BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
10-03-2022, 09:52 AM | #1 |
Drives: '22 BRZ
Dumb question. Shifting into second gear
I don't have much experience with driving manual, but I want to keep my car healthy for as long as possible.
After having the car for almost a year, I am still a bit hesitant about shifting into second or if I am doing it correctly so I wanted to see what other people do. Basically my issue is shifting into second from first feels like there is some extra resistance there compared to other gears. It is especially more noticeable while the car is cold. It feels like I am forcing it in. Other gears after that are fine. Also I noticed after the car warms up this feeling of forcing the second gear in is not as bad anymore. What I have been trying lately is from first gear I would shift into neutral, and then go second and this actually feels much better compared to directly moving the shifter from top to bottom in a straight line. How do other people shift and what is the correct way? |
10-03-2022, 10:37 AM | #2 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Some gearbox oils make it hard to shift into 2nd gear until it`s warmed up.
10-03-2022, 02:09 PM | #3 |
Drives: 2013 FR-S Series 10
Usually helps if before you take off, work the stick (pause) through all the gears a few times at a standstill. Also it sounds counter intuitive but when it's cold its better to make the shift with all one motion, try not to pause too long in between 1st and 2nd.
It'll get better as you pile the miles on.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following 2 Users Say Thank You to Decep For This Useful Post: | Tcoat (10-03-2022), Ultramaroon (10-04-2022) |
10-03-2022, 07:47 PM | #4 |
ProCrastinationConsultant
you're working against the syncro's. try shifting into 2nd when the rpm's are closer to where they would be for the gear.
The Following User Says Thank You to soundman98 For This Useful Post: | fredzy (10-04-2022) |
10-04-2022, 06:27 AM | #5 |
Drives: 2013 GT86 fully standard
Probably then only thing i dislike with my 86, especially since i live in a cold country. I sometimes just go to from 1st to 3rd instead on upshifts, double clutch matched shifts can help, but not always. I also noticed 2nd goes in easier at upshifts if shifted at really low rpms, instead of reving up on 1st first.
2013 GT86, fully standard daily and occasional track day car
10-04-2022, 08:15 AM | #6 | |
Mebmer
Drives: Sienna, GR86, TourX
My 350Z had bad syncros. I tried a few different gear oils and ended up putting the OEM Nissan stuff back in. My process for 1st to second for the first couple cold shifts was to pop from first to neutral, wiggle the stick side to side (as a way of making a repeatable delay) then it would fall into 2nd easy as the revs would be matched. And as CedN says the lower the RPM the better especially as this technique would mean engine revs would be a smidge low once actually releasing the clutch. Double clutching seemed very hit or miss for 1 to 2, but was useful from 2 to 3 where the trans had maybe worse problems. Last edited by fredzy; 10-04-2022 at 09:48 AM. |
10-04-2022, 09:44 AM | #7 |
Wes
This is what I did. Changed the tranny fluid, installed MTEC shifter springs and perrin/whiteline shifter bushing combo (they come as a package). Night and day difference, really crisps up the shifts, no more issues.
Instagram: @gt86ws
10-04-2022, 12:24 PM | #8 |
the shifter bushing and transmission mount bushing DO help a surprising amount when its cold.
10-04-2022, 04:08 PM | #9 |
Drives: '22 BRZ
10-04-2022, 07:40 PM | #10 | |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Sent from my SM-S908U1 using Tapatalk |
10-05-2022, 11:09 AM | #11 |
Which bushings did you change to more specific?
10-05-2022, 01:00 PM | #12 |
Wes
it's this package
https://www.ft86motorsports.com/perr...-fr-s-brz.html I now also have subframe inserts from Whiteline, the STI trans mount, Perrin engine mounts, I used to have whiteline outrigger diff bushing inserts as well. Every single drivetrain mod added NVH but improved shifting.
Instagram: @gt86ws
10-05-2022, 01:38 PM | #13 |
That combo helps shift feel so much, but be warned it can make your car sound like a big rig at times with all the gear whine. i hated it at first, but eventually found it endearing.
10-06-2022, 04:20 PM | #14 |
Drives: '22 BRZ
Do you think double clutching into second while its cold is a good idea? I tried it today and the shift was super smooth
Similar Threads | ||||
A dumb question | ckilburn_ | Electronics | Audio | NAV | Infotainment | 9 | 06-05-2018 08:45 AM |
Dumb Question | 22R | Software Tuning | 3 | 10-30-2017 05:19 PM |
Turn Signal Relay Question (Dumb Question) | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-23-2017 01:58 AM |
might be a dumb question | TooChang | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-05-2014 10:10 PM |
Dumb question | ExWhyZer0 | Electronics | Audio | NAV | Infotainment | 2 | 01-25-2013 06:44 PM |
