go_a_way1, MisterSheep
Old 09-23-2022, 05:35 PM   #23871
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Gave it a good wash today
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 6 Users Say Thank You to KMA KiCKz For This Useful Post:
Kaotic Lazagna (09-23-2022), MJones_RB (09-27-2022), NLSP (09-23-2022), Teseo (09-24-2022), villainous_frx (09-24-2022), Wally86 (09-27-2022)
Old 09-24-2022, 08:08 PM   #23872
SoCalHANZ86
HANZ
SoCalHANZ86's Avatar
Drives: 2014 frs
changed brake fluid.
SoCalHANZ86 is offline   Reply With Quote
The Following 2 Users Say Thank You to SoCalHANZ86 For This Useful Post:
bcj (09-25-2022), Wally86 (09-27-2022)
Old 09-25-2022, 08:19 PM   #23873
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Installed STI motor mounts and took out the torque solutions mounts. So much quieter. Feels OEM, very happy
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
new2subaru (09-26-2022), orz (09-26-2022), RToyo86 (09-25-2022), Teseo (09-29-2022), Wally86 (09-27-2022)
Old 09-25-2022, 11:55 PM   #23874
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Full Exterior detail with ceramic coating.
The car is sitting in my friend's garage for a couple days to cure.
Shots from final polish before coating.
https://imgur.com/a/OilkUfA
Post coating shots
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
Kaotic Lazagna (09-27-2022), Stephen W. (09-26-2022), Teseo (09-29-2022), Wally86 (09-27-2022)
Old 09-26-2022, 01:46 PM   #23875
StraightOuttaCanadaEh
Wes
I'm also planning on replacing my perrin engine mounts with the sti mounts. After about 3-4 years on them, it's gotten annoying.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
DarkPira7e (09-26-2022)
Old 09-26-2022, 03:27 PM   #23876
DarkPira7e
DarkPira7e's Avatar
Go through Nengun, I got mine for like $230 shipped or something and they came quick
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
StraightOuttaCanadaEh (09-26-2022), Wally86 (09-27-2022)
Old 09-28-2022, 01:41 AM   #23877
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Pulled oil pan, looked at sparkles.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
DarkPira7e (09-29-2022), NoHaveMSG (09-28-2022), Tcoat (09-28-2022)
Old 09-28-2022, 01:50 AM   #23878
soundman98
ProCrastinationConsultant
soundman98's Avatar
i always said it's a bad idea to rent out cars on turo. before you know it, they're on stripper poles trying to earn it one buck at a time.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Ultramaroon (09-28-2022), Wally86 (09-28-2022)
Old 09-28-2022, 09:40 AM   #23879
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Sounds like the voice of experience. Do you do private parties?
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
MJones_RB (09-29-2022), Ultramaroon (09-28-2022)
Old 09-28-2022, 01:54 PM   #23880
Gonna DIY?
Old 09-28-2022, 03:05 PM   #23881
blsfrs (09-28-2022), JD001 (09-28-2022), MJones_RB (09-29-2022), soundman98 (09-28-2022), Stephen W. (09-28-2022)
Old 09-28-2022, 03:07 PM   #23882
NoHaveMSG (09-28-2022), soundman98 (09-28-2022), strat61caster (09-28-2022)
Old 09-28-2022, 03:51 PM   #23883
strat61caster
Gonna DIY?
Yeah, most reasonable option to get back on the road seems to be to order an oem shortblock, going to do that today, pull engine over the weekend, hopefully back together by next weekend. Disassemble short block at leisure and see if it’s salvageable to hold onto as a spare. Smells like the typical #3 crank bearing failure, engine died as I was getting my time slip after my 4th autox run, data shows it was pulling power during that run.
Sketchy ‘junkyard’ engines are $3-$4k, slightly less sketchy jdm engines are like $5-6k and my time is cheap right now because I quit my job.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Tcoat (09-28-2022), Teseo (09-29-2022)
Old 09-28-2022, 04:03 PM   #23884
I'm two months into a 2gr-fe rebuild. Timing cover is going back on tonight. Only way to be sure is to DIY. Good luck! Keep us posted.
soundman98 (09-28-2022), strat61caster (09-28-2022), Teseo (09-29-2022)
