Old 09-26-2022, 03:39 AM   #1
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Few questions from a new owner
After a few days with my new to me GT86 I have some questions ha
The overall ride quality seems good no real issues but if the road is a bit rough or I am dealing with speed bumps the front end seems very "crashy" Is this normal ? I get the feeling I have a blown shock up front.
Another odd thing it does and maybe this is related to the bad shock is under light braking say slowing down for a light or stop sign the front end seems to sort of oscillate. Like it has this sort of back and forth rock to it.
The previous owner did put on new pads and disk up front but they were as cheap as you can get and unfortunately unlike in the states were you can get good cheap blanks these were just cheap. I will be replacing them with OEM or better soon so that might fix this issue as I might just have a slightly warped rotor
Last thing I did notice was the speedo is reading low by 5kph/3mph. Tire size is stock and the car itself is stock. Is this normal ? if not any fix beyond just drive faster
TLDR Bought a 2014 gt86 that might have a blown shock and warped rotors
autoracer86 is offline   Reply With Quote
Old 09-26-2022, 06:54 AM   #2
randallryan569
Drives: Mazda Corolla
Hello
randallryan569 is offline   Reply With Quote
Old 09-26-2022, 07:29 AM   #3
Originally Posted by randallryan569 View Post
Hello
Reported
Old 09-26-2022, 07:32 AM   #4
Do you know if they changed out the struts? Some aftermarket suspension parts are very uncomfortable.
The probability of having warped rotors is very very remote even if cheap. OEM is the way to go.
Old 09-26-2022, 08:52 AM   #5
autoracer86
Drives: Toyota GT86
The car is stock for sure but it was crashed and repaired and from the looks of it on the Cheapside haha. So if you told me the struts had 100k on them I wouldn't be shocked.
I was at Toyota today ordering pads and rotors. The car will be seeing track time so I want to make sure the rotors are of good quality. OEM pads will be for the street driving
The Following User Says Thank You to autoracer86 For This Useful Post:
Tcoat (09-26-2022)
Old 09-26-2022, 09:04 AM   #6
Oh that adds a whole new dimension of possible issues.
I hate just throwing parts at something to try to correct a problem but the obvious answer is, as you plan, to replace the brakes and see if that helps. If not then onto the struts and hopefully that is it. If not then you are in for an adventure.
Old 09-26-2022, 09:22 AM   #7
autoracer86
Drives: Toyota GT86
Yeah I was planning on doing brakes anyway so no issues there. Same with suspension.
Tcoat (09-26-2022)
Old 09-26-2022, 09:25 AM   #8
Well hopefully that fixes it!
Old 09-26-2022, 09:00 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
sounds like it's most likely greasy pads.
https://alconkits.com/technical-info...ed-brake-discs
it's fine to change rotors and pads, though a thorough cleaning to the rotors and a good set of quality pads would likely bring braking performance back as well.
Old 09-27-2022, 03:33 AM   #10
autoracer86
Drives: Toyota GT86
Thanks for that. This does make we wonder do the oem pads need to be bedded in ?
Old 09-27-2022, 11:40 PM   #11
soundman98
soundman98's Avatar
i really never did. supposed to? it's probably not a bad idea...
Old 09-28-2022, 12:41 AM   #12
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
On your speedometer being off check your tire pressure. It may help all around to level it to spec.
2020BRZtS is offline   Reply With Quote
Old 09-28-2022, 07:33 PM   #13
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
How do you know that your speedometer is reading low? That might be reading high.
Old 09-28-2022, 07:46 PM   #14
autoracer86
Drives: Toyota GT86
GPS speed reading from my aim solo. Which also happened to match one of those slow down signs that show your speed.
I had a feeling it might be off because when driving home I couldn’t keep up with my friend and we both sent our Cruise control at the same speed. So I checked and I was right
New BRZ owner questions.... Petah78 BRZ Second-Gen (2022+) — General Topics 16 06-01-2022 06:39 PM
New Owner Questions PacManTheRS1.0 Scion FR-S / Toyota 86 GT86 General Forum 54 05-04-2018 11:23 PM
New frs owner few questions fridayfrs Scion FR-S / Toyota 86 GT86 General Forum 6 07-22-2015 06:00 PM
New Owner / New Questions Zinger Engine, Exhaust, Transmission 2 09-04-2014 07:57 PM
New BRZ Owner, some questions! JoonPrime BRZ First-Gen (2012+) — General Topics 4 08-28-2014 06:11 PM
