Old 09-04-2022, 11:58 AM   #1275
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I would ask a tuner. Obviously the FA20 and other modern motors are in the 12+:1 on 91, but this is with direct injection. If you are ever considering boost then I would go lower, especially if you want or need to be on pump gas. E85 makes a huge difference, even with higher compression and boost. The Texas heat might make a difference too. It isn’t worth adding compression just to pull timing. I’m sure your tuner would know if a lot of timing needs to be pulled for a higher compression motor.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
funkjaw (09-06-2022)
Old 09-04-2022, 05:15 PM   #1276
ML
ML's Avatar
Drives: 13 White MT FR-S
My supercharger build is 9.5:1. Seems 11 or 10.5 maybe a good compromise setup between the boost and motor
The Following User Says Thank You to ML For This Useful Post:
Old 09-06-2022, 02:41 PM   #1277
RedReplicant
Drives: None
Cam choice is important with respect to fuel and static compression ratio. Agreed to talk to your tuner, hopefully they are a K person.
For what it is worth, the 09+ TSX is 11:1 stock, there are a lot of people that put those pistons (or the nippon racing equivalent) into the earlier motors. They are referred to as RL5.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
funkjaw (09-06-2022), Irace86.2.0 (09-06-2022)
Old 09-10-2022, 02:02 AM   #1278
Dresj442
Drives: Ft86
Having issues with my AIM but will check it out today
Dresj442 is offline   Reply With Quote
The Following User Says Thank You to Dresj442 For This Useful Post:
funkjaw (09-15-2022)
Old 09-19-2022, 12:42 PM   #1279
funkjaw
Drives: 16' WWB
Couple updates:
1. Raced my buddies FBO AP1 S2k last night (F20c). His car is a full track prepped time attack car (~2600lbs) and was tuned at the same place as my KRZ. We make very similar power; I have more torque, he has more revs (9k). All in all I pulled ahead a few car lengths by the end. This might be the first time in history a Gen 1 BRZ beat an S2k lol jk jk. (Sorry for the poor video quality, you can see his car on the left falling behind)
2. A/C line on the high side has always had a tiny leak, but it's gotten pretty bad lately. I emailed Kpower about it and they had no problem replacing the line - actually they just sent me the entire A/C package, new belt and all. So that was super cool of them. They were very responsive about the issue, and got the new A/C lines out the same day
funkjaw is offline   Reply With Quote
The Following 3 Users Say Thank You to funkjaw For This Useful Post:
Irace86.2.0 (09-19-2022), Jdmjunkie (09-19-2022), RedReplicant (09-19-2022)
Old 09-22-2022, 09:56 PM   #1280
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Interesting about the a/c line leak. I had a low side leak early on at the crimp and they replaced it. I still have a leak on the new one only it's a tiny amount at the valve. I've replaced the core multiple times without any positive effect. I may have to just get another new one at this point but waiting for the weather to cool off first.
captain awesome is offline   Reply With Quote
Old 09-23-2022, 01:39 AM   #1281
funkjaw
Drives: 16' WWB
Initially my A/C wasn't working very well at all. I had the honda tuner shop look at it and they found while the compressor was turning on as it should, it wasn't providing much suction (this was a "tested good" compressor I got from a used part seller on eBay)
So I just went ahead and replaced the used compressor with this new compressor:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The new compressor did the trick and the system worked pretty well for a few days but then the crimp on the high side line started leaking and got worse and worse over a few months. So a few days ago I replaced that line, gave it an evac/new charge (used 12oz of R134a) and it works flawless now, even better than when the used compressor was first swapped (I'm thinking there was some air in the system) - it now blows air at 35 degrees!
Old 09-23-2022, 08:32 AM   #1282
captain awesome
Wears Pants
I replaced the compressor as well after the first leak with a new GPD unit and a deslugger at the same time. It blows cold but not as good as I know it should. Whoever is doing their lines needs fired?
The Following User Says Thank You to captain awesome For This Useful Post:
funkjaw (09-23-2022)
Old 09-23-2022, 04:28 PM   #1283
captain awesome
Wears Pants
Oh, I also saw it mentioned on the FBook that the fuel gauge has been working with the recent NSP update. I updated the other evening and it's now way more accurate. Like doesn't just jump from full to half and then half to empty.
The Following 2 Users Say Thank You to captain awesome For This Useful Post:
funkjaw (09-23-2022), Irace86.2.0 (09-24-2022)
Old 09-23-2022, 04:35 PM   #1284
RedReplicant
Drives: None
Are you on the 3.7.0 or whatever? I noticed an improvement in an older version and almost screwed myself trusting it.
Apparently the stock cluster uses input from the ABS unit (wheel speeds) and a fuel injected cc count from the ECU to calculate an estimated distance to empty and this is what was missing before.
The Following User Says Thank You to RedReplicant For This Useful Post:
Old 09-23-2022, 04:46 PM   #1285
captain awesome
Wears Pants
I don't recall which version it updated to but it's the most recent one that was available. Today I had a quarter tank showing on the dash, and only 9 gallons to top off which is the first I've had happen before. I haven't checked the MPG AVG that used to read way off the charts so I'll check that on the drive home and see if it seems more reasonable now.
The Following 4 Users Say Thank You to captain awesome For This Useful Post:
funkjaw (09-23-2022), Irace86.2.0 (09-24-2022), Jdmjunkie (09-23-2022), RedReplicant (09-23-2022)
Old 09-24-2022, 08:46 AM   #1286
captain awesome
Wears Pants
Watched MPG average and MPG meter on the drive home. It’s accurate like factory now.
The Following 3 Users Say Thank You to captain awesome For This Useful Post:
funkjaw (09-24-2022), Jdmjunkie (09-24-2022), RedReplicant (09-26-2022)
Old 09-24-2022, 12:04 PM   #1287
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Question to those who took the car to a racetrack or a canyon road after the swap. Since the car has a better weight distribution with K24, did you notice any improvements in cornering?
Arthur-A is offline   Reply With Quote
The Following User Says Thank You to Arthur-A For This Useful Post:
Old 09-24-2022, 12:57 PM   #1288
funkjaw
Drives: 16' WWB
I regularly drive my car like a maniac on back roads and such and I can say it does handle better, but it's not so night and day like I was hoping. Probably because the baseline set originally is just so dang good.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
