Old 10-01-2022, 01:32 AM   #15
Favato
Favato's Avatar
Drives: 86
Originally Posted by 2020BRZtS View Post
it had to be something of value. A sunglasses holder wouldn't cost enough to bother removing. Aftermarket satellite radio?
It is too weak, flimsy to support any considerate weight, I guess..
Tomorrow I will be working on my car and will access it from behind and luckly there will be some P/N
Favato is offline   Reply With Quote
Old 10-01-2022, 01:58 AM   #16
New headliner sells for a few clams. I don't know what year yours is, but...
https://parts.toyota.com/a/Toyota_20...4420-6402.html
Favato (10-01-2022), x808drifter (10-01-2022)
Old 10-01-2022, 02:30 AM   #17
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Length of the police tape is 50 meters?
Just use that instead.
Old 10-01-2022, 03:12 AM   #18
gpvecchi
gpvecchi's Avatar
If your car is JDM import, probably it was the aftermarket ETC.
It's a local accessory for wireless toll payment.
Old 10-01-2022, 04:35 AM   #19
Favato
Favato's Avatar
Drives: 86
Originally Posted by gpvecchi View Post
If your car is JDM import, probably it was the aftermarket EPC.
I have no idea even how to look it up, don`t really want to buy another headliner, will start thinking what to do next
Just saw this picture in another thread, would that be what you were mentioning?
Old 10-01-2022, 05:19 AM   #20
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
No, thats the Mic for hands free phone. I have that too.
The Following User Says Thank You to x808drifter For This Useful Post:
Favato (10-01-2022)
Old 10-01-2022, 10:17 AM   #21
soundman98
ProCrastinationConsultant
soundman98's Avatar
Everything you can think of, already spent 1.5 year fixing and tiding everything, when I installed my new headunit my friend who`s an autoeletrician told there were 2-3 different harness shoved inside. The unit we removed had a little controler but nothing that would fit there.
Would you have like a picture or anything? my next step is to find how to close this damn hole or cover.
post a picture of the wiring that's up there, that will help narrow down some of the differences.
this is really the best option.
to get rid of that spot correctly, it's going to be either
a: replace headliner with a new/used model
b: re-cover headliner with new material.
both involve taking the entire headliner out. A just requires swapping the new one in, B requires getting fabric, backing the hole with something a similar consistency as the rest of the headliner, and then applying spray-on adhesive, then applying fabric. many fabric stores carry headliner fabric.
i did it in a ford ranger after repeated attempts at the local junk yards failed to find the right model headliner, or one in any better condition. took all day to do, and it's not the most fun job in the world...
some guy's take the opportunity to use other materials to re-cover the headliner-- any fabric will work, headliner fabric just has a 1/8" foam backer on it which gives it a little flexibility.
Old 10-01-2022, 07:52 PM   #22
Favato
Favato's Avatar
Drives: 86
Any ideas?
Old 10-01-2022, 10:35 PM   #23
I'm out. Where is TAS? Perhaps try asking in a regional sub-forum.
Old 10-01-2022, 11:49 PM   #24
soundman98
soundman98's Avatar
i'm positive i've seen that design before. i just can't place it.
the wiring that's there is all oem. front harness is of course the dome light, the harness over the mystery hole should be the oem microphone connector. i was hoping there was another mystery connector i could trace down...
there's this 'trigger' brand wireless switch setup, but it's recessed pod design doesn't have the cutout in the side.
https://triggercontroller.com/produc...te-flat-mount/
i want to say there was another brand of wireless switch like that was really similar that had the cutout in the side to make it powered
there's also 2 HKS products. a boost controller and turbo timer. but neither appear to have a recessed mounting kit.
https://www.driftshop.com/hks-evc-s-...ontroller.html
https://www.driftshop.com/hks-turbo-timer-type-0.html
and finally, there's a few remote-head 2-way cb or ham radio's that have a similar mounting style, but all of them are more rounded on the corners than that design. and none are inset into the panel surface
http://atvillustrated.com/content/ru...ote-head-radio
i've tried about 50 other search terms i can think up, but none show anything closer than those above results
Favato (10-02-2022)
Old 10-02-2022, 03:27 AM   #25
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Right hand drive, pictures are dated a day ahead of US, my guess would be Tasmania.
Ultramaroon (10-02-2022)
Old 10-02-2022, 03:30 AM   #26
gpvecchi
gpvecchi's Avatar
Any ideas?
If you read my previous comment, I already answered you...
Old 10-02-2022, 04:35 AM   #27
Favato
Favato's Avatar
Drives: 86
I did read your comment and I appreciate, however I tried to search further info on that and could not find anything, also `probably` won`t work for me in terms of deciding what to do next.
Going to concentrate on my other projects and eventually either fit something, try to fix the hole or buy a new headliner.
Thanks for the support
Correct, I`m from Tasmania, I dare to say I can count the 86s with my hands in the whole state ha, probably no sub-forums
The Following User Says Thank You to Favato For This Useful Post:
Old 10-02-2022, 04:43 AM   #28
Favato
Favato's Avatar
Drives: 86
Thank you for the time and patience. I`m guessing this was fitted around 2014, reason? No idea. The tray doesn`t have any locking mechanism, unless the previous owner kept whatever there glued/velcro. And even if it was some boost controller, just seems very odd the location, I can only guess but I think he used to track this car, if anything useful could be used there, out of my knowledge. Also the install was 5/10, therefore I don`t think it came like that from factory nor specialised accessory fitting places, if that makes sense
key fob, interior dome light not working superlords2 Scion FR-S / Toyota 86 GT86 General Forum 4 03-26-2022 09:07 PM
interior dome light danielremjativa Cosmetic Modification (Interior/Exterior/Lighting) 15 07-21-2016 12:52 PM
Interior Dome Light Issues Mongo Issues | Warranty | Recalls / TSB 3 03-19-2014 04:52 PM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 08:59 PM
