| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: between cars...
Anyone running the OEM Mudflaps?
I'm considering adding these to my BRZ for winter duty. I was hoping this could be a seasonal add on, but looking at the instructions there is some drilling involved and not sure if they would be ok to install and remove. Who has them and do you think they help keeping the car more protected?
#2 |
Drives: BRZ 2023
I went with GR86 mudguards instead. Those offer little protection comparatively but still better than nothing. I don't think I could have lived with the ones made by Subaru. You do need to drill holes, about 1 on each side for front and 4 for rear. I just did 2 for rear thought. You can use rivets for drilled holes and previous holes already have rivet you can keep.
| The Following User Says Thank You to ruturaj001 For This Useful Post: | DocWalt (11-10-2022) |
#3 | |
#4 |
Drives: '22 BRZ
+1 on the toyota splash guards. I've been happy with them. From what I've seen, I would not buy the subaru ones as it seems they tend to deform. If you want something more substantial and seasonal then maybe consider the rally armor urethane flaps. I've had those on other cars and they worked well.
#5 |
Drives: 2022 Subaru BRZ 6MT IR
I've had them for a year now. In short: they are just "ok."
In long: https://www.ft86club.com/forums/showthread.php?t=148138
2022 BRZed, Red, Base, Manual, Simple
#6 |
Drives: 2022 BRZ
Been running them for a year as well. I had to shorten the front ones since I'm sitting a bit lower, but they have worked well to keep rocks and dirt from kicking up too much. Held up just fine. You have to drill, but those holes get plugged with a clip that can be reinstalled if you remove the flaps.
#7 |
Drives: Mini Cooper S
Has anyone had luck with non-OEM flaps?
| Mudflaps with Sti Brz? | WhiteChocolate | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-30-2015 04:10 AM |
| FS: OEM TRD Mudflaps | fretchh | Exterior Parts (Aero, Lighting, Etc.) | 6 | 12-20-2014 12:18 AM |
| FS: OEM mudflaps | BMWDavid | Exterior Parts (Aero, Lighting, Etc.) | 4 | 01-07-2014 09:50 AM |
| FRP or PE mudflaps | OICU812 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-02-2013 06:19 AM |
| OEM FRS Mudflaps | jgbruno | Cosmetic Modification (Interior/Exterior/Lighting) | 70 | 03-12-2013 12:05 AM |
