Old 08-21-2022, 03:23 AM   #1
DerJuso
Drives: Gt86 2013
Question P0171 and ruff idle
Hey Guys i am still struggling with my engine. I rebuilded my car after an engine fire. The car starts runs ruff and way too lean. I have tried so many things and checkt everything i could think of! I hope you have some ideas what i can check next because i am at my limits!
I checked:
Fuel:
- Pressure in both lines to the engine (around 4 bars)
- Highpressure for DI is like it should be (looking at the values in my app)
- All injectors are opening. I checked the port injectors they also are spraying i a nice pattern.
Air:
- The intake side is completle sealed. I checkt it with positiv pressure.
- The Exhaust system is mostly seald no leaks till the first muffler.
- My MAF is sending some infos to the ECU
- Also dose the MAP
- the Evap and PCV are working fine
Electric:
Bought a AFR gauge to have a vision on the AFR
New parts:
-Engine ECU
-Body ECU
-DI ECU
-Gateway ECU (think it is the Body ECU)
-Wireharness (Engine & enginebay(the one with the big fusebox))
-O2 sensor
I will put 2 videos on this Post. In one you can see the AFR and on the other you can see the ruff engine idle. I really need Your help and would be happy to hear any ideas unnessecary how crazy they are.
PS: I had checked the timing because i feld bad about that. there i recocnized that the VVT from the Driverside exhaust camshaft was locked not in the right position. could that be a problem? i took it off twisted it to the right place and put it back on.
Links:
AFR:
Ruff idle: https://youtube.com/shorts/jz2NYksQD4s?feature=share
PSS: sorry for my english if anything isnt clear feel free to ask!
DerJuso is offline   Reply With Quote
P0171 and P1170 codes when at low RPMs or idle stockysnail Issues | Warranty | Recalls / TSB 35 12-22-2022 09:27 PM
Odd idle and P0171 and P1170 codes dave- Engine, Exhaust, Transmission 0 09-27-2018 12:05 AM
Ruff R351 18x8 +40 & Kumho Ecsta AST 235/40-18 2000 Miles ShaneLindley Wheels and Tires 7 07-11-2016 12:08 PM
FS: Ruff Racing R356 18x8 w/ Yokohama 225/40 18 Dan@AWD Wheels and Tires 12 11-18-2013 12:10 AM
>>> 18" RUFF Racing 351 | 356 | 357 wheels - starting @ 710.00 shipped speed depot Wheels and Tires 9 11-23-2012 07:54 PM
