Old 09-07-2022, 02:36 AM   #15
Nanofuzer
Nanofuzer's Avatar
Drives: Orange 2015 Scion FRS M/T
yep. prevailing theory seems to be them including a sloppy alignment tool that doesn't really align it properly. a few people swear they haven't had any issues once they reset with the OS Gilken billet alignment tool .
so will a new alignment tool kinda fix that problem then or do i need more than that?
Nanofuzer is offline   Reply With Quote
Old 09-07-2022, 03:53 AM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Supposedly using the billet os gilken alignment tool fixes all issues.
Many would rather solve by buying something other than an act clutch
Simply put, act's seem to have consistent issues on the forums here. Maybe the installers are bigger forum complainers, maybe the installers are horrible monkey wrenches, maybe there's actually an issue with act clutches, or maybe their alignment tool really is that bad.
I don't really think there's enough info in any direction to draw any definitive conclusion.
What I do know is that there's plenty of other clutch brands that don't seem to have the same issues, and I don't like taking my car apart on the garage floor more than is needed.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Ultramaroon (09-07-2022), x808drifter (09-07-2022)
Old 09-07-2022, 01:39 PM   #17
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by Nanofuzer View Post
did not remove any hoses when i pulled the trans. i just removed the slave cylinder off and set it to the side.
A couple of other things come to mind.
Have you adjusted the clutch. If you have a lot of free play before the clutch disengages, lengthen the rod under the dash. You still might need to bleed the system.
Did you properly install and adjust the shifter so that gears can fully engage.
Old 09-08-2022, 01:59 AM   #18
Nanofuzer
Nanofuzer's Avatar
i believe i installed the shifter properly, had to play around with it a little bit so it'll go in gear smoothly when i put it back together. what what do you mean by lengthen the rod under the dash, i'm not sure what you mean by this.
Old 09-08-2022, 09:49 AM   #19
blsfrs
blsfrs's Avatar
Recheck your shifter alignment. If it's popping out of gear, it's not going all the way into gear.
The Following User Says Thank You to blsfrs For This Useful Post:
Nanofuzer (09-12-2022)
Old 09-09-2022, 01:27 PM   #20
Nanofuzer
Nanofuzer's Avatar
-UPDATE- dropped transmission and this is what i came to find.
The Following User Says Thank You to Nanofuzer For This Useful Post:
blsfrs (09-10-2022)
Old 09-09-2022, 01:42 PM   #21
WNDSRFR
Drives: FR-S,GTI
WTF?
How did that happen?
Old 09-09-2022, 01:43 PM   #22
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
There's yer problem.
Old 09-09-2022, 02:04 PM   #23
I've seen worse for sale on the member classifieds.
NoHaveMSG (09-09-2022), soundman98 (09-09-2022), Spuds (09-09-2022)
Old 09-09-2022, 03:22 PM   #24
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, I know where not to get a clutch now...
Old 09-09-2022, 05:14 PM   #25
Originally Posted by WNDSRFR View Post
WTF?
That is pretty much what mine looked like when my TOB had it's meltdown.
Old 09-09-2022, 07:07 PM   #26
WNDSRFR
Drives: FR-S,GTI
Wow
Really?
I've had two TOB's bite the dust but never had any damage to my clutch disk.
In fact, I wish I kept the first clutch, it was pristine. The second time I just left the clutch there. It was fine.
Now I guess it's gonna fail tomorrow.
Old 09-09-2022, 08:42 PM   #27
Wow
Really?
I ignored it too long and it literally melted, went off center and blew the whole works apart.
Was my own bloody fault for not taking care of it when I knew what the issue was.
Unfortunately I don't have a picture of the clutch plate but it was only slightly better than that one.
Old 09-09-2022, 08:58 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have seen worse friction welds then that on parts that were supposed to be friction welded
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-09-2022), Tcoat (09-09-2022)
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
VOTE: Your Transmission 6MT? Butter smooth? -or- Problems? hmong337 Engine, Exhaust, Transmission 111 07-27-2016 10:59 PM
Transmission problems M&W_FRS Issues | Warranty | Recalls / TSB 9 11-23-2014 11:29 PM
Transmission problems ofuts Issues | Warranty | Recalls / TSB 24 10-23-2014 12:44 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
