View Poll Results: Coilovers?
Ohlins R&T V2 15 78.95%
HKS Hipermax IV GT 4 21.05%
Voters: 19. You may not vote on this poll
Old 05-28-2020, 04:54 AM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
So, RCE with "latest sets" spoke about MP22, not MP21? So "new" - 5kg/mm springs, that were optional choice for MP21, now default? Or it's "We make sure to specify that at this point" - that is still option one needs to ask for when ordering?
AFAIK
MI20: 6kg square & included camberplates in set
MP20: "new" with 4kg front, 3kg rear, camberplates became optional
MP21: should be same as MP20, but TUV certified and with extra rubber seats for NVH (though according one MP21 manual seems that defaults might be not 4/3, but 4 square, and funny, but recommended spring preload also differs even for front with same rates.). And one could optionally order with 5kg square rates.
MP22: 5kg square by default, or not?
Seems PITA to hunt for specs that simply should be listed in product description page or linked docs on manufacturer website.
RayRay88: i recall seeing someone saying that usually good coilover valving should be able to accomodate +/-30% spring rate change. But i don't know for sure, if MP2* shocks still have same valving as MI20 had or not, saw contradicting info on that. If track on sticky tires is priority, imho custom valving might be better option. Or something like these BTO ones with 9/7 rates .
Old 05-28-2020, 06:41 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by weederr33 View Post
Oh the irony of this thread. I was actually looking at these as well! Good info
Where is the irony?
Old 05-28-2020, 08:20 AM   #17
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by churchx View Post
SUU MP22? Looks like recent addition (all previous kits were prefixed SUS). Also MP22.
I wonder what might changes be. So far more or less get what differences are between previous versions of MI20, MP20, MP21. Would appreciate for someone to post what's new in MP22.
They removed the included top mount parts> lowered the spring rates from 6/6 to 4/3 > readjusted the valving again and then added rubber spring seats.
Old 05-28-2020, 09:41 AM   #18
Racecomp Engineering
Because they've changed so much, we just always specify exactly what we want.
Originally Posted by RayRay88 View Post
I share your frustration from a buyers perspective as well.
I would like to run some aggressive 200TW or less tires (RE71r/A052) on these and I want to make sure the 5/5k spring rates will support that while the car still functions as a daily driver with the occasional track day.
I would also like to know if the valving on these dampers support 6k/6k or 7k/7k spring rates or would that be really pushing them beyond their intended use?
With those tires I would recommend stiffer rates than 5k/5k but they'll still work well. The dampers will easily support 6k/6k. They'll support 7k/7k fine but that might be close to their limit.
Just remember their shift to more of the road side of the road&track equation. Totally fine for occasional track days. Great coilovers, just a little less flexible than they could be in certain ways.
- Andrew
Old 10-05-2022, 01:22 PM   #19
Swisher Seattle
Drives: 2017 BRZ LMT w/ performance Pkg
HKS HIPERMAX S is the best
Swisher Seattle is offline   Reply With Quote
Old 10-06-2022, 09:03 AM   #20
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Last post = Over two years ago.
Don't add anything useful at all.
You dumb or something?
FS: HKS HIPERMAX IV GT Mirageo Brakes, Suspension, Chassis 2 03-21-2017 10:55 AM
My ohlins warranty problem!!!!!!see what Ohlins China replies!!!!!!!!!!!!!!!!!!!!!!!! kkman User/Vendor/Sponsor Reviews, Feedback, Comments 18 03-31-2016 10:59 AM
HKS Hipermax IV GT vs KW V1 Stayreal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-17-2014 12:17 PM
FS: HKS Hipermax IV darthwong1138 Brakes, Suspension, Chassis 33 01-24-2014 08:04 PM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
