Old 10-19-2022, 09:25 AM   #1
TorqueRavine
Accelerated Performance Turbo Kit
Hello all, I recently picked up a 2nd hand turbo kit for a steal. After doing some research, I came to the conclusion that I bought an Accelerated Performance turbo kit.
https://www.ft86club.com/forums/showthread.php?t=9942
This kit is supposedly the 1st turbo kit ever built for the 86 platform. From what I’ve seen, the turbo is installed underneath the car and connects directly to the OEM exhaust manifold.
An old classifieds post, says that the kit originally came with instructions. I was wondering if there were any previous owners of this kit who wouldn’t mind sharing the instructions file?
TorqueRavine is offline   Reply With Quote
Old 10-19-2022, 11:53 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How about just calling Accelerated Performance?
https://www.acceleratedperformance.com/
Old 10-20-2022, 05:00 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Like 99% of the cases. No.
It's almost like there's a Forced Induction sub forum for a reason too...
Old 10-20-2022, 09:26 AM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Maybe ask in the thread that you included in your original post
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 10-20-2022, 12:32 PM   #5
TorqueRavine
The guy hasn’t posted since 2014, their fb page has been dead since January and I read he disappeared. I didn’t think there would be a number to even call.
I now understand why forums have basically died off.
Like 99% of the members are unhelpful assholes.
Old 10-20-2022, 01:12 PM   #6
You asked a reasonable question and received reasonable responses. If you had said you had tried to contact them to no avail in the first post nobody would have given the answer they did.
This forum is far from dead and if there was anybody that could help I am sure they would but you are asking about a 10 year, old long out of production, limited run product where the company disappeared so I doubt anybody is going to be able to help. Try Facebook since I hear they are all wonderful and knowledgeable over there.
You come for help and because you didn’t receive instant gratification your second post is an insult so not sure who the real asshole is here.
Old 10-20-2022, 01:40 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't give enough of a shit about accelerated performance to do more then google "accelerated performance brz turbo kit", the only things that popped up were two threads, this one and the one you linked. I kicked you a link to the website cause you never know if someone bothered to check there first which happens A LOT with new members so you would have to excuse us if we come across a bit snooty. It sounds like you are SOL on the instructions and likely not going to get any help here with that attitude. Good luck, probably should have researched the kit before you bought it.
Old 10-20-2022, 01:53 PM   #8
TorqueRavine
Oh no, I appreciate you sending me the link to their website. I tried to thank your post, but idk how. I managed to get in touch with someone. It’s the other guy, who was being snarky for absolutely no reason when it’s clear I literally signed up for the site yesterday. I wasn’t even aware of the forced induction sub.
Old 10-20-2022, 02:58 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd start with going to the Accelerated thread and cataloging what you got. He has a parts list there and pictures. Verify you have everything from the kit. In the end, it is just a turbo kit and the install should be relatively straightforward. If you get stuck, post a picture and someone may be able to chime in. There are other kits out there mounted in that position and they are all similar so you should be able to compare to kits like the Works kit. You may be able to hit them up and tell them you bought one of their kits used and get instructions from them for reference. That way you can see how things like the scavenge pump is mounted and hoses routed, and reference it to the parts you got. Should give you a good idea to work off of.
Old 10-20-2022, 07:48 PM   #10
x808drifter
LMGTFY
If I'm snarky it's because spoon feeding people has gotten REAL irritating after nearly 20 years of it.
Like I also said in the other thread.
Will you get a response from the OEM?
Probably no.
But please do that first or at least tell us you did.
Otherwise it makes you you like a lazy person.
Old 10-21-2022, 08:33 AM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
AFAIK Russ and Don are still active and running accelerated performance. They were still open last time I was in Toledo but that was also the same January timeframe.
Sounds like you did get a hold of them anyways though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
S> Accelerated performance turbo kit GT 86 Brah Engine, Exhaust, Bolt-Ons 9 12-28-2013 09:22 PM
