Old 10-14-2022, 03:24 PM   #23913
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Installed a TRD Shift Bezel.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 5 Users Say Thank You to KMA KiCKz For This Useful Post:
DandoX (10-14-2022), DarkPira7e (10-14-2022), Jdmjunkie (10-14-2022), MJones_RB (10-14-2022), RToyo86 (10-15-2022)
Old 10-14-2022, 06:49 PM   #23914
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
man, one of my aftermarket TPMS just died on me. Totally not responding on that tire. I hear that TPMS just sometimes go bad, but my OEM non programmable sensors that I got with the car are still fully functioning.
I got Maxi Autel universal programmable TPMS (made in china) I've had them less than 2 years and one sensor just up and died. I'm trying to work with Autel support and also tire rack (where I got the sensors from) to get a replacement, well see, hopefully I do.
Not sure if this is a one off sensor fail or an indication of the quality of these sensors. Anyone run any tires using these sensors for any of your cars.
DandoX is offline   Reply With Quote
Old 10-14-2022, 07:55 PM   #23915
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Finally got around to changing my black brake fluid. I just about used a quart getting it all pretty again.
The Following 10 Users Say Thank You to Sapphireho For This Useful Post:
DarkSunrise (10-15-2022), Kaotic Lazagna (10-14-2022), MJones_RB (10-17-2022), new2subaru (10-16-2022), NoHaveMSG (10-15-2022), RToyo86 (10-15-2022), soundman98 (10-14-2022), Teseo (10-15-2022), Ultramaroon (10-14-2022), WildCard600 (10-15-2022)
Old 10-15-2022, 09:00 AM   #23916
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Well replacing the short block was in fact the right call.
#2 rod bearing was toast, haven’t split the block yet but suspect at least one main bearing is toast because it still won’t turn smooth with all the pistons out.
Heads look decent enough to re-use. I found no metal in them, oil filter did its job.
ineedyourdiddly
The Following 14 Users Say Thank You to strat61caster For This Useful Post:
bcj (10-15-2022), Busybee (10-16-2022), DarkPira7e (10-15-2022), DarkSunrise (10-15-2022), Jdmjunkie (10-15-2022), MJones_RB (10-17-2022), new2subaru (10-16-2022), NoHaveMSG (10-15-2022), Pat (10-15-2022), RToyo86 (10-15-2022), soundman98 (10-15-2022), Teseo (10-15-2022), Ultramaroon (10-20-2022), WildCard600 (10-15-2022)
Old 10-16-2022, 05:27 PM   #23917
new2subaru
Weight Weenie
Drives: 15 FR-S
Picked up something to help with the maintenance.
It's an older Atlas MR-06. I like the fact that it has dual locking mechanism and no cables. All works well and it was a good deal.
The Following 5 Users Say Thank You to new2subaru For This Useful Post:
Busybee (10-16-2022), Kaotic Lazagna (10-16-2022), MJones_RB (10-17-2022), RToyo86 (10-16-2022), soundman98 (10-16-2022)
Old 10-16-2022, 06:01 PM   #23918
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You're about to make some friends who need lift access
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 10-16-2022, 07:05 PM   #23919
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by Kaotic Lazagna View Post
Been doing 1 year changes for years on multiple cars. Well, 15k miles when I used to commute 120 miles each day.
Never had any issues, and many people have sent their oil in for analysis with great results.
I was of the 6 month and 5,000-mile persuasion but called my oil analysts for an opinion. They said modern oils are good for up to 3 years. I wont go to that extreme though. I'll go to 1-year intervals since I don't put much more than 5,000 on in a year anyway.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
Stephen W. (10-17-2022)
Old 10-16-2022, 07:13 PM   #23920
new2subaru
Weight Weenie
Drives: 15 FR-S
lol
Old 10-16-2022, 09:13 PM   #23921
Kaotic Lazagna
Drives: GR Corolla
3 years! Wow. I'm only putting 3k a year, and even then I think it's pushing it. LOL
Old 10-17-2022, 03:26 AM   #23922
blakebrz
Drives: 2017 Toyota GT86 (sorta stock)
Tranny and diff fluid change + rusty bolts
Shifting has been very difficult and my gear linkages have been super rough since my last track day, so I changed the diff and transmission fluid. 58k kms and it's never been changed. My God, did it ever need it. Fluid changes went off without a hitch, no problem. But when I removed the bolts that hold on the scrape plate and plastic cover that protect the transmission case, every bolt was extremely rusty. When I finished the fluid change, I still put them back in, but they are all very brittle and one (non-essential one) even broke in my hands. I feel like I should replace all of them soon, as they are all in extremely poor condition, but I don't know where to order them from, the part numbers, how not to get ripped off, etc. If anyone knows, please help me out or send me to the right place. Thank you!
It's my DD and I live in Southern Ontario, so there's lots of salt and the entire underbody is so rusty, I can't even believe it. I've never seen anything like it. Wish I had brought my jack to the test drive before I bought the thing.
Next on the list is debadging. Unless the OEM is paying me to advertise, I don't do that ish for free
blakebrz is offline   Reply With Quote
Old 10-18-2022, 01:39 PM   #23923
norcalpb
norcalpb's Avatar
So when I'm ordering parts for an 86 I'm always under the impression that Subaru will have them for cheaper.
I go to parts.subaru.com
Just put in a 2013 subaru BRZ. The bolts you want are part of the body so you will want to select the "body" category.
Keep scrolling until you see "Under cover & Exhaust Cover". Click on the diagram. On the top right of the photo you'll see the cover you are talking about. You'll see a lone drawing of a bolt called M000344. This means you can safely assume all the other bolts are the same, and there are 7 of them. If you click the link for that part, you'll see it's a m6 bolt that is 16mm long. Part number is 901000344
In terms of getting ripped off, these bolts are inexpensive, so this is something I'd go to the local dealer for. Maybe call ahead of time to see if they have them in stock. Most likely they'll need to special order. If this price is higher than what MSRP is I always say "I was hoping we could get a little closer to the MSRP of (actual MSRP)" and they will bring it down.
For more expensive OEM parts, plug the part number into google and order from a wholesaler. I like subarupartsdeal.com.
The Following User Says Thank You to norcalpb For This Useful Post:
strat61caster (10-18-2022)
Old 10-18-2022, 03:57 PM   #23924
strat61caster
Toyota dealer where I bought my car has decent prices, order online select local pick up. Might save like 2-3% cross shopping for most parts in my experience unless there’s a rare piece sitting on a shelf that they want gone.
ineedyourdiddly
Old 10-19-2022, 07:40 AM   #23925
WNDSRFR
Drives: FR-S,GTI
Or you can go to the hardware store and buy 7 M6 bolts 16mm long.
The Following 4 Users Say Thank You to WNDSRFR For This Useful Post:
Busybee (10-19-2022), Dadhawk (10-19-2022), gen3v8 (10-19-2022), Wally86 (10-19-2022)
Old 10-19-2022, 12:28 PM   #23926
This. It would never occur to me to go to the dealer first for a bolt, unless I couldn't find it anywhere else first.
gen3v8 (10-19-2022), Grady (10-19-2022), soundman98 (10-19-2022)
