| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#19573 |
Weight Weenie
Drives: 15 FR-S
I predict you will be bleeding from many locations before finishing this...The harness is ridiculous. I've been slowly reducing the size of mine but will be removing everything I don't need from a spare harness at some point and installing it. I took the HVAC box right out for easier access. Don't know if you're keeping that.
#19574 | |
Drives: 2013 Subaru BRZ
Umm, HVAC? not sure what box that one is? Are you referring to the VDC module? Either way, I'm not removing any boxes, if anything, the only box I will mess with is the VDC control module, which is in the engine bay. Because I am replacing the hard steel brake lines with the Chase Bay's dual caliper booster delete kit, which comes with its own lines, I will most likely relocate the VDC module box into my cabin somewhere? Not sure where, but maybe up in the dash area?
#19575 |
30 minute maintenance
Drives: My18 wrxsti
| The Following 2 Users Say Thank You to gen3v8 For This Useful Post: | Ace23_BRZ (09-09-2022), new2subaru (09-09-2022) |
#19576 | |
Las Vegas weather sucks and the last thing I need is no A/C in the summer or heat in the winter lmao. I will make custom A/C lines at a later date though, probably see if I can make those lines match my engine bay color theme, which is still under consideration...the color scheme that is.
| The Following User Says Thank You to Ace23_BRZ For This Useful Post: | new2subaru (09-09-2022) |
#19577 | |
Drives: My18 wrxsti
| The Following User Says Thank You to gen3v8 For This Useful Post: | Ace23_BRZ (09-12-2022) |
#19578 |
Installed my DSS LV4 800HP axles today
LoL, I saw some other people install axles and I'm gonna be honest, these bitches were not that easy to come out
![]() The second pic is a side-by-side OEM axle vs DSS LV4 axle...OEM looks like a twig LoL. I got them installed but ended up with 2 casualties in the process.
#19579 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#19580 |
Drives: 2013 frs base
First, you brought a claw hammer to a car fight. Second, those prybars are ok for pulling nails but not rigid enough to get axles to pop out. I used a pickle fork and mine popped right out.
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
#19581 | |
Ha, but one way or the other, them twig axles were coming out ![]() LOL! Now I can get back to my harness nest
| The Following User Says Thank You to Ace23_BRZ For This Useful Post: | blsfrs (09-14-2022) |
#19582 |
Drives: 17 BRZ
![]() Tail of Dragon with friends |
| The Following 5 Users Say Thank You to Espi For This Useful Post: | bcj (09-25-2022), Dirty Harry (10-02-2022), JD001 (09-19-2022), juenedgi (09-22-2022), weederr33 (09-22-2022) |
#19583 |
Drives: BRZ ts
Went to pick up my car that’s been in the shop after a student did a hit and run on it. Went something like this this rainy morning:
“Hello, unfortunately we left the windows down in your car and it’s filled with water. We sent it out to be detailed. Very sorry.” |
| The Following User Says Thank You to dpfarr For This Useful Post: | soundman98 (09-21-2022) |
#19584 |
That's going to take more than a detail...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | soundman98 (09-21-2022) |
#19585 |
ProCrastinationConsultant
i would make sure that's well documented... there's a lot of wiring on the floorboards...
#19586 |
Drives: BRZ ts
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
