#3669 |
That engine sitting in your driveway reminds me of the time, back in CT, when I was mowing an area of lawn between me and the neighbor's property that hadn't been mowed before.
I found out why. My almost new Toro lawn mower hit a piece of diamond plate metal and guess what - the diamond plate won! Since the engine wouldn't turn over, I took it apart, cleaned up the parts and took it into a Toro dealer to find out what parts I needed. After making the determination that I needed a new crank and a couple of valves, the cost came to almost as much as a new mower. So, I bought a new mower and learned I could have saved all that time by doing that in the first place -
| The Following 5 Users Say Thank You to humfrz For This Useful Post: | ScoobsMcGee (08-24-2022), soundman98 (08-24-2022), Spuds (08-24-2022), Tcoat (08-24-2022), Ultramaroon (08-24-2022) |
#3670 | |
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (08-24-2022), NoHaveMSG (08-24-2022), ScoobsMcGee (08-24-2022), soundman98 (08-24-2022), Spuds (08-24-2022) |
#3671 |
That brings to mind another story about mowing in that rough area along side my lawn in CT. So, I inspect the area for any metal foreign objects then fired up my new Tory mower.
As I mowed over this large hole in the ground, I heard a very loud humming/buzzing sound. That is when TIL about ground bees. They swarmed out of that hole, maybe thinking that mower sound was a bunch of wasps attacking - ![]() What I do know is that the swarm could fly as quick as I could run (dressed in shorts and no shirt). I made it to the garage and slammed the door closed. Not to lose my new mower to a swarm of ground bees, I mixed up a concoction of a half gallon of premixed 2 cycle engine gas and two large glugs from a jug of methyl parathion. I then divebombed the bees home base and hit the hole with the whole load. On the next pass I tossed in a cigarette lighter. - ![]() BOOM! - no more bees! THE END (yes, it's a slow day on Puyallup - )
| The Following 8 Users Say Thank You to humfrz For This Useful Post: | bcj (08-24-2022), Capt Spaulding (08-25-2022), NoHaveMSG (08-24-2022), ScoobsMcGee (08-24-2022), soundman98 (08-24-2022), Spuds (08-24-2022), Tcoat (08-24-2022), Ultramaroon (08-24-2022) |
#3672 | |
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | bcj (08-24-2022), humfrz (08-24-2022), NoHaveMSG (08-24-2022), ScoobsMcGee (08-24-2022), soundman98 (08-24-2022), Ultramaroon (08-24-2022) |
#3673 | |
ProCrastinationConsultant
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#3674 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
I’d make a small cap out of aluminum window screen and put it over one end of the pole. I’d go around to the other end with a propane torch and a can of spray contact cleaner. Shot through the torch flame the contact cleaner created an afterburning jet engine out of the pole. Bad day to be a wasp.
Slow is smooth, and smooth is fast
| The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post: |
#3675 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
#3676 |
While true, there's no better satisfaction than smelling those fuckers burn.
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#3677 | |
Persona Non Grata
It wasn’t just about killing them.
| The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post: | soundman98 (08-25-2022), Ultramaroon (08-25-2022) |
#3678 | |
Reminds me of another "adventure" as a young boy back on the farm. When it came time to paint the large, main barn, I was the one that was put on the top of a rickety, old, wooden, double ladder, extended way past the recommended extension. Why me? Because I was light and wouldn't break the ladder. Now, waay up in the gables of the barn were several wasps nests. My grandfather would give me a tin cup of gasoline and instruct me to climb up the ladder and throw the gasoline on the wasps nests. Sure enough, when that gas hit the wasps, they would instantly drop like lead shot. However, every now and then a wasp would be out of town and not get the memo. So, I had in my pocket a squirt gun filled with gasoline to shoot it down with. - ![]() Yep, it was 90 degrees with 95% humidity and I was hanging on a fully extended wooden ladder, with one hand, onto a rung that was wound up with baling wire because it was split and it would rotate because it was wore out. My other hand was holding a paint brush. Here comes a totally pissed off wasp. So I had to juggle the paint brush and reach for my squirt gun, fire and hope I hit the wasp before it hit me - THE END |
| The Following 6 Users Say Thank You to humfrz For This Useful Post: | bcj (08-26-2022), Capt Spaulding (08-25-2022), Dadhawk (08-25-2022), soundman98 (08-25-2022), Spuds (08-25-2022), Ultramaroon (08-25-2022) |
#3679 |
Drives: Crapcan
I just got stung yesterday so I am all about the scorched earth policy.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#3680 | ||
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | Capt Spaulding (08-25-2022), humfrz (08-25-2022), NoHaveMSG (08-25-2022), soundman98 (08-25-2022), Spuds (08-25-2022) |
#3681 |
#3682 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | NoHaveMSG (08-25-2022), soundman98 (08-25-2022) |
| Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
| OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
