Drives: 2013 Subaru brz limited
Wont go into gear
Installed new transmission and clutch itll go into gear with vehicle off but not with the vehicle on i have no leaks good resistance from the pressure plate and clutch pedal what are ways i can test theories
#2 |
Drives: 2018 BRZ
What's the clutch? ACT?
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Turdinator (09-29-2022) |
#3 |
Comp twin disc
#4 |
ProCrastinationConsultant
means something isn't set up right and the clutch isn't disengaging entirely.
| The Following User Says Thank You to soundman98 For This Useful Post: | x808drifter (09-20-2022) |
#5 |
Drives: 2013 frs base
Tried this?
#6 | |
Would i hear any grinding or chatter from the trans if i didnt set it properly? Im asking because i dont have any noise but i did the ole start in first gear with clutch applied but its as if the pressure plate is done or my adjustment could be off. I have a comp twin disk and tilton hydraulic release bearing everything is new. I forgot to note that this is a cd009 swap Sent from my iPhone using Tapatalk |
#7 |
You won't hear grinding on forward gears because you are bumping into the synchro rings. Grinding when attempting to put in reverse if your clutch is not disengaging.
#8 |
Drives: 2018 BRZ
As far as I know the Twins have a synchromesh reverse as well so would be no different than forward gears. Also, if you keep pushing the lever into a gear with the clutch not fully disengaged you'll grind regardless of synchros.
#9 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | x808drifter (09-21-2022) |
#10 |
Drives: None
Your release bearing probably isn't set up properly so you're not getting disengagement.
#11 | |
Yah i manage to get a video of the bearing in action i know the tilton is self adjusting but should it be riding like that in the picture im not sure if its constantly applying pressure or what but it wasnt this pressed in when I installed the bearing this is without the clutch applied i thought it was suppose to be just a hair off the pressure plate even still this shouldn’t be the problem ill still be able to go into gear ![]() Sent from my iPhone using Tapatalk |
#12 |
You mean just touching the fingers? Yes, that's how it works. Link the video.
#13 |
So I’m not sure how to post a video but I spoke with tilton they were really helpful had me run a few test to see if its the hydraulic bearing. Everything seems to work properly so they suggested that it could very well be the clutch if the trans is new and mechanically sound. Also mentioned that for swaps like these it could be hard to get the input shaft center of the pilot bearing when you have very little space to work with. Lots of times if not center it could push the pilot bearing out of its proper place. But could also be the pressure plate being bad, clutch disc not being installed correctly, etc so dropping the trans is my only option. Im a truck driver and have little ones so i just don’t have time to drop the transmission anymore so I contacted a transmission shop as soon as i told them it was a manual swap and wasn’t a stock transmission they declined the work. All i wanted them to do was drop the trans and inspect the clutch, and pilot bearing if the clutch needed to be replaced id send the clutch back and use my warranty since its new. If i cant a shop to do that simple job i might give up on this build and sell it for a type R at this point.
#14 | |
| FS Trd close ratio gear set 1-2, mfactory 6th gear | AxisPower | Transmission and Driveline | 11 | 08-17-2024 06:45 PM |
| Car wont go into 2nd gear at all. | airrick | Engine, Exhaust, Transmission | 4 | 04-29-2020 12:37 AM |
| Gear indicator not registering 5 th gear on 6mt | sroby | Engine, Exhaust, Transmission | 20 | 03-18-2020 11:43 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 06:28 PM |
| After Market Problem Signals Fuse Popped- Car Wont Go into Gear | ScionFR-S | Issues | Warranty | Recalls / TSB | 14 | 11-20-2012 02:34 PM |
