Old 10-07-2022, 04:21 PM   #19615
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Took the summers out. Used the long reach low profile jack for the first time and loved it. Also, used the Autel TS508 for the Position learn and it was done in 30 seconds.
A local shop and one of the chain tire shop quoted me around $200 for this swap. Unbelievable!
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following 2 Users Say Thank You to Busybee For This Useful Post:
soundman98 (10-07-2022), Wally86 (10-12-2022)
Old 10-07-2022, 10:43 PM   #19616
soundman98
ProCrastinationConsultant
soundman98's Avatar
what's with all the rags over the car?
Old 10-07-2022, 11:38 PM   #19617
Busybee
Busybee's Avatar
That’s the only leveled spot but has Acorns all over the place
The Following User Says Thank You to Busybee For This Useful Post:
Ultramaroon (10-08-2022)
Old 10-08-2022, 06:31 AM   #19618
JD001
JD001's Avatar
Drives: Subaru BRZ
Talking
You should make friends with the person across the road, nice drive..
The Following User Says Thank You to JD001 For This Useful Post:
Busybee (10-08-2022)
Old 10-08-2022, 12:18 PM   #19619
Busybee
Busybee's Avatar
That’s true! I know them and they are very nice people. They offered me their spot whenever I need it. I just take my time and enjoy it slowly
The Following 6 Users Say Thank You to Busybee For This Useful Post:
Dzmitry (10-12-2022), JD001 (10-08-2022), Sapphireho (10-08-2022), soundman98 (10-08-2022), Teseo (10-08-2022), Ultramaroon (10-08-2022)
Old 10-08-2022, 02:11 PM   #19620
Indeed!
Busybee (10-08-2022), Dadhawk (10-08-2022), soundman98 (10-08-2022)
Old 10-12-2022, 06:58 PM   #19621
Busybee
Busybee's Avatar
Washed, detailed and prepared her for some autumn shots
The Following 5 Users Say Thank You to Busybee For This Useful Post:
bcj (10-13-2022), Dadhawk (10-12-2022), soundman98 (10-12-2022), Ultramaroon (10-13-2022), Wally86 (10-13-2022)
Old 10-13-2022, 02:39 AM   #19622
Perfection
Busybee (10-13-2022)
Old 10-13-2022, 09:42 AM   #19623
Perfection
Hope he took the picture and moved!
You couldn't pay me to park on a bunch of dry leaves.
Old 10-13-2022, 11:21 AM   #19624
soundman98 (10-13-2022), Tcoat (10-13-2022)
Old 10-13-2022, 11:22 AM   #19625
joro2
joro2's Avatar
Drives: 2017 BRZ Premium MT (DGM)
(Cross posted from an older thread on trans/diff fluid changes, apologies for any duplicates.)
Had a routine oil change yesterday @ 21K on my 2017 BRZ (MT base Premium).
The dealer mentioned ("recommended") a few additional items needing service, some which made sense and others not so much.
- Battery failed load test; reasonable, given that the BRZ is 66 months old and still on the original battery; ACCEPTED i.e. went for the new battery (it was competitively priced).
- New tires; yeah, they're 5.5. years old and have 21K miles, but I feel confident I can safely go one more oil change interval before shopping tires (another topic, i.e. new tires) I DECLINED.
Then came these suggestions:
1) "Alignment and fuel induction service"
I didn't find these in the factory maintenance schedule, what are they? Did they mean a standard wheel alignment AND some kind of fuel service? Or is "alignment" part of the fuel service? I DECLINED.
2) Was told I should (or did the service manager say "recommended" again?) replace the manual transmission fluid and the rear diff fluid. I found ambiguous factory info on this, some say 30K miles, other text entries say every 4 years (regardless of mileage) for the diff, which is it? Couldn't find anything on the transmission fluid except "inspect". Since there's no dipstick on either I assume "inspect" means the tech drives it and decides if they don't like the way it's shifting.
I feel as though I foolishly ACCEPTED.
Looks like they also did a rear diff BG flush.
From new the BRZ was notchy, for the first ~5-7K sometimes finicky until warmed up. And remained notchy, once in a while not slipping as smoothly into gear as I'd like, but still always one of the better manuals I've ever owned.
Short story I said yes to both (diff and trans fluid change). Immediately was feeling remorse, as only at 21K, never tracked, etc. But do admit shifting was definitely noticeably "smoother" (maybe slightly heavier? less mechanical clunks) after the service. Not sure yet which I liked better, before or after the fluid changes. Either way I feel like Steve Jobs felt about opening up iPhones, once cracked open RUINED!
So, feeling ripped off! I know better but somehow (because I'm an IDIOT) dropped my guard.
I know, I know -- dealer is always a ripoff (although as I said these services all were competitively priced).
What say you re: the trans/diff fluid change at 5.5 years/21K miles? And what is that "alignment and fuel induction service"? Feel free to call me an IDIOT, I've done the same for the past 24 hours.
PS They also gave me a "free wash" at the dealer. something I forgot to decline, I always hand wash the car and have since new. Dealer has a cheap toy car wash set up. All in all, what was a simple service turned into a pricey bad BRZ day, really my first in 5.5 years of ownership.
And that's what I did to my BRZ (yesterday). Thanks for reading my whine.
joro2 is offline   Reply With Quote
The Following 2 Users Say Thank You to joro2 For This Useful Post:
Busybee (10-13-2022), Clipdat (11-01-2022)
Old 10-13-2022, 11:23 AM   #19626
Downer or not it is a hidden danger! My mom lost a car to that once.
Old 10-13-2022, 11:30 AM   #19627
Those leaves would burn about as well as the bright green grass over which they lay. That is in no way a tinderbox.
Old 10-13-2022, 11:31 AM   #19628
You did well. You accepted exactly what you should have and declined what is just a money grab.
Cars are not like iPhones and are built to be opened up and serviced without being ruined. In fact they MUST be opened up and serviced periodically.
Busybee (10-13-2022), Dadhawk (10-13-2022), joro2 (10-13-2022), soundman98 (10-13-2022)
