Old 10-11-2022, 02:31 PM   #15
bhmax
Drives: 13 BRZ, 17 Focus RS
Originally Posted by FrickingReallySlow View Post
How much did you pay for the trans? Was it from a totaled ‘22 recycler
It was the one on eBay. Ended up being $1500 shipped. Probably pricier than it should be. Hopefully we’ll see more of them (unfortunately for the owners) and the price will come down.
bhmax is offline   Reply With Quote
Old 10-11-2022, 06:00 PM   #16
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
https://www.ebay.com/itm/28497515266...SABEgISqPD_BwE
Here is another one on eBay for $1,600 plus $200 shipping. I'm probably going to do a CD009 swap unless someone shows that the second gen is a whole lot stronger than the first gen.
Old 10-11-2022, 07:05 PM   #17
PulsarBeeerz
Drives: JRSC BRZ SOLD
Knowing Subaru it will be only 20% stronger to go with the 20% of additional engine output. That turbo K24 will shatter the case. lol No reason to be scared of slamming 4th all over again if you can help it.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Irace86.2.0 (10-11-2022)
Old 10-13-2022, 01:15 PM   #18
bhmax
Got the car running with no issues, so the swap itself is no issue. It’ll just come down to if it’s actually strong enough for a given torque/driving style and availability/price.
The Following 3 Users Say Thank You to bhmax For This Useful Post:
DarkPira7e (11-08-2022), Irace86.2.0 (10-15-2022), zc06_kisstherain (01-16-2023)
Old 10-15-2022, 11:14 AM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I wonder if the 2nd gen has these components.
https://toyotagazooracing.com/jp/gr/grparts/86/
Old 10-15-2022, 11:59 AM   #20
Irace86.2.0
Maybe. They said larger/stronger 4th and shot peening and upgraded syncros I thought. I don’t know. Cheaper just to get a used transmission than doing a rebuild with those components, unfortunately. At that point, a CD009 swap would be better. Most people are spending like $4k+ for rebuilt stock transmissions.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
blsfrs (10-15-2022)
Old 11-08-2022, 05:29 PM   #21
86league
Drives: '13 BRZ Limited
So the 2nd gen bolts up and the connectors for the trans are the same - no modification needed for a 2nd gen trans in a 1st gen car?
86league is offline   Reply With Quote
Old 11-09-2022, 01:35 AM   #22
bhmax
Yep. All the same.
The Following 4 Users Say Thank You to bhmax For This Useful Post:
blsfrs (11-09-2022), fableluke (01-20-2023), Teseo (11-10-2022), zc06_kisstherain (01-16-2023)
Old 11-09-2022, 05:07 PM   #23
Sasquachulator
Pavement Grey
So does it actually feel different in any way?
Would that just be due to the upgraded/tweaked components inside?
The Following User Says Thank You to Sasquachulator For This Useful Post:
blsfrs (11-10-2022)
Old 11-09-2022, 07:34 PM   #24
bhmax
Well, it doesn’t suck, but I was coming from bad 3rd and 4th gear synchros so anything would be better.😆 I’m not sure it would actually be any better than a brand new 1st gen trans feel wise, but it was the best option for me at the time.
The Following User Says Thank You to bhmax For This Useful Post:
blsfrs (11-10-2022)
Old 11-10-2022, 12:23 AM   #25
zachseidy39
Drives: 2014 base manual Raven FR-S
So does this pretty much confirm that you can interchange gen 1/2 clutches? Might be nice to throw a gr86 clutch in my fr-s when it needs one if it has a slightly higher torque rating
zachseidy39 is offline   Reply With Quote
The Following User Says Thank You to zachseidy39 For This Useful Post:
blsfrs (11-10-2022)
Old 01-12-2023, 01:05 AM   #26
Irace86.2.0
I just did the gen 2 swap because it was the cheapest and fastest swap for now to get me into something newer and slightly stronger. Everything bolts right up. I swapped the MTEC springs, Verus forged fork and billet pivot. I'm using a South Bend Endurance clutch that is a kevlar clutch rated to 450tq. We will see how everything works out with my K24 turbo. I'll be taking the car to the dyno in a few weeks. Shooting for 450whp and 350wtq.
The Following 8 Users Say Thank You to Irace86.2.0 For This Useful Post:
bhmax (01-19-2023), blsfrs (01-12-2023), Breadman (01-12-2023), DarkPira7e (01-12-2023), fableluke (01-20-2023), MrSkubi (01-12-2023), x808drifter (01-12-2023), zc06_kisstherain (01-16-2023)
Old 01-12-2023, 09:26 AM   #27
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Following this closely. I dont expect my trans to hold up my highboost pulley build for much longer.
The Following User Says Thank You to Breadman For This Useful Post:
blsfrs (01-12-2023)
Old 01-12-2023, 11:09 AM   #28
Irace86.2.0
My power goals are less than what people have done with the FA20 on the gen 1 transmission, so if it holds on the dyno, that won’t be saying much empirically.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
blsfrs (01-12-2023), x808drifter (01-13-2023)
Help! Transmission mount to transmission bolt size Four_wheel_drifts Engine, Exhaust, Transmission 4 08-31-2020 02:55 PM
FR-S 6MT Transmission crazyfrenchbiker Transmission and Driveline 2 02-21-2017 02:54 PM
Transmission with F/I SimplyIcy Engine, Exhaust, Transmission 21 05-08-2016 08:47 AM
WTB TRANSMISSION boostedfrs Want-To-Buy Requests 17 07-24-2014 07:46 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
