Member's Car Journals Car journals by our members. |
#16 | |||||
~Hachi Roku~
Drives: 2013 Firestorm GT86 A/T
Thank you ALL for your kind comments.
Glad to become part of the family. And to answer a few questions asked since my last post. No friend, I'm not Emarati. Quote:
![]() Quote:
Now I'm at odds with where to apply it on the car. Any suggestions? Thanks Mishimoto. Took me 3 hours to finish the shoot around that part of town. Went on each side of the Creek to get the perfect shots.
#17 |
Drives: Toyota 86
Nice car Imti! (a forum name suspiciously close to my real one
![]() Congrats on the Firestorm, seems to be a very popular choice of colour in the UAE. FYI the recommended octane level is Super 98 on a ccount of the high compression. Might as well stick to the manufacturer's spec, it's not worth risking your warranty for the sake of a few dirhams less. Plus, this car is mindboggingly economical for a sports car.... Mine is now approaching 2000km. I think it's time for an owner's meet! |
The Following User Says Thank You to i_giado For This Useful Post: | Imti (07-31-2012) |
#18 |
~Hachi Roku~
This showed up at work an hour ago. And these were scheduled to arrive on the 9th.
Lucky me! ![]() Psyched! Can't wait to get off work. 2 hours to go. ![]() Update: I'm home. Couldn't find a decent spot to park and it's above 45'C outside. Will wait till the car cools down and the sun is setting. First time I saw the tips, they appeared really big. Now that I placed them near the diffuser. They appear alright. Now the challenge will be to align them nicely. All alignment tips are welcome. Update2: Size comparison (couldn't think of anything better for universal comparison than xbox slim) ![]()
#19 |
Driving Coach
I had to take the included washers out from inbetween the bolts and the shims to get the shims to back out enough and slip the tip on over the stock pipe. You'll probably need to do the same. Just slide them back until right before the pipe begins to curve to the muffler, youll notice when the tips start to point left or right instead of straight back. Then tighten the inside (top left for passenger side, top right for drivers side) bolt/shim first, then the bottom, then the 3rd one. Back up and look straight into the tip and make sure the stock pipe is centered inside the tip, then stand above the bumper and eyeball both tips to make sure they are even and one isn't sticking out farther than the other.
The Following User Says Thank You to ATL BRZ For This Useful Post: | Imti (08-02-2012) |
#20 | |
~Hachi Roku~
![]() I had to remove the washers and the support metal(shims as you said it?). So basically, what you see here is attached via bolts only. Should that be a concern? Would I lose the exhaust tips on a bump somewhere ![]() I couldn't for the life of me insert the tips with the metal thingies (shims).
#21 | |
Driving Coach
I wouldn't run with the bolts only and no shims. When you tighten them, the bolts focus pressure in one small spot, and your stock pipes may have indentations on them now from the bolts pressing against them. The force of the bolts only is not spread out enough for me to trust them gripping the pipe well and not falling off or getting misaligned. That's what the shims are for. Try putting them on again with the shims but back the bolts ALL THE WAY OUT to the point where they are barely threaded, then push the shims outward as much as you can (without washers inbetween) and then gently slide/wiggle them on the stock pipe making sure the shims don't fall down. Use two hands and you may have to hold the shims in place as you're sliding the tip on so the edge of the stock pipe doesn't get caught on the shims. Then tighten them the same way I said before and keep an eye on the alignment as you tighten. Last edited by ATL BRZ; 08-01-2012 at 04:35 PM. |
#22 | |
~Hachi Roku~
The problem doesn't seem to be the shims But the bolts. They are too small. When I tried inserting the tips with the shims/bolts on. The shins wouldn't go past the edges of the pipe. The bolts wouldn't let the shims go out further even when I U nscrewed them out to the end I believe I may need to invest in some longer bolts. And I'll have to check on the size of the stock pipes
#23 |
Drives: 2012 Tornado Grey Toyota 86 GTS
Car is looking good! Loving those location shots! Looks like a beautiful place!
The Following User Says Thank You to Cappuccino For This Useful Post: | Imti (08-02-2012) |
#24 | ||
~Hachi Roku~
I ordered an orange first. But somehow I got inclined to buy the red and I'm loving it. Been using Super98 from day one. But I'm a bit skeptical about the fuel consumption. I don't think it's as good as it is made out to be. Trip computer read 10litres/100km. That's roughly 22-23MPG I think. Another forum member has been hitting 31MPG. I'd wanna hit that number in Dubai. Nope, no spirited driving. Just city traffic. Perhaps that is to blame? Yes, GT86 owner's meet! We have plenty of Dubai members posting now. Should be fun. I suggest good time would be when the weather cools down a bit. It's a killer nowadays with 45'C and above. Quote:
Thanks! Dubai is gorgeous. A bit hot during these months but it's home. There are many more places I'd love to showcase my car if time n weather allow it.
#25 |
Wayward Member
Drives: Hot Lava 86
Those shots by the creek look like post cards or some type of advertisment.
The Following User Says Thank You to Nevermore For This Useful Post: | Imti (08-02-2012) |
#26 |
~Hachi Roku~
BEFORE (Stock exhaust pipe = Eugh!)
![]() AFTER (DC Sports EX 1012. Installed myself) ![]() ![]() ![]() ![]()
The Following User Says Thank You to Imti For This Useful Post: | Guff (08-05-2012) |
#27 |
Drives: GT86
Great Exhaust tips Imti. Do you have any idea if I can get similar delivered to Lebanon?
My car is still on the super ugly Middle-East lack of tips exhaust. |
#28 |
~Hachi Roku~
I got mine from US' Amazon.com and they should be able to deliver to your location I suppose.
LIGHTNING RED BRZ Compilation | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 408 | 05-29-2020 12:47 PM |
I'm changing my order from World Rally Blue to Lightning Red | Subie | BRZ First-Gen (2012+) -- General Topics | 26 | 06-12-2012 12:59 PM |
Lightning Red BRZ & Brilliant Red A4 Photoshoot | BRZ4me | BRZ Photos, Videos, Wallpapers, Gallery Forum | 9 | 06-02-2012 04:42 PM |
BRZ4me's Lightning Red Mini-Review | BRZ4me | BRZ First-Gen (2012+) -- General Topics | 41 | 05-29-2012 12:08 PM |
Lightning red/WRB side by side? | FLHC | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 04-15-2012 01:53 PM |
