Old 09-19-2022, 10:23 PM   #1
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Rookie Mistake
Wanted to get a second or third opinion on a rookie mistake I made the other day leaving for a car show.
It appears I may have slightly overfilled my engines oil. I'm attaching a photo of a dipstick reading after letting idle to 200f then being shut down for 10 mins in my garage.
The red line is where the oil just about reads when the motor is completely cold in the morning. Checking my last oil bottle, I have about 0.5 to 0.6q left.
Am I paranoid or should I do another oil change? Brand new car, just dont want to have any issues. In my past two twins I never had them over the top line so I feel like a goof.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 09-19-2022, 10:38 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s fine. Don’t sweat it.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
22R (09-20-2022), humfrz (09-20-2022), pope (09-20-2022), soundman98 (09-19-2022), VoltsFRS2013 (09-19-2022)
Old 09-19-2022, 11:19 PM   #3
+1
humfrz (09-20-2022), VoltsFRS2013 (09-19-2022)
Old 09-19-2022, 11:53 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
there's a lot of oil that goes into the valves and filter up top that tends to drain down.
boxer motors also tend to burn more oil than straight or v-type motors due to the design. so it's also not terrible to have slightly more to compensate for nearing the end of the oils lifespan
Rustyoid (09-20-2022)
Old 09-20-2022, 12:19 AM   #5
STOP worrying about stuff like that.
Old 09-20-2022, 12:23 AM   #6
Sasquachulator
Pavement Grey
Doesnt that only apply if the piston rings or the head gaskets dont do its job properly?
Old 09-20-2022, 12:30 AM   #7
soundman98
soundman98's Avatar
you're thinking of the temporary sealing of piston rings, which is an old mechanics trick to check if rings are going bad.
what i'm talking about is the routine oil consumption of the motor. because the boxer motor cylinders are sideways, the oil tends to not drain down out of the cylinder bores as much as it would in an upright inline-cylinder, or v-style layout. that results in slightly increased oil consumption.
Old 09-20-2022, 12:50 AM   #8
VoltsFRS2013
given I don’t track my cars, occasionally spirited driving I never noticed any sort of oil consumption in my two FA20 twins prior to this. (havent really noticed any consumption on this car either)
Outside of the motor design itself, do you think that would have a fair bit to do with it? I should probably note that I change my oil very preventative. Like every 3,500 Miles.
Old 09-20-2022, 01:13 AM   #9
eyeballs
Drives: '22 BRZ
I would consider that a perfect oil level. I prefer a tad over vs under for any car that gets driven hard.
eyeballs is offline   Reply With Quote
The Following 2 Users Say Thank You to eyeballs For This Useful Post:
Rustyoid (09-20-2022), VoltsFRS2013 (09-20-2022)
Old 09-20-2022, 10:06 AM   #10
Spektyr
Drives: GR86
Unless you have bad seals you're not going to see oil consumption in 3500 miles significant enough to really measure.
I could be wrong, but I'd expect that if you can burn enough oil to notice the level drop in that short an interval you'd smell oil burning fairly regularly.
Spektyr is offline   Reply With Quote
The Following User Says Thank You to Spektyr For This Useful Post:
Old 09-20-2022, 02:06 PM   #11
If you do there will be a cloud of smoke for miles behind you!
Old 09-20-2022, 02:37 PM   #12
DarkSunrise
DarkSunrise's Avatar
Whoa found my garage twin lol. Nice mqb Tiguan SEL
Btw slight overfill like that is nothing to worry about. That’s the level I’ve got my BRZ at (and my FR-S for 10 years prior).
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 09-20-2022, 04:55 PM   #13
Spektyr
Drives: GR86
In my experience (grew up driving cars older than I was) there's a bit of distance between "doesn't burn oil" and "smoky exhaust" where you smell the oil burning but don't see it.
We had an old 1970 Ford LTD that you'd need to put a half quart of 10W40 in every month or so, but it never visibly smoked. Sure it looked like James Bond on cold mornings but that was more moisture than anything else.
I miss popping the hood on a car and then climbing in to sit on the fender with my legs in the engine bay while I worked.
Ultramaroon (09-20-2022)
Old 09-20-2022, 07:41 PM   #14
Yep a big old 8 could burn that much oil with almost no smoke.
I found that the smaller the displacement the less oil it takes to have visible smoke. My wife's first car was a $50 Datsun B210 that at about 1/2 a quart a month would leave a trail behind her that you could follow for 1/2 an hour.
I probably exaggerated a little but the boxer engine burning that much oil is going to have visible smoke.
I daily drove cars older or just slightly younger than me until about 1996.
This poor old girl had pretty much no rings left by 1981 so I know me some oil burning!
Ernest72 (09-30-2022), soundman98 (09-20-2022), Spektyr (09-21-2022)
Rookie in need of suggestions! Please help. Artxjr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-01-2019 03:51 PM
Subaru ROOKIE BRZParee2019 BRZ First-Gen (2012+) — General Topics 29 10-15-2018 11:40 AM
Spacers rookie mistake Impureclient Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-03-2016 01:55 PM
Help out a rookie? Outride Forced Induction 37 02-04-2015 01:04 PM
Adventures of a rookie in Autocross djfuller Tracking / Autocross / HPDE / Drifting 9 04-01-2013 09:30 PM
