Old 08-27-2022, 07:00 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Best source for axle boots
The boots on 2013 FRS are starting ooze some grease. I bought a spare axle and I am going to "rebuild" all 3 using Redline grease and adding a vent tube. I'd like to buy just the boots and not a kit.
What's the best source for them thar boots?
Old 08-28-2022, 04:03 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Subaru or Toyota parts department
EndlessAzure is offline   Reply With Quote
The Following 3 Users Say Thank You to EndlessAzure For This Useful Post:
blsfrs (08-28-2022), DocWalt (09-20-2022), x808drifter (08-28-2022)
Old 08-28-2022, 09:40 AM   #3
blsfrs
blsfrs's Avatar
Out of the 1000s of sub/toy parts depts, which one would you choose?
Old 08-28-2022, 11:49 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The one that costs the most..
The Following User Says Thank You to x808drifter For This Useful Post:
blsfrs (08-28-2022)
Old 08-29-2022, 08:13 AM   #5
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If you are going to replace you'd be better off getting the kit as the larger clamp isn't available seperately.
Order Here
If the grease in your old axles is just old and has liquified, just clean and repack them.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 4 Users Say Thank You to Opie For This Useful Post:
blsfrs (08-29-2022), Prodigalson (11-18-2024), RedReplicant (09-18-2022)
Old 08-29-2022, 09:17 AM   #6
blsfrs
blsfrs's Avatar
@Opie: Thanks for posting the video. It's been about 10 years since I took apart an axle so I need the refresher.. I ordered my boots from subarupartspro.com They were $17each + shipping. I found some random straps on ebay. I need to check to see if they are large enough.
Old 08-29-2022, 03:51 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Inspect the cups (for lack of a better term), I found mine deformed, axle failure was not imminent but certainly possible. Mine were only deformed in one direction, I heard an old trick was to flip them L/R if that was found, these will be my spares and they're marked as such.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
blsfrs (08-29-2022), Opie (08-30-2022), RedReplicant (09-18-2022)
Old 09-12-2022, 12:53 PM   #8
blsfrs
blsfrs's Avatar
Repacked with grease and rebooted. I bought a used left axle and put it on the right. I put my right on my left and will keep my old left as a spare.
Cleaning and repacking the outer cv was the worst part. Everything else was easy peasy.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
DocWalt (09-20-2022), strat61caster (09-12-2022), x808drifter (09-13-2022)
Old 09-18-2022, 06:56 PM   #9
blsfrs
blsfrs's Avatar
Finished up repacking my spare axle. This is my original left. 100k miles and 20ish track days.
There was some "heat" discoloration at the lip of the cv joints. I noticed it on my other axles as well. Is this from usage or the manufacturing process?
Old 09-18-2022, 08:46 PM   #10
strat61caster
Manufacturing, the boot would have melted if it got that hot on the car.
ineedyourdiddly
blsfrs (09-18-2022)
Old 09-18-2022, 10:13 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Probably case hardened the bearing surface.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (09-19-2022), DocWalt (09-20-2022)
Old 09-26-2022, 09:43 AM   #12
blsfrs
blsfrs's Avatar
Well, I suck at repacking CV joints. My left axle let go after 3 sessions. The next one (left again) let go after 2 sessions. The "cups" were hot to touch even after sitting for 1/2 hr. I eyeballed the amount of Redline grease that I put into the cup. It was 1/2 to 2/3's full. I packed grease around the bearings to hold them in place for installation. Was I supposed to pack the boot with grease too?
I'm biting the bullet and sourcing OEM axles today.
Old 09-27-2022, 11:09 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm .. are you boosted? Or do you run thick wheel spacers? Or maybe you have lowered car a lot? If later, i'd consider some diff riser kit to reduce back CV joint angle / reduce load & wear on it.
Old 09-27-2022, 12:35 PM   #14
blsfrs
blsfrs's Avatar
N/ A powered. 198 hp on last dyno pull. Lowered about 1" with Tein Flex A coilovers. I am running Federal 525 rs rr on 9x17 Apex Arc 8 wheels no spacers. Maybe I put the axle in backwards. (LOL)
Dss axle boots riped IsaiahW Engine, Exhaust, Transmission 0 07-09-2022 10:42 AM
AutoStyled - Hand-Crafted Shift Knobs/Shift Boots/Brake Boots Are Now Here! RallySport Direct Interior Parts (Incl. Lighting) 4 06-23-2017 01:37 PM
