Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 10-03-2022, 01:11 PM   #1
formulaBRZ
Resident Grannyshifter
formulaBRZ's Avatar
Drives: 2022 BRZ w/ STI aero
'22-'23 Average Oil Temps
Hey all, looking for feedback on your 2nd Gen oil temps!
Where in the temperature range does your oil stay under daily driving conditions?
I commute ~30-40min for work of all highway miles. My oil is always able to get fully up-to-temp, and I like to keep an eye on where those temps are hovering just as an engine health data point.
As the BRZ does not have an numerical temp gauge like the GR86, I'm basically having to eyeball my temps and 'guess-timate'. It seems like the oil stays between 190-240F, with the average probably ~215F. The higher-end of those temp ranges have come during stop-and-go summer commuting but are not infrequent in 80+ degree weather.
What is your guys' experience with the oil temperature in the 2022? Does the 0w-20 leave more to be desired?
formulaBRZ is offline   Reply With Quote
Old 10-03-2022, 01:30 PM   #2
KillerBMotorsport
KillerBMotorsport's Avatar
About the same temps, depending on several variables.
Only on the second oil change here. Using Amsoil, but the oil analysis results are good so no reason to change. I did get some Motul 0w20 I may try at some point.
KillerBMotorsport is offline   Reply With Quote
Old 10-03-2022, 04:22 PM   #3
jongers
Drives: 19 86, 22 BRZ
Commuting via freeway I get about 210-215 max with SoCal summer weather. Temps have stayed the same between using 0w-20 + 5w-30.
jongers is offline   Reply With Quote
Old 10-03-2022, 05:05 PM   #4
Petah78
Drives: 2022 BRZ sport-tech
This is interesting, as in 2.5L of each weight oil? Any particular reason to mix?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 10-03-2022, 07:20 PM   #5
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
200F
Baby, you can drive my car
Shub Deetle is offline   Reply With Quote
Old 10-04-2022, 03:20 PM   #6
jongers
Ah, sorry for the confusion. I recently did an oil change to 5w-30 when I dropped my oil pan. Had 0w-20 previously.
Both oils have given me similar temps.
The Following User Says Thank You to jongers For This Useful Post:
Petah78 (10-04-2022)
Old 10-04-2022, 07:41 PM   #7
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
190-200 when highway driving in 70f (about 19c), 230 at the hottest when I'm driving like an idiot during hot weather.
Sent from my SM-S908U1 using Tapatalk
Interceptor777 is offline   Reply With Quote
Old 10-05-2022, 10:05 AM   #8
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
In normal driving, I've never gone over 200 degrees, even when sitting in stop-go traffic on the highway at 100F.
I've not noticed it going much higher when driving aggressively. I've autocrossed it a few times, but never done a track day.
Desertnate is offline   Reply With Quote
Old 10-07-2022, 02:25 PM   #9
formulaBRZ
formulaBRZ's Avatar
Dang, really? 200 seems to be the lower-end for me any time it gets over 80 degrees and I'm on the highway more than 30 minutes. This is why I wish I had the GR86's numerical gauge so that I'm not just eyeballing a line.
Old 10-07-2022, 02:51 PM   #10
OkieSnuffBox
Drives: '23 BRZ Limited
I know it read it somewhere but now I can't find it in the manual how we change the dash to display oil temp instead of coolant, or add it to the days.
EDIT: Finally found it.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 10-11-2022, 12:19 PM   #11
Desertnate
Spelling Impaired
Yes. The temps are very consistent for me, to the point any variance is really obvious. Even on a blast through the hilly backroads this weekend at temps in the low 70's I didn't get it to budge.
The only time I've seen my oil temps go over the normal point was while doing runs at an autocross event when air temperatures were 95F+. At that point it was probably 220~230, but quickly dropped back to normal as I drove off grid and back to the paddock.
Old 10-11-2022, 03:20 PM   #12
formulaBRZ
formulaBRZ's Avatar
I'd be really curious to learn how to do this, are you able to share?
I also skimmed my manual for this but couldn't find anything quickly.
Old 10-11-2022, 04:40 PM   #13
AK2112
AK2112's Avatar
Drives: 22 BRZ
I don't think you're going to be taxing the oil one bit with 40 minutes of highway driving.
Not being rude but this is why so many cars don't come with oil temp or pressure gauges.
AK2112 is offline   Reply With Quote
Old 10-12-2022, 11:18 AM   #14
OkieSnuffBox
Just the right/left buttons on the right side of the steering wheel will toggle through the different screens.
brz, daily driver, oil temperature, second gen
Average MPG for Trip A & B Lifer1988 BRZ First-Gen (2012+) — General Topics 5 01-31-2018 04:37 PM
What is your BRZ average MPG? Lifer1988 BRZ First-Gen (2012+) — General Topics 60 01-30-2018 08:54 PM
23.7 average MPG, is that bad? edigeek BRZ First-Gen (2012+) — General Topics 76 08-21-2015 11:13 PM
Average MPG in SoCal? PradiG Southern California 64 07-30-2013 05:41 PM
What will the average MPG be? Poll! SOB Scion FR-S / Toyota 86 GT86 General Forum 52 04-22-2011 05:48 PM
