Old 08-28-2022, 11:34 AM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
One ugga dugga
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Wally86 (08-29-2022), x808drifter (08-28-2022)
Old 08-29-2022, 05:38 AM   #16
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by Mike_ZN6 View Post
Do you have the torque specs for the bolts? I just got mine and want to install them in my first gen.
12ftlb (16nm) allegedly from a quick search around here.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Mike_ZN6 (08-29-2022)
Old 08-29-2022, 08:06 AM   #17
KillerBMotorsport
KillerBMotorsport's Avatar
One ugga dugga
Definitely no ugga duggas
^ this right here is correct for those 8mm nuts and bolts.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
Mike_ZN6 (08-29-2022), soundman98 (08-29-2022)
Old 08-30-2022, 02:06 PM   #18
Spektyr
Drives: GR86
I always just torque it down until the head twists off, then spend an hour getting the bolt out, find a replacement, and then realize I've lost the sense memory of how force I applied that was too much, try to remember where I put my torque wrench...
Probably don't do it that way, though.
Spektyr is offline   Reply With Quote
The Following User Says Thank You to Spektyr For This Useful Post:
soundman98 (08-31-2022)
Old 08-30-2022, 04:15 PM   #19
KillerBMotorsport
Not recommended since the 6 studs (3 studs and 1 bolt on each side) are all bonded to the chassis. Breaking one of those off would be a horrible ordeal.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Old 08-31-2022, 09:10 AM   #20
Spektyr
Drives: GR86
Yeah, learned to never ugga dugga nuts - only bolts (and even then, that's a dumb idea). Naturally I learned that the hard way: water pump on a 2.8L Fiero GT. The number of bolts you can sheer off at the block and still get it tight enough not to leak is zero.
Old 09-13-2022, 06:59 PM   #21
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I want to put a set on my 1st gen but I'm not sure if it will clear my STI strut bar. Will try to find time to do a test fit soon if no one else does.
- Andrew
It clears the STI strut bar, just tried it tonight.
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
KillerBMotorsport (09-14-2022), Racecomp Engineering (09-13-2022)
Old 09-13-2022, 10:20 PM   #22
Heck yeah! Post a pic!
- Andrew
Old 09-14-2022, 06:50 AM   #23
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
- Andrew
I have a 2020 so I've got a different issue on why the bar isn't on right now. I'll post a pic.... tomorrow afternoon after some stuff gets here
Racecomp Engineering (09-14-2022)
Old 09-14-2022, 09:53 AM   #24
OkieSnuffBox
Drives: '23 BRZ Limited
I'm confused. You're posting about the fit of part for the previous gen in the section about the 2nd gen? Or do you also have a '22+?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 09-14-2022, 10:00 AM   #25
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Two different fitment questions and answers.
Does it fit under the STI strut bar? Yes. 100%.
Do the nuts for the mounts fit on the inner bolts for my 2020? No, due to some slight tapering on the mounts. I've ordered some new smaller flanged nuts to test fit the bars on so I'll be trying that when they get here tomorrow.
EDIT: Yes, I'm trying to fit this on my 2020, not a second gen.
soundman98 (09-15-2022)
Old 09-14-2022, 10:02 AM   #26
OkieSnuffBox
Gotcha. But still confused why you are posting a Gen 1 fit answer in the Gen 2 section.
Old 09-14-2022, 10:06 AM   #27
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Maybe I'm lost.
(I'm definitely lost)
OkieSnuffBox (09-14-2022)
Old 09-14-2022, 10:07 AM   #28
OkieSnuffBox
Maybe I'm lost.
Although to be fair, with everything else. I suspect the fit for stuff like this is going to be exactly the same between Gen 1/2.
Strut Bar Testing KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 5 08-30-2022 04:12 PM
WTB Cusco Strut Tower Brace and/or Strut Bars nwgabrz Want-To-Buy Requests 0 12-09-2019 10:19 PM
Strut Bar Review: AEM Strut Bar Thoughts and Experiences wu_dot_com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-08-2019 04:33 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
