Old 10-13-2022, 07:16 PM   #15
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It takes way less than 12V to start a car, a starter will crank down to really low voltage, often low enough that modules are flickering on and off and a car will crank and start down in the 10V range, heck, I seen some shit start below 9V but more to the point...
We have a binary situation here, not a slow crank, a crank and then -nothing- and I presume the dash lights are NOT throwing a disco since op hasn't brought it up so his voltage isn't so low that electronics are throwing a fit. It's still better to ascertain
"does car want to start by putting voltage to Switch terminal" Y/N
If Yes then you've got all the time in the world to worry about supplying a lot of amps to anything you might desire, but if No, a battery connection and ground path so clean you could eat off of it will not help it start.
Old 10-13-2022, 11:51 PM   #16
Kojiro
Drives: 2014 Black BRZ Limited
That is correct. Lights on dash are not flickering or going crazy. They resume normal operations after attempting to crank and dying.
Kojiro is offline   Reply With Quote
Old 10-14-2022, 02:30 AM   #17
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Says you. My car was the same and the battery was bad and needed replacing.
Lights and gauges were completely unaffected. And just for clarification yes I mean the headlights.
Old 10-14-2022, 02:32 AM   #18
Kojiro
That’s strange.
When my old battery was crapping out, it would get dimmer until there was nothing left. Then I would just jump it and it would start.
New battery in it now with a tender.
Old 10-14-2022, 08:10 PM   #19
Grady
Grady's Avatar
Ok lets stop talking or recommending a test light. It is not the 70’s any more. You can get a volt meter for $15. We need to know voltage, not the light dimmed a little. Hell the price of infrared imaging has come dow so much I have one. Talk about a great way to troubleshoot electrical!!!
The Following 2 Users Say Thank You to Grady For This Useful Post:
soundman98 (10-15-2022), Tcoat (10-14-2022)
Old 10-15-2022, 12:39 AM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
but only if it's nearly on fire!
Grady (10-18-2022)
Old 10-18-2022, 04:34 PM   #21
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
No.
Check at the most effective test point that provides the most information at the earliest in the diagnostic.
Is it a problem on the starter motor circuit? Is a problem on the ignition switch circuit? You must know where to look before you can look, and checking everything end to end is a big dirty waste of time.
As much as I hate to admit it, I have to agree with @Tcoat on this one.
If you're using an old-school test light to attempt electrical troubleshooting on modern vehicles, you are not a mechanic that I would want to bring my vehicle to.
A decent quality digital VOM is the proper tool to troubleshoot with in these (and all) modern cars.
Throw that old test light away. Then check the battery voltage at each post first, then from the positive post to one of the +12V fuses in the fuse block under the hood that is always energized, then crank the starter and measure that voltage. This will let you know if you have any resistance between the post and the fuses. Any measured voltage greater than 0.1 volts and you have too much resistance (probably caused by corrosion or loose terminals) and you should address that.
Do the same thing for the negative post and to the engine block while cranking. Any measured voltage greater than 0.1 volts indicates resistance between the negative post and to the block. Address that if needed.
Once you've established that your positive and negative cables are clean and secure, and that your battery is not weak, then you can move on to diagnosing individual circuits.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
Grady (10-18-2022), Tcoat (10-18-2022)
Old 10-18-2022, 06:51 PM   #22
RZNT4R
The starter on a '72 works the same as a starter on a '22. Small current make big current go brrrrr. What changed is the key used to control the starter solenoid directly, now your key or push button request a start and the PCM obeys, or not, if the conditions aren't correct.
The starter circuit is one of the last things on modern cars, along with a rear defrost, that is still ideal prey for a test light.
If you want to think otherwise that's fine by me, enjoy yourself.
Old 10-18-2022, 07:18 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Test lights have their place, especially when you are just checking if something is switching when it is supposed to. Sometimes it is not easy to manipulate a control while holding a meter leads where they need to be and be able to see the screen, even with alligator clips. I have an LED with a magnet glued to it with alligator clips on it to check switching that I use sometimes.
Old 10-18-2022, 10:36 PM   #24
Grady
Grady's Avatar
You would be amazed, you can see temperature differences you can not feel with your hand.
Old 10-18-2022, 10:40 PM   #25
Grady
Grady's Avatar
The fluke 233 has replaced that, Hell mine will display on my phone.
Old 10-18-2022, 10:45 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Fluke 233 -4-500
Led with magnet glued to it that I found-almost free.
My old meter is still kicking. Not upgrading till I have to.
Old 10-18-2022, 11:06 PM   #27
soundman98
soundman98's Avatar
i've got one. really don't use it as much as i expected to.
usually can spot the problem in the form a greasy breaker/melted wire first.
Old 10-19-2022, 11:17 AM   #28
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
The issue is that the '72 doesn't have sub-5 volt circuits in it that could easily be damaged by connecting a 12-volt incandescent bulb in series with them. Modern cars do, and the possibility exists that when you are probing for the suspected correct circuit, you might accidentally probe one of those low voltage circuits. Then you'll have to explain to your customer why they need a new ECU when all they originally dropped their car off was for a non-start situation....and you'll still have troubleshoot and fix the original issue once the ECU has been replaced and reprogrammed, etc. And you may have introduced even more issues to some of the low voltage circuits that the ECU is monitoring even after all of that. That is a risk that I would not take as a technician with many years of experience diagnosing vehicle electrical issues, and just about any other kind of electrical issue that you can think of.
For all of the old-school guys that still insist on using a "test light" to troubleshoot with, I would recommend a digital version of it such as this one here,
which as you can see has sequencial LEDs to show the level of voltage in the circuit you are testing, and can conveniently allow you to have one hand free if you attach an alligator-type clamp adapter to the end of the wired probe. The low voltage electronics in the digital "test light" pose no threat to modern electronics. Using a tool like this would be insurance taken to prevent a huge headache down the road.
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
soundman98 (10-19-2022)
2013 Scion FR-S cranks but no start!!! Btborja Issues | Warranty | Recalls / TSB 43 10-29-2023 10:30 PM
Car cranks but won't start after openflash custom tune install kyu01186 Software Tuning 1 10-05-2021 08:28 AM
Long cranks and engine struggling to start. Please help! pakunodafie Engine, Exhaust, Transmission 17 09-08-2021 03:32 PM
HELP! Cranks but won't start P0102 P0113 Sum10clever Issues | Warranty | Recalls / TSB 2 09-06-2020 12:46 AM
Car cranks but wont start yablonskiy11 Issues | Warranty | Recalls / TSB 15 01-02-2019 01:18 PM
