For This Useful Post:
Busybee (10-21-2022), DarkPira7e (10-20-2022), Jdmjunkie (10-21-2022), MJones_RB (10-21-2022), q335r49 (10-26-2022), RToyo86 (10-25-2022)
Old 10-20-2022, 09:15 PM   #23936
DarkPira7e
DarkPira7e's Avatar
That's really neat. I like the "exposed simple knob" look, but I also can't get out of 80s and 90s car interiors
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Raven86Project (10-20-2022), Wally86 (10-21-2022)
Old 10-20-2022, 11:54 PM   #23937
Pat
Pat's Avatar
Drives: 2023 BRZ
I'll bet you do.
Sorry. I'm a child.
The Following 2 Users Say Thank You to Pat For This Useful Post:
DarkPira7e (10-21-2022), Tcoat (10-22-2022)
Old 10-21-2022, 12:39 AM   #23938
so many knobs
bcj (10-21-2022)
Old 10-22-2022, 12:22 PM   #23939
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
JDL goodness finally arrived
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
DarkPira7e (10-22-2022), MJones_RB (10-24-2022), Teseo (10-23-2022), villainous_frx (10-22-2022), WildCard600 (10-26-2022)
Old 10-22-2022, 07:55 PM   #23940
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
First snow day with the car. Didn't have space to store the car or get another, so she's on daily duty for this winter. In ~4" of Calgary slush the car did great with the 215 Kumho Wi31's, no complaints or loss of traction that wasn't self inflicted
villainous_frx is offline   Reply With Quote
The Following 7 Users Say Thank You to villainous_frx For This Useful Post:
bcj (10-22-2022), Busybee (10-23-2022), DarkPira7e (10-23-2022), Jdmjunkie (10-23-2022), RToyo86 (10-22-2022), Stephen W. (10-24-2022), Teseo (10-23-2022)
