Old 07-07-2022, 02:10 PM   #5811
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by FRScott View Post
Hey all. Just installed my C38 kit with the CARB tune and after a week of obsessively ensuring that everything is running well, it seems like everything is running as it should.
I do have a question regarding how the tune works with a stock MAP sensor vs. a higher resolution MAP sensor like a 3 bar unit. I know that there are people who have installed the kit with an aftermarket MAP unit and were able to see higher boost. If I installed a higher pressure MAP unit, will the CARB tune adjust for the higher boost or will I need to retune?
If you install a 3 or 4 BAR MAP sensor with the CARB Calibration, the car will not run properly. MAP sensors also do not change the boost level, only a pulley will do that.
JDMChris is offline   Reply With Quote
Old 07-07-2022, 07:21 PM   #5812
tomm.brz
Drives: brz 2017 hksv2
you can't change it without modify the tune, it won't even crank and start
You ll see the higher boost, but mostly no difference in performance, you can save the money for it
Also because i don't think you get to modify the CARB tune, you d have to keep it as it is, and it needs the oem map sensor
Old 07-11-2022, 06:13 PM   #5813
CSG Mike
CSG Mike's Avatar
The CARB kit is designed around an otherwise stock engine.
Do not change your MAP sensor. It will not work with the CARB tune, which is designed for the stock MAP sensor.
CSG Mike is online now   Reply With Quote
Old 07-22-2022, 04:42 PM   #5814
FRScott
Drives: 2015 Firestorm Red Scion FR-S
Now I appear to be running into an issue. I haven't driven my twin in about a week where last time she was running great. I took her out for a spin today and I'm noticing that acceleration is sluggish and I'm getting a more pronounced supercharger whine. By sluggish, I mean that acceleration is nearly back to stock.
In response, I checked the running temps, traction fluid level (at running temp), belt alignment, and the intake to the compressor wheel. I'm not seeing anything new or any issues in general.
Before I start diving deeper and taking things apart, I'd like to reflect on peoples experience here regarding which directions to look for in this particular system to find the root cause. I'm holding out that it's not the unit itself, but after removing the intake to the compressor wheel and running at temp, it sounds like it's coming from inside the compressor.
The next minimal step I might take is to remove the belt, rotate the compressor pulley and listen for noise/feel for added resistance. If I don't notice anything new, I'll run it again with the belt reinstalled and aligned again to see if the mechancal equivalent of the "turn it off, and then turn it on again" works.
FRScott is offline   Reply With Quote
Old 07-23-2022, 12:14 PM   #5815
FRScott
Update: I'm 100% sure the rotrex unit is screwed. I get variable resistance when I try to spin it CCW. At some points the rotation feels normal, and other points I can barely rotate it by hand.
My main concern is what caused failure. I can't conclude yet whether or not it's something like a manufacturing defect, pulley misalignment (doubtful as I was careful to ensure that wasn't the case with the assistance of measuring tools),or some other reason. Again I'll ask, are there any other pitfalls in the system I can look for to ensure this doesn't happen again?
In the meantime, I'll be contacting JR for a replacement.
Old 07-26-2022, 09:16 PM   #5816
FRScott
Update: Looking at the total install with the bumper off, I noticed that one of the couplers off the intercooler had slipped off. All of the symptoms make sense now considering that it was a boost leak. At the very least, this is a note to other owners to be mindful of.
Old 07-27-2022, 02:15 AM   #5817
CSG Mike
CSG Mike's Avatar
How old is your supercharger?
Old 08-02-2022, 11:09 PM   #5818
Badaspanda
Drives: FRS
Hey there any of your guys were able to install the kit with a mishimoto oil cooler? Or can you redirect me to any other post that might have the answer. Thanks guys
Badaspanda is offline   Reply With Quote
Old 09-14-2022, 07:39 AM   #5819
HaXx
Drives: jrsc_brz
Looking for input
My supercharger has been extraordinarily loud lately. The whine is extremely audible and it hasn't always been like this. I changed its air filter & topped iits oil earlier this season. Daily driver only. Prob has around 50,000 miles on the compressor.
The whine is directly correlated to rpm, so as I accelerate the whine increases intensity.
It's not a BAD sound, it sounds dope to be honest, now it's clearly audible that my cars boosted but I started it up this morning and it simply sounds like the belt is meeting resistance in the compressor.
Is this increased sound a bad omen?
I guess I should see how much effort it takes to turn the turbine by hand? Not sure how to do this, take the belt off and unclamp a hose?
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 09-14-2022, 10:17 PM   #5820
CSG Mike
CSG Mike's Avatar
Originally Posted by HaXx View Post
Looking for input
Exactly that. If it's crunchy, you need a new Rotrex unit. Keep the Rotrex fluid lines on for this.
Old 09-25-2022, 04:35 PM   #5821
hachi roku [86]
Drives: Toyota GT86, Mazda MX-5 NB
Originally Posted by CounterSpace Garage View Post
Can ship anytime. Make sure you check the alignment of your belt and pulleys. We've put on years and thousands of miles of tracking without tearing up a belt.
Would you have any recommendation on how?
Visually, it seems my SC pulley needs to go in about 0.5-1 mm towards the engine block in relation to other pulleys. So, I was thinking of filing down the three mounting studs by equal amount. Would this work?
hachi roku [86] is offline   Reply With Quote
Old 09-27-2022, 02:07 PM   #5822
JDMChris
Drives: 2016
Something is installed incorrectly or impeding proper installation. remove it and re-install.
Old 11-29-2022, 10:53 AM   #5823
arxm
Drives: 2013 FR-S, 2023 BRZ
i understand what im about to ask may be an unintelligent question and seeing as I havent come across much info on the internet, it likely is but hear me out.
Has anyone run an electronic boost controller on a centrifugal supercharger, my logic behind it is boost by gear. I know it doesnt make sense on the stock 7 or 9 psi pulley but with something like a RS pulley (assume built engine and supporting mods for this caliber of build) and an EBC you could bleed off boost in 1st, 5th and 6th gears and go for all the juice in 2nd-4th or adjust to your liking. I understand why people use an EBC in turbo cars and why superchargers dont have boost controllers but im thinking a little out of the box here, it could allow for quite some flexibility if someone wants to run high boost with no turbo lag but not always have all the boost available the way a SC gives it.....am I crazy?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 11-29-2022, 11:35 AM   #5824
PulsarBeeerz
Drives: JRSC BRZ SOLD
There is no wastegate to control on a SC setup, so you couldn’t add one if you wanted as far as I know. The Rotex compressor power delivery is about the smoothest you’ll find in FI, so it’s a bit like addressing a problem that doesn’t exist. Probably easier to leave traction control on. Lol
PulsarBeeerz is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
