Old 03-16-2022, 07:28 AM   #701
Originally Posted by Sasquachulator View Post
I think it was only the power bump (+5hp) and the gearing that was different with the 2017+ manuals.
Every other change/tweak (suspension, materials, engine nvh, etc) was across the lineup as far as i know.
Yep
The intake, header and final drive changes applied only to the MTs. All other changes were done on both ATs and MTS. The MTs also got a bump in strength.
There was also a few regional differences (i.e. battery charging for North America only) but generally all changes applied.
Having had both a 2014 and a 2020 I can safely say that although the power "bump" is probably lost in the averages of weather/driving conditions that final drive change made a noticeable difference in initial acceleration and feel. If, for some bizarre reason I had to get a pre facelift car the final drive swap would be a must for me. Opinions may vary.
Dadhawk (03-16-2022), soundman98 (03-17-2022)
Old 03-16-2022, 09:55 AM   #702
reeves
Originally Posted by Adam_L View Post
The improvements were to the manual only (not sure if you knew that).
Yea I know.. And I only drive manuals so the auto is of no interest to me
And even if there were no engine/suspension improvements, I'd still only get the '17+ for the throw out bearing fix for those years.
Old 03-17-2022, 02:53 PM   #703
No sense throwing good money after bad.
bcj (03-17-2022)
Old 03-17-2022, 10:02 PM   #704
alone1i
Not pro yet
Drives: 2020 Toyota GT86
How about the topic of reliability? Too early to say?
alone1i is offline   Reply With Quote
Old 03-17-2022, 11:15 PM   #705
soundman98
ProCrastinationConsultant
soundman98's Avatar
it's a toyota. ish.
that's like the literal definition of the brand.
alone1i (03-18-2022)
Old 03-19-2022, 03:18 AM   #706
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
*Who could ask for anything more ?! *
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 03-22-2022, 12:26 PM   #707
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
none
iLuveKetchup is offline   Reply With Quote
The Following User Says Thank You to iLuveKetchup For This Useful Post:
dsc_pat (03-22-2022)
Old 03-22-2022, 12:38 PM   #708
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
Yeah, you can get one!
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
The Following User Says Thank You to Ghost of Akina For This Useful Post:
Tcoat (03-22-2022)
Old 03-26-2022, 06:58 PM   #709
BRZ-G1
Drives: 2022 BRZ
Honestly, have not read the whole thread. But to answer your question, absolutely yes! Same car, much stronger engine that fills the void the earlier gen had.
I had driven gen1 multiple times, and I thought it was an amazing handling car, but neutered. The new gen has an engine that really matches the car’s chassis. At the track, it is a peach, it does pull. I’m not a pro at the track, I do track both my gt3 and new BRZ, I love BRZ. It is as fun as the gt3 if not more, as I can push it harder. At my driving level, the power is more than adequate. Earlier gen… I felt needed pushing.
BRZ-G1 is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZ-G1 For This Useful Post:
alone1i (03-30-2022), DylanJZA (08-28-2022), Vr4gasmtt (03-26-2022)
Old 08-27-2022, 07:11 AM   #710
Samba86
Samba86's Avatar
Drives: 86 GTS
NecroThread alert :P This guy owns both gen 1 & gen 2 and has some interesting analysis:
Samba86 is offline   Reply With Quote
Old 08-27-2022, 09:29 AM   #711
Ohio Enthusiast
Drives: 2018 BRZ
TL;DW - comparing a base 2013 FRS (that he owned for 9 years) to a base 2022 GR86:
  • Steering feel is worse in the new gen, goes as far as "substantially worse"
  • New gen is much quieter
  • Shifting is improved in the new gen, especially cross shifting (but he does appear to have a heavy shift knob on his FRS)
  • Clutch pedal feel is worse (but he still has the assist spring in the new gen while removed it in his FRS)
  • Throttle slower to respond, says needs more gas to take off
  • The FRS feels more raw, "90's sports car vibes"
  • Much better fit and finish in the new gen
  • AC is much better in new gen (he's in Vegas)
He goes into some more detail on the steering feel around the 12:05 mark, saying "[old] steering is way heavier and gives you more feedback, more precise and doesn't have this kind of strange numbness and laziness right around center like the new generation does".
I'm not sure about feedback, but I felt that numbness/laziness on center as well when I test drove a 2022 BRZ.
The FRS is lightly modded, with header, exhaust, tune and wider wheels and tires (245 MPS4S).
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Samba86 (08-27-2022)
Old 08-27-2022, 10:09 AM   #712
My first thought on this was "It's a 9 year old car have you bothered to have the A/C serviced?"
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
Ohio Enthusiast (08-27-2022), Pedro13 (08-29-2022), soundman98 (08-27-2022), Teseo (08-29-2022)
Old 08-27-2022, 10:37 AM   #713
Ohio Enthusiast
Drives: 2018 BRZ
Same. I think quite a lot of the comparisons by long time owners of the 1st gen are somewhat flawed, in both directions - they compare a car they are very familiar with and very used to, but is also old and probably has quite a bit of wear (especially of the gradual wear items like shocks and bushings). This is akin to comparing worn tires to brand new ones. It will certainly be different, but a single point of time comparison probably isn't all that representative.
I think the ideal comparison would be between a stock low milage 2020 and 2022/3 by a good track driver who didn't recently own a Twin (or even never owned a Twin). I vote for Throttle House (Thomas being a good track driver who's into BMWs, and seems to be able to adjust his reviewing very well to the kind of car he is driving).
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Dadhawk (08-27-2022), JusTheG (08-27-2022), soundman98 (08-27-2022), Tcoat (08-27-2022)
Old 08-27-2022, 10:53 AM   #714
This has been a concern of mine all along. There were many many incremental improvements from the first release in 2012. Things like fit and finish can not be based solely on the first run of the FRS. To start with they were deliberately a base car to hit price point. Even comparing a base FRS to a post 17 86 can show a vast improvement in such things yet since there are so many more 13s it is what is used most often. Wear and tear and mods also have to come into play.
Things like steering and clutch “feel” are subjective to individual taste. There can also be a heavy bias to what is familiar. I highly doubt that one is “better” than the other in the long run.
I know that my 2020 86 has a totally different feel in almost all aspects to my 100,000+ mile FRS.
As far as the improvements to the GR that people rant about it had bloody well be better than a 10 year old car!
bcj (08-27-2022), Dadhawk (08-27-2022), DarkSunrise (08-29-2022), JusTheG (08-27-2022), soundman98 (08-27-2022), Wrecky_Flowers_ (08-27-2022)
Another good reason to drive an AT Hotrodheart Scion FR-S / Toyota 86 GT86 General Forum 31 07-13-2016 01:00 AM
A Good Reason to Stay With Narrow 17s FlamingRectumSyndrome Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 04-30-2014 04:18 PM
FA20CLUB: GOOD REASON TO REMOVE YOUR TURBO KIT RIGHT AWAY.... FA20Club.com Forced Induction 27 06-21-2013 11:19 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 12:52 PM
