go_a_way1, MisterSheep
Old 09-29-2022, 11:32 PM   #23885
arxm
Drives: 2013 FR-S, 2023 BRZ
did quite a bit, got fresh tires, got a very good deal on bilsteins for the car, figured since i'm in the suspension might as well refresh most of the bushings, got a custom tune and re-installed my splitter, been a busy few days haha, finally got a beater for the winter so I don't have to feel bad about putting all the aero back on. Im tired of losing parts to the 401
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 09-30-2022, 03:05 AM   #23886
keenanok
keenanok's Avatar
Drives: 2013 Whiteout FR-S
put a 25mm hub centric spacer on the back and they made the wheels sit pretty flush
keenanok is offline   Reply With Quote
The Following 4 Users Say Thank You to keenanok For This Useful Post:
Dab (09-30-2022), MJones_RB (09-30-2022), orz (10-01-2022), Wally86 (09-30-2022)
Old 09-30-2022, 02:21 PM   #23887
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Looks perfect!
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
keenanok (10-01-2022)
Old 10-01-2022, 01:37 PM   #23888
WNDSRFR
Drives: FR-S,GTI
Changed my rear brake pads. I had a set laying around since the last time I was going to replace them. But my lug studs stripped and after dealing with that I wasn't in the mood to do anything else.
But once you have the wheels off, it's the easiest job I've ever done. Just need to remove one bolt, swing the caliper out of the way, and replace the pads.
Nothing to it. And the brakes even still work!
Old 10-01-2022, 07:35 PM   #23889
new2subaru
Weight Weenie
Drives: 15 FR-S
Wheel well day,
Cleaned up the coils
Greased the caliper pins
Clean all the flaked paint of the pads and greased the tips!
Caliper gravity bleed.
Checked suspension bolts/nuts
Fueled her up and she's waiting for track day Monday
The Following 3 Users Say Thank You to new2subaru For This Useful Post:
DarkPira7e (10-02-2022), RToyo86 (10-02-2022), Wally86 (10-02-2022)
Old 10-02-2022, 12:45 PM   #23890
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Tightened everything in the front suspension today and gave all exposed threads the FluidFilm treatment. It's nasty and looks like shit, but way better than drilling out bolts the next time I need to take them off. Doing the back later, I have other stuff to do back there when UPS gets here.
Also didn't realize how much higher the front is than the rear... Going to raise the rear a bit maybe
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
new2subaru (10-02-2022), RToyo86 (10-02-2022), Wally86 (10-02-2022)
Old 10-02-2022, 01:01 PM   #23891
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Don`t know what specs or suspension you run. FYI I was quoted for mine 350mm center of wheel cap to lip on rear and 355mm for the front.
Old 10-02-2022, 01:14 PM   #23892
DarkPira7e
DarkPira7e's Avatar
HKS GTIV GT. The wonky ride height is my own goof, I set them and then never really looked back after everything settled since camber looked fine
Old 10-02-2022, 01:16 PM   #23893
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Re-mounted my driver's side USDM fog light...
I clipped a cone at the Autoclub speedway roval on the left turn coming off the banked turn into the infield at 60MPH... deflected the bumper cover enough to let the two tabs on the inboard mount pop out. All better now and ready for Streets of Willow!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
DarkPira7e (10-02-2022), Wally86 (10-02-2022)
Old 10-02-2022, 06:41 PM   #23894
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Took stuff apart
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
DarkPira7e (10-02-2022), new2subaru (10-02-2022), Wally86 (10-02-2022)
Old 10-02-2022, 07:36 PM   #23895
DarkPira7e
DarkPira7e's Avatar
Took stuff apart
I envy your non rusty pulleys and OCVs. I don't envy what you're taking on
Old 10-02-2022, 10:09 PM   #23896
soundman98
ProCrastinationConsultant
soundman98's Avatar
clean those headlights while you're there
Dadhawk (10-03-2022)
Old 10-02-2022, 11:56 PM   #23897
strat61caster
Ocvs are <9 months old, but for the rest yeah, no salt nor snow around here. After prying off the front cover and upper oil pan though, yeah this kind of sucks, hopefully I only have to do it once a decade or so.
Nah, they just get yellow again in 3-4 months, there’s other shit to do.
ineedyourdiddly
Old 10-03-2022, 01:24 AM   #23898
nextcar
After you polish them, spray them with clear UV protection spray paint
Krylon clear UV protection
Pull out
The Following 6 Users Say Thank You to nextcar For This Useful Post:
Dadhawk (10-03-2022), gen3v8 (10-03-2022), Jdmjunkie (10-03-2022), MJones_RB (10-03-2022), soundman98 (10-03-2022), strat61caster (10-03-2022)
