#15 |
Drives: 2017 BRZ
Thanks!
I have been thinking about that one for a while, rules be damned I would run it out the quarter panel or rockers with a trim ring around the opening like a TA2 car but since I would have to take p/w hit for ST4 for any floor/rocker modification for exhaust I figure I will run 3" round at the collectors, transition to a 3" oval equivalent (ground clearance) and merge to a single 4" or 4.5" oval equivalent tube and exit to the passenger side just under the rocker panel, it will angle downward so you wouldn't really see it but it would be right at the edge of the rocker - since I have no fuel tank under the car - (hard to paint a picture). |
#16 |
Drives: 2017 BRZ
One other good note for this week, I received my shocks/springs, MCS 2 way with Vorshlag plates.
I was pretty impressed on the adjustment range and a quick test shows it will go pretty close to -7* on the front Will be starting with a 25mm Hotchkis front bar and stock 15mm rear bar. I may end up making a splined speedway bar for the front but we will see how this is first. I ended up doing that on my last mac strut race car and it worked very well but the off the shelf bars available were shite at the time. I shouldn't have sold that car, miss it a lot. Pic also gives a glimpse of where this one is going, no widebody or picnic table splitter due to class rules though |
| The Following 3 Users Say Thank You to gt5759 For This Useful Post: |
#17 |
Drives: 2017 BRZ
More work complete! Finished up the fuel cell area top and bottom. Media blasted, painted and installed billet bushings in the rear subframe. Fuel filler neck and hose is done other than changing a couple clamps i'm not happy with looking at
| The Following 5 Users Say Thank You to gt5759 For This Useful Post: | DocWalt (09-20-2022), Kelse92 (09-14-2022), RedReplicant (09-13-2022), villainous_frx (09-20-2022), Wally86 (10-12-2022) |
#18 |
Drives: 2023 BRZ
So cool. Thanks for sharing.
Director of Rocky Mountain 86CUP
| The Following User Says Thank You to Pat For This Useful Post: | gt5759 (09-13-2022) |
#19 |
Drives: 2017 BRZ
Few side notes and some more sheet metal work done this weekend.
As I was working on the new differential, pulling the gears to send off for REM treatment, I did some comparison shots of the internals versus a 8.8 ford diff I have, quite the material difference! If the factory diff dies I'll fab up a 8.8 using a newer aluminum housing from like a 2018 mustang gt but for now I'll try the factory torsen, REM treat the gears and use a knock off cusco diff cover for some added fluid capacity. Gear's are from a 2012 is250 (3.727 ratio) Sheet metal wise I finished up the firewall but still need to do the harness loops for the center net and main belts on the center bars of the cage. |
#20 |
Drives: 2017 BRZ
Plugging away as I get time, thankfully the racing season is ending so people will hopefully stop breaking stuff for me to work on
![]() Got the gears back from REM treatment and the diff is assembled with billet bushings. (bushings are from salasko racing) For people wondering why the polishing, it's to help reduce friction so less heat in diff and more power to the ground. All painted up and new cover installed Started working on the coolant pipes as well, kind of off track a bit but I really wanted to see some progression in the bay a bit, motors are my favorite part. |
#21 |
Drives: 2013 frs base
Great build. I'm curious, it looks like you blocked off the rear compartment. No rear view mirror? Are you going to use a camera system?
| The Following User Says Thank You to blsfrs For This Useful Post: | gt5759 (10-11-2022) |
#22 | |
Drives: 2017 BRZ
I will attempt to mount it up high on the cage near where the factory mirror was as naturally your eyes move that way but worst case it will be down on the dash in line of site. I drove a few cars with this style of camera and it works beautifully. |
| The Following 5 Users Say Thank You to gt5759 For This Useful Post: | blsfrs (10-12-2022), ML (10-12-2022), RedReplicant (10-11-2022), villainous_frx (10-11-2022), Wally86 (10-12-2022) |
#23 |
Drives: 13 White MT FR-S
Just saw this thread! looks like an awesome build. You don't have a template for the side windows you could share do you?
https://www.ft86club.com/forums/pict...ictureid=12941
| The Following User Says Thank You to ML For This Useful Post: | gt5759 (10-12-2022) |
#24 | |
Drives: 2017 BRZ
but maybe not.I don't have a way to scan the templates so I'm not sure how i would do that really. I use construction paper from hobby lobby to make the templates and then transfer to main material if that helps. |
| The Following User Says Thank You to gt5759 For This Useful Post: | ML (10-12-2022) |
#25 | |
I have played around with taking a picture of something and tracing it in Fusion360 and then getting it laser cut from sendcutsend.com but its hard to get a straight on shot and be perfect.
#26 | |
Drives: 2017 BRZ
| The Following 2 Users Say Thank You to gt5759 For This Useful Post: | ML (10-12-2022), villainous_frx (10-12-2022) |
#27 | |
Drives: Fr-s
BTW, this build is kick-ass, can't wait to see it hit the track.
| The Following 3 Users Say Thank You to redlined600 For This Useful Post: |
#28 | |
Drives: 2017 BRZ
| Jensen NASA ST4 race build | thin2win | Member's Car Journals | 18 | 04-14-2021 12:15 AM |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
| Car 986 Scion FR-S NASA PTD Race Car Build | phastafrican | Member's Car Journals | 70 | 01-03-2015 09:32 PM |
