Old 06-03-2021, 04:08 PM   #1
RayRay88
Drives: 2017 86 860 Special Edition
Ohlins with Extended Rear Top Hats
Does anyone have Ohlins (SUU MP22 or any with the 200mm 5k/5k springs) with the Raceseng 1" extended rear top mounts. I'm just having a tough time figuring out how to pre set the ride height before I install them on the car this weekend. The extended rear mounts move the reference for the height adjustment. No problem with preload.
I'm also still having a tough time trying to figure out why this setup would not be lower than using an OEM top mount. It seems the stack height is almost half of what and OEM top mount and spring perch would be.
If all else fails, I'll just wing it once it's on the car. Just didn't want to raise, adjust, lower and repeat so many times.
RayRay88 is offline   Reply With Quote
Old 06-03-2021, 08:00 PM   #2
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Have you read the install instructions? If you raise the top mount up 1 inch you will need to extend the ride hight 1 inch. The instructions state you have a +- 10mm adjustment or .39 inch. For ride hight. Looks like you are going to be over 1/2 inch to low. You can correct this with preload but then you just f upped all the engineering put into the shock.
Old 06-04-2021, 12:13 AM   #3
RayRay88
Thank you but yes I have read the instructions repeatedly to find a clue.
The top mount extends the travel of the shock, but the way its designed the total stack length seems shorter. I have the spring preloaded correctly with 20mm (180mm spring length installed), but due to the different top mount the the entire spring assembly and lock collars has moved up an unknown amount (I don't have an oem top mount to compare upper perch positions). So now the reference for the height adjuster is no longer valid. I can't get close to the target 25mm that Ohlins recommends. The adjuster bottoms out on the shock and i'm still about 30-40mm away from the target.
This would have been a lot easier if Ohlins gave us assembled full shock length reference numbers.
Looks like i'll just be eyeballing it for now and then adjusting once they're on the car.
Old 06-04-2021, 08:02 PM   #4
Grady
Grady's Avatar
I have the MP21 with 5k springs the adjustments are exactly the same as the MP22. If you look at the MP20 installlation it does give a total length of 381.5mm. That should be close to ours. The preload with the space to the lower mount on ours is 205mm, it is listed as 219 on the MP20. If everything else on the kits are the same except the spring and valving that would give a little more safe adjustment. On a side note not sure gaining an extra inch of compression will help any. My car will drag ass already without bottoming out the strut.
Old 06-05-2021, 03:21 AM   #5
RayRay88
I had found that reference a few weeks back too and locked in the settings. I was just curious if anyone else had come across this before I throw them on today . Can never be too sure since that kit comes with the softer rear spring, and ours are stiffer. I'll know where I stand once I start measuring and swapping.
Tons of people, including RCE have mentioned the rear compression stroke is a bit of a weak point for these dampers, I was getting the front tops anyways, it's an easy thing to throw them on from the get go. Especially since I'll be running 200tw tires.
Old 06-05-2021, 08:29 AM   #6
Grady
Grady's Avatar
Let me know how it goes. Probably agree with the rear dampening, but all in all I like the ride and performance of these. I will have to say I have switched from 4s to cup 2 tires and probably passing the limit of the 5k springs. Probably will need to upgrade to 6k to 7k springs at some point.
Old 09-19-2022, 09:20 AM   #7
RacingredGR86
RacingredGR86's Avatar
Drives: 2022 GR86
Reviving this thread as I'm interested in the Ohlins R&T for my build. @Grady - did you ever switch out to stiffer springs (6/7k)? If so, did you also have the Ohlins revalved? Curious to see if the Ohlins were able to meet your needs.
RacingredGR86 is offline   Reply With Quote
Old 09-21-2022, 08:28 AM   #8
Grady
Grady's Avatar
I have not yet. Been working on another car project.
WTB: Rear top hats CrispyCheddar Want-To-Buy Requests 0 04-03-2016 11:36 AM
KWV3 with Ohlins Top Hats 86Tony Brakes, Suspension, Chassis 0 01-16-2016 10:30 PM
WTB: OEM Rear Top Mounts / Top Hats KVDB31 Want-To-Buy Requests 0 07-29-2015 12:56 PM
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder MyRx Brakes, Suspension, Chassis 5 10-12-2014 02:14 PM
