08-22-2022, 08:54 AM | #3571 | ||
Drives: 2018 Subaru BRZ
Of course, once things normalize I'm expecting it to be more on the 40-60 range instead of what it is right now. It can go down as fast as it went up. This town is steadily becoming more popular but anything can happen. Adding central air is our biggest priority, with closets being built second. Everything else is mostly cosmetic and more of a want than a need. Quote:
Yep, not looking forward moving my 300lb mobile tool bench down in the basement nor re-wiring my PC desk. Or painting. |
The Following User Says Thank You to spcmafia For This Useful Post: | Dadhawk (08-22-2022) |
08-22-2022, 09:02 AM | #3572 |
The Dictater
Drives: '13 Red Scion FRS
None of those sounds like a reason that you would need to move. Paving a driveway and AC definitely add additional value to the house so you aren't likely to lose money there in the long run. If you have the space to add closets inside the house then that is doable.
Remember, if your house increased in value by 120k, any house you could buy would also have an increased price that may or may not hold up for long. Good reasons to move (imo): You need more/less space, you want/need a different location, you want/need a different floorplan or feature that is prohibitively expensive or impossible in the current house, some sort of disaster. |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
08-22-2022, 09:41 AM | #3573 | |
That is true. We'll see what estimates I can get, will probably report back. |
08-22-2022, 09:53 AM | #3574 | |
When we bought our house it was dirt cheap because it needed a bunch of work (roof, furnace, landscaping, some windows, siding, interior updating) we accounted for all the costs when we did the mortgage but spread the work over 5 years. Even before the market went crazy we had more than doubled the value of the house. What we could of got for it a couple of months ago at the market peak was almost embarrassing. Mind you anything "better" would have cost that much more.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
08-22-2022, 09:59 AM | #3575 | |
Drives: 2017 BRZ
Ikea wardrobes may be an option in lieu of closets if you want to explore what you can do at a given price. Advantage being non-permanent in case room size loss might be an issue in the future. We've used them both places we've owned and they work well. Tip: Add a 1x board horizontally across the width and anchored to studs behind the wall anchor spots. Be incredibly wary borrowing against increased value. It's far to easy to end up under water, or even just back in PMI range.
The Following 5 Users Say Thank You to cjd For This Useful Post: | Dadhawk (08-22-2022), soundman98 (08-22-2022), spcmafia (08-22-2022), Spuds (08-22-2022), Tcoat (08-22-2022) |
08-22-2022, 10:08 AM | #3576 | |
Sometimes trees just have to be trimmed or even come down completely. If I had any nut bearing trees over my driveway they would be gone in a heartbeat.
08-22-2022, 10:10 AM | #3577 | |
Drives: Crapcan
What do you have for heat? Doing a mini split is pretty cost effective and DIY kits like MrCool are easy to install. It really depends on your home layout though.
08-22-2022, 10:10 AM | #3578 | |
We want to basically buy a bunch of wood and build shelves using the existing closets. They were basically two pieces of wood with a bench-like frame with a plastic tube to hang clothes. Has done the job, but is very shitty. I can probably just get a portale garage big enough for two cars. It just wouldn't be aesthetically pleasing. Our zoning regulations prevents us from building any permanent structure within 30ft-50ft away from the property line, and the house sits dead in the middle of the lot. Being exactly within property lines. @Tcoat 's idea resonates with us, might just do one project at a time before moving to the next one. Gotta make some phone calls and start getting estimates. |
08-22-2022, 10:13 AM | #3579 | |
We have what it seems to be a 10+ year old furnace with Forced Air, Oil heat. Adding a condenser, cooling coil, etc, using the existing ducting/ furnace might make a little more sense. The house is small, 1000sqft or so. |
08-22-2022, 10:15 AM | #3580 | |
https://www.lowes.com/pd/ClosetMaid-...et-Kit/3032156
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
08-22-2022, 10:16 AM | #3581 |
Drives: Crapcan
I would inspect your ducting. If you are not getting much dust in it, it is likely okay. That can exponentially add to the cost since it is a ton of work to repair/replace.
08-22-2022, 10:21 AM | #3582 | |
The Dictater
I parked my beater car under the oak tree at my last house to look extra beat. |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (08-22-2022), spcmafia (08-22-2022) |
08-22-2022, 10:28 AM | #3583 | |
Drives: Crapcan
08-22-2022, 10:38 AM | #3584 | |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
