Old 10-11-2022, 08:37 PM   #1
ThatYeti
Install questions with VIS duckbill trunk on '17+ car
Seen lots of videos and how to's ob installing carbon trunks on older cars and I'm comfortable with how to handle the backup camera but nobody seems to cover the opener/sensor. Anyone done this and can advise or can point me to a DIY/How-to/write-up?
ThatYeti is offline   Reply With Quote
Old 10-12-2022, 06:54 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I did the Seibon on my car and it was pretty straight forward.
Opener/sensor? Do you mean the latch? Cus that's just two bolts, easy peasy.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 10-12-2022, 07:27 AM   #3
ThatYeti
Not the latch, unless I guess that's what it's called. I'm talking about the proximity sensor button/popper/opener/etc. that works with the proximity key (for push button ignition cars).
Old 10-12-2022, 09:07 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Oh, I've got the poor man spec (base model) so I have no idea
The Following User Says Thank You to Wally86 For This Useful Post:
ThatYeti (10-12-2022)
Old 10-13-2022, 10:04 AM   #5
ThatYeti
Bueller?
Old 10-14-2022, 06:48 PM   #6
ThatYeti
I can't possibly be the first one to do this....can I?
Old 10-15-2022, 03:50 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
I've been told being a lowly '14, I'm both too poor and too out of touch to be able to do anything with the new cars.
So apparently you're the last hope of anyone modding a '17! Good luck!
* The entire license plate light/keyslot/button assembly should migrate over and bolt up directly to the new trunk. Yay for standardized parts!*
ThatYeti (10-15-2022)
Old 10-15-2022, 03:55 PM   #8
ThatYeti
Appreciate that but based on the pics below of the carbon trunk and stock one (albeit with the garnish still on) am I gonna have to make a huge cut for that opener/sensor?
Old 10-15-2022, 05:32 PM   #9
soundman98
soundman98's Avatar
looks exactly like it ought to me.
minus the garish welding failure, this is what an oem trunk looks like at nearly the same step without the buttonpad/keyslot/subaru logo plastic assembly:
Old 10-15-2022, 08:27 PM   #10
ThatYeti
I'll have to take my garnish off to confirm but basically I'm looking at cutting a hole the size of that sensor?
Old 10-15-2022, 09:30 PM   #11
soundman98
soundman98's Avatar
no, don't cut any holes. the bolts line up.
this trunk garnish piece from your other trunk needs to just be bolted on.
https://www.ebay.com/itm/12423211358...Bk9SR4icyeb7YA
Wally86 (10-17-2022)
Old 10-16-2022, 05:38 PM   #12
ThatYeti
Right but that garnish has a cutout for the opener. And I imagine you'd need to cut a hole in the carbon garnish to match and a hole in the trunk to run the wires, no?
Old 10-16-2022, 07:49 PM   #13
soundman98
soundman98's Avatar
you shouldn't need to drill anything. the trunk opener button wires should go through the larger hole near the middle. everything on the 2 trunk lids, despite the differences in brands line up perfectly.
just take your old trunk apart, and put the new one together exactly the same way.
edit, oh, you're talking about the carbon garnish that bolts to the trunk lid-- you probably ordered the fr-s version, where you needed the brz version. yes, for that you would need to cut the button into the garnish, but the holes already exist in the lid for the wires.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
ThatYeti (10-17-2022), Wally86 (10-17-2022)
Old 10-17-2022, 07:05 AM   #14
ThatYeti
Picked it up used and it was on an earlier car, figured I'd only have to worry about cutting a hole for the camera, but hadn't considered the opener/sensor. Will give it a shot at some point.
The Following User Says Thank You to ThatYeti For This Useful Post:
WTB: VIS AMS carbon fiber duckbill trunk Goulash Canada Classifieds 0 07-01-2017 06:53 PM
Duckbill trunk install to IFO - Subaru BRZ - HAWAIICALIVEGAZ Cosmetic Modification (Interior/Exterior/Lighting) 4 01-02-2016 03:16 AM
Duckbill questions? OkieSnuffBox Cosmetic Modification (Interior/Exterior/Lighting) 5 09-11-2015 04:52 PM
GB: SE Tuned Custom Duckbill Trunk Speed Element Groupbuys 87 06-04-2015 11:38 PM
FS--IL/MO: My SWP/WO Trunk w/TRD Duckbill for WINGLESS + CASH OmarGC Exterior Parts (Aero, Lighting, Etc.) 9 08-14-2014 09:14 AM
