Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-20-2022, 12:04 AM   #1
mycrors7
mycrors7's Avatar
Drives: zd8 brz
DIY/Review: GJP Designs IPS Gauge for 2nd gen BRZ/GR86
Hey guys, GJP Designs, who created the TracBox and IPS Gauge for the 1st gen is working on a 2nd gen IPS Gauge and I have the honor of helping him with pre-production testing(alongside a handful of others)
First off I want to say that this product was given to me at no cost and in return I will helping GJP Designs with troubleshooting/testing. Regardless, I will be giving my 100% unbiased and honest review of this “smart gauge”
I have some experience with the P3 gauge on other platforms(vw, bmw) but I don’t have experience with the P3 Gauge on the twin platform… It’s fairly safe to assume it’s very similar to how it works with the VW and BMW platforms ive used it with, so that will be my main point of comparison.
To start off, this gauge costs a faction of what the P3 Gauge costs yet feels very similar in how it functions/operates. The IPS Gauge has a 3D Printed housing that is pressure fit into the OEM driver side vent. This allows for minor adjustment to ensure the screen and angle are optimal for the driver. It also essentially eliminates the possibility of any vibrations.
The IPS Gauge comes with its own wiring harness that goes directly into your OBD2 port. At the time of this review, it does not support aftermarket sensors for boost and oil pressure. Those features are in the works, but as with everything, it requires time. This gauge’s firmware can also be updated via a Micro USB (old android connector).
It has all your common menu options that you should expect. It also has BRZ/GR86 specific options such as turning on/off the Active Sound.
As of right now, pretty much every option works as intended. My Active Sound feature shows an error because the module was unplugged (more on this later).
Link to product and more info regarding it's features and functions:
https://www.geraldjustprojects.com/p...gr86-brz-2022/
Let’s get into this DIY:
Difficulty 2.5/10
Total Time required:
Newbie(never done anything past check your own fluids): 1 hour
Hobbyist(performs common automotive tasks and modifications): 30 mins
Professional(lives the auto industry hell on a daily basis): 12 mins
Tools required:
Trim removal tool (Flathead and a microfiber works too)
#2 Phillips
Straight long pick or a very small flathead(maybe even a toothpick? lol)
Zip Ties
Step 1: Open your box and look at your IPS Gauge. You should have the Gauge itself, the OBD2 connector, and an adapter to go from the OBD2 to the gauge itself
Step 2: Go to your car, open the driver side door and pull the side panel off with your trim removal tool. Put the tool where the arrow is pointed and it should pop one clip off and give you enough space to get your fingers behind the cover and pop it out. I’ve included a picture of the back of the cover, to show you where every clip is. The panel pops out very easily
Step 3: Take your Phillips screwdriver and remove the screw under that panel, circled in red. Once that screw is removed, take grab the entire lower section from the front and pull it toward the back of the car and slightly downward. Give it a decent yank and it’ll pop most of the clips off. Work the rest out and you can either let the panel hang down to undo the 2 connectors and put the panel aside. I’ve included a picture of the back of that panel, where all the clips on, so you have an idea of what to look for when pulled it off.
Step 4: Take your Phillips screwdriver and remove the screw under the vent, circled in red. Once that screw is removed, you can pull the whole vent assembly toward the back of the car from underneath/left section that is clearly exposed. It pops off fairly easily. I’ve included a picture of the back of the vent assembly so you can see which clips you are fighting.
Step 5: Take your vent assembly, flip it over and you will see 3 tabs holding the vent itself to the housing. You will get your pick or a very thin flathead and undo each tab/clip one by one. As soon as you do the first one, the vent itself should move up enough to keep that tab unclipped while you do the others.
I’ve circled all 3 tabs you have to undo. The vent itself will come out of the whole housing.
Step 6: Remove the Phillips screw holding the front portion of the vent to the rear portion. Once this screw is removed, the front portion will separate from the rear portion. You will not need this section anymore and can store it away safely.
Step 7: Get your adapter cable and run in into the vent housing from behind at the lowest portion, then plug it into your IPS Gauge.
Step 8: Push the IPS Gauge into the rear section of your vent. The section of the back of the Gauge where the plugs are is the BOTTOM of the Gauge. The housing has a rectangle guide; that is the TOP of the vent. One it is pressure fit into the rear portion of your vent, snap it back into the main housing. This is basically the only step that you may have to repeat if you install the gauge upside-down.
Step 9: Install the Vent assembly back into the car and push the hanging wire downward though an opening between the dash and the vent. You don’t need to make any holes or do anything for the wire. The Vent tube is EXTREMELY flexible and wont damage or cut any wires. If you want to, you can trim a little bit of the vent tube to give the wire space, but it’s soft enough where it barely puts any pressure on the wire itself. Don’t forget to put the Phillips screw back where it belongs!
Step 10: Plug in your OBD2 connector to the Gauge and to your port on the car. Wrap the excess wire and zip tie it out of the way. This is when you should turn the ignition on and make sure the Gauge is facing the correct orientation!
Step 11: Install the two other panels in reverse order of removal. Don’t forget the Phillips screw on the side!
Step 12: Before you turn on your car, hold down both buttons on the gauge for 8 seconds to open the main menu. Everything on this gauge requires holding the button for extended periods of time. Hold the left button for 2seconds to enter that specific menu and change the option. Hold the right button for 2 seconds to move to the next menu. Go through every menu option and ensure it all seems correct and to your liking. When you are done, hold both buttons down for 8 seconds and it will turn off the Gauge.
Step 13: Turn on your car. It should default to Readout #1. Holding the left button for 2 seconds will move to the previous readout/page. Holding the right button for 2 seconds will move to the next readout/page. Holding both buttons down for 8 seconds will allow you change what that specific readout/page shows. You scroll through the menu by holding either left or right button for 2 seconds. When you are at the readout you want to display for that page, you hold both buttons down and it will set it to that page. If the readout/page has a “MAX” value, dictating the highest value it has seen during that specific drive cycle, you can reset that MAX value by holding both buttons for 3 seconds. You will see the MAX value turn red and you can let go to reset it.
This all sounds a bit confusing, but trust me, when you use it, it’s A LOT simpler and easier to understand.
Step 14: Enjoy your gauge! If you have any issues, it is likely an isolated issue that GJP Designs can resolve via a firmware update. Please get into contact with him via his website with any issues.
Remember the Active Sound Error I mentioned? Well mine showed that even after I plugged in the sound module. At the time of me typing this, GJP Designs actually sent me an updated firmware to fix it and make some minor scaling changes that I found issues with!
Here’s a few random screen menus.
Personal favorite is the TPMS readout, as it also shows temp! It’s not like having a pyrometer, but it is a nice touch to keep track of tire temps on track!
Overall thoughts:
I like it.. a lot. I prefer it over the P3 gauges ive had in the past. Programming is specific to the vehicle instead of being generic. The menu is more modern, it matches the rest of the car in terms of design and once it has the ability to run aftermarket sensors for oil pressure and boost, it will be game changing.
Also note: The 3D printed housing is for testing purposes only, the final product will have an OEM-like finish.
one important aspect: If you disconnect the obd2 port, it will reset all your "presets" for the pages. This gauge does not hold enough memory to keep the menu locations. It's really not a big deal to me, as it's not meant to be unplugged unless you need to access the OBD2 port
Ill update this post with an update review once I get some more use out of the gauge.
mycrors7 is offline   Reply With Quote
Old 08-22-2022, 11:04 AM   #2
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
That's one cool little piece of kit. Thanks for sharing and great DIY write up - they did right to go with you.
Is it hard to see while driving; both the text size and the positioning of the face?
Before I shoot GJP Designs an email inquiring to it; is it already possible to connect an OBD interface with the factory head unit display? I'd love to see this P3 gauge information on the big screen (I suspect I'm asking for something that has already been figured out!)
Re_Invention is offline   Reply With Quote
Old 08-22-2022, 11:24 AM   #3
Well done write up!
Old 08-22-2022, 11:48 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
Chipping in on this as well, as I have the V2 version but for the first-gen GT86 and BRZ.
Coming from the V1, the physical buttons make a great difference when operating the gauges, and being able to customize the views without pulling out the PC makes everything easier as well.
I have an OBD2 splitter to connect multiple OBD2 devices which connects the gauge, BT reader for logging and an autolock/unlock module; they work together perfectly, although with some caveats. When monitoring certain values (AFR for example) on the gauge, my BT reader jams up until I move to another. Small matter, as I primarily use the gauge to monitor my coolant and oil temps and the BT reader works fine with the gauge on that screen.
One thing that could be changed/improved are the button delay times, it was understandable for the touch sensors to have a longer hold but with physical buttons it really isn't necessary. Perhaps press once to move between pages, 1sec hold to reset peaks, 2sec hold for menus?
Here's mine on my GT86, with an added 3D-printed sliding cover to block and redirect the vents. Not fond of the airflow blowing at my hands for the entire drive.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 08-22-2022, 09:13 PM   #5
mycrors7
mycrors7's Avatar
Drives: zd8 brz
not hard at all to see at night. there's a dim light-up option as well in the settings for those who feel its too bright at night.
Positioning is great, and since it's a pressure-fit design, you have a some room to play with the fitment and really get it right.
Once i get my car back from a company(i cant say anything yet) that's testing another new product, i'll grab some pictures at night.
as far as seeing this info on the big screen, im sure it's doable, but id imagine youd need some form of custom OS and a wiring harness to go between the radio and the car to attach to obd2.
Once the ecu on this platform gets cracked, we will have access to A LOT more of the car and get a bunch more info as well.
Well done write up!
thank you!
Running multiple accessories via OBD2 can lead to some funky things going on. When i used to work for the city fleet, we would install GPS trackers on fleet units that would essentially "T" into the OBD2 harness. When the tracker was plugged in, we couldnt get any obd2 functions out of the car. we couldnt even check for CEL codes. We had to disconnect the tracker just to pull a code. Very frustrating... but the entire OBD system is very sensitive, so it makes sense
I agree i feel some of the button presses are too long, especially if i just wanna sift through the different screens. Ill bring it up with the owner to see if it's something he consider changing for future firmware updates.
Old 08-23-2022, 02:30 AM   #6
Compelica
Compelica's Avatar
Drives: 86 GT
@geraldjust
Old 08-23-2022, 04:24 AM   #7
geraldjust
Drives: MR2, Sliver BRZ
sorry for the late reply. But yup something real simple to change. for the new v2 il have something available for re-flashing firmware.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 08-23-2022, 09:04 AM   #8
Compelica
Compelica's Avatar
Drives: 86 GT
Not at all - just forwarding some feedback to improve the experience of the product for others.
Old 09-01-2022, 04:33 PM   #9
mycrors7
mycrors7's Avatar
Drives: zd8 brz
not the greatest of pictures, but here's some shots i took on my phone last night.
this is with the gauge set at full brightness. it matches the cluster brightness
Old 09-01-2022, 04:46 PM   #10
sharkynrk
Drives: 2013 WRB BRZ
This is really cool. Link for the Gen 1 setup by chance?
sharkynrk is offline   Reply With Quote
Old 09-01-2022, 04:56 PM   #11
jongers
Drives: 19 86, 22 BRZ
https://www.geraldjustprojects.com/p...-brz-frs-gt86/
+1 - I was also lucky enough to test/provide feedback and have to say that I'm thoroughly impressed with the product.
jongers is offline   Reply With Quote
Old 12-14-2022, 01:44 PM   #12
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
thank you!
Do you happen to know if running this with a Y-split cable will cause any issues? I have other accessories plugged into my OBD2 port.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 12-16-2022, 11:44 PM   #13
mycrors7
mycrors7's Avatar
Drives: zd8 brz
I'm unsure if running this with a Y-split will cause issues.
Im sure @geraldjust should be able to answer that
Old 12-20-2022, 01:53 AM   #14
geraldjust
for the gen1 alot of features that will allow it to work with the cars internal network. check the list of "data" thats available and what is obd2 and what is not.
for gen2 all has to be obd2 so only one device at a time for now.
Difference between 2022 BRZ and GR86 digital gauge clusters timurrrr BRZ Second-Gen (2022+) — General Topics 31 12-31-2022 01:46 AM
savagegeese GR86 5K mile review Samba86 GR86 General Topics (2nd Gen 2022+ Toyota 86) 35 06-30-2022 06:54 AM
GR86 Parts Websites / Review your experiences bpoisso GR86 General Topics (2nd Gen 2022+ Toyota 86) 4 02-24-2022 03:43 AM
Car & Driver Comparison Test Review: Veloster N vs. GTI vs. BRZ vs. GR86 LimitedSlip GR86 General Topics (2nd Gen 2022+ Toyota 86) 158 12-12-2021 04:04 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
