Old 09-30-2022, 11:36 AM   #1
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Too much brake pad ?
Is something like the Project Mu 999 too much brake pad for a stock car running pilot sport 4 tires ?
For track usage only. Will be running OEM pads on the street. Not sure if it matters but the format of the track day is open pit lane so no run groups and I will have two drivers in the car.
autoracer86 is offline   Reply With Quote
Old 09-30-2022, 12:23 PM   #2
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
As long as the brakes get up to their proper operating temp range and are balanced front/rear, then IMO you can never have 'too much pad' unless you have a hard time modulating the brakes.
Project Mu website says 200-800C rotor temperature range, so I'd expect you can get there and stay in it once the car is warmed up.
I wouldn't use these in a low grip situation or rain because they'd be very aggressive and prone to lockup/ABS, as well as too low operating temp.
There are pads out there which would be better suited to the situation, but these will work for you since that was the original question.
Matt93SE is offline   Reply With Quote
Old 09-30-2022, 02:21 PM   #3
autoracer86
Drives: Toyota GT86
Thanks for the info Matt. After a bit of back and forth on my end I have ended up going with the CL pads in the RC6 compound from a local race shop
Old 09-30-2022, 03:10 PM   #4
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The CL sintered compounds do have excellent control compared to the 999, however, you'll want to be mindful of keeping the brake temps in check. Both CL and 999 do run incredibly hot so monitor your caliper seals and such.
CounterSpace Garage is offline   Reply With Quote
Old 09-30-2022, 04:42 PM   #5
autoracer86
Drives: Toyota GT86
Oh I never thought about that side of things haha.
Thanks for the information. I guess a cool down lap or two is in my future lol
Old 09-30-2022, 04:55 PM   #6
CounterSpace Garage
Just remember to drive to the tire and you'll find yourself being very consistent on equipment.
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings fc3s_johnny Brakes, Suspension, Chassis 11 10-05-2020 10:26 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
