Old 09-20-2022, 10:43 PM   #15
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
While we are on the topic, how much oil would you guys suspect would actually be too much and cause harm? It's my understanding that too much oil can
- increase oil pressure
- cause air pockets (failed lubrication)
- froth up
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 09-20-2022, 10:57 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
starting to get into a guessing game.
i wouldn't worry about it unless it's frothy on the dipstick.
Old 09-21-2022, 02:39 AM   #17
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
- froth up
I believe you'd have to overfill by an entire quart to begin seeing those things happening.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Ultramaroon (09-21-2022), x808drifter (09-21-2022)
Old 09-21-2022, 04:31 AM   #18
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
And FIY Hole to hole on a dip stock is 1 quart for every car I've seen.
The Following User Says Thank You to x808drifter For This Useful Post:
Spektyr (09-21-2022)
Old 09-21-2022, 07:59 AM   #19
- froth up
You need a lot more oil than you have for that.
If you were so overfull that it causes an issue you would know by now.
Old 09-21-2022, 12:16 PM   #20
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Put your dipstick in, pull it out, and wipe it about 50-100 times.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following 6 Users Say Thank You to NARFALICIOUS For This Useful Post:
Dzmitry (09-22-2022), soundman98 (09-21-2022), Spektyr (09-22-2022), Ultramaroon (09-22-2022), VoltsFRS2013 (09-21-2022), Wally86 (09-28-2022)
Old 09-21-2022, 12:25 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pretty sure it is more than that, I know guys that intentionally run a quart high. There is the oil pan, the upper oil pan, and then the outside of the crank is about an inch above that.
Old 09-21-2022, 01:11 PM   #22
TommyW
TommyW's Avatar
Drives: '13 Whiteout
As long as the crankshaft isn't hitting the oil in the pan you're ok.
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
soundman98 (09-21-2022), x808drifter (09-22-2022)
Old 09-23-2022, 02:03 AM   #23
Clipdat
Proud of BOXER
Clipdat's Avatar
Why would you want to intentionally run a quart high?
I'm old and lazy
Old 09-23-2022, 03:11 AM   #24
Oil pools in the heads when cornering. Another quart is insurance against starvation.
Clipdat (09-24-2022), Tcoat (09-23-2022)
Old 09-23-2022, 07:21 AM   #25
x808drifter
LMGTFY
Drive like Takumi and that's not a problem.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
soundman98 (09-23-2022), Ultramaroon (09-23-2022)
Old 09-23-2022, 11:34 AM   #26
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
You'll be fine.
This is another good argument for a quick drain valve though. Slight overfill? Easy to drain a little without a full change.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Spektyr (09-23-2022)
Old 09-23-2022, 11:38 AM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oil starvation. I don't do this, I just know of others that swear by it.
Old 09-23-2022, 02:47 PM   #28
soundman98 (09-23-2022), spike021 (10-01-2022), x808drifter (09-24-2022)
Rookie in need of suggestions! Please help. Artxjr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-01-2019 03:51 PM
Subaru ROOKIE BRZParee2019 BRZ First-Gen (2012+) — General Topics 29 10-15-2018 11:40 AM
Spacers rookie mistake Impureclient Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-03-2016 01:55 PM
Help out a rookie? Outride Forced Induction 37 02-04-2015 01:04 PM
Adventures of a rookie in Autocross djfuller Tracking / Autocross / HPDE / Drifting 9 04-01-2013 09:30 PM
