#23773 |
Drives: 2013 Whiteout FR-S
WHAT DID YOU DO TO YOUR FRS TODAY?
took her to the mall, torn between the oem spoiler and spoiler-less look
#23774 |
Drives: Halo
37,500mi
Installed a cruise control relocation bracket. This whole install was more than I signed up for. Lost some sleep too.
Issues ABS/Traction - Fixed - Cleared code using OBD2 cable/Techstream then ran a steering angle sensor reset. SRS - Fixed. B1801/B1811. It was a loose airbag bypass wire. I figured out that you can push the terminal clip so it bites down on the resistor. Cleared the code and so far so good. It helps if u tin the prongs lightly with some solder. ![]() Installed the Faction Fab Shifter bushing. ![]() Installed Perrin/Whiteline Trans/Diff mounts. I noticed the cabin got louder. Did a short pull on the way home and the car sounds like it has a supercharger. ![]() -Cheers
| The Following 5 Users Say Thank You to orz For This Useful Post: | bcj (08-05-2022), MJones_RB (08-09-2022), RToyo86 (08-14-2022), villainous_frx (08-17-2022), Wally86 (08-05-2022) |
#23775 |
I replaced my rear diff fluid!
Sheared an adapter, tore my knuckles, and punched myself in the face but I did it all by myself ![]() All that's left is brake fluid and race pads and ya boy's track-ready
| The Following 5 Users Say Thank You to redwood9d For This Useful Post: | bcj (08-08-2022), DarkPira7e (08-16-2022), new2subaru (08-08-2022), soundman98 (08-07-2022), Wally86 (08-08-2022) |
#23776 |
Drives: FR-S,GTI
I removed this intake blockage and replaced it with the OEM intake.
I would suggest that anyone who has a similar blockage remove it and put it up for sale. Before it's too late. |
#23777 |
Drives: 17 Asphalt 86
Uninstalled torque solutions short shifter and in went the OEM shifter. It feels great with the front and rear carrier bushings done.
#23778 |
Drives: frs
#23779 |
installed my 2 piece splitter from Verus with race upgrade, oil change, installed new OEM Fenders liners, and swapped out my cracked beat to hell Bumper to my new OEM pained by Maco.
2013 Series 10 FRS #553
#23780 |
Drives: 2013 FR-S Series 10
How much they charge for the repaint?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#23781 |
Drives: Subaru BRZ
#23782 |
Rust bucket enthusiast
To combat IATs until a get a new intercooler setup, I wrapped the downpipe and added gold tape hastily to the cold side intake pipe. Didn't really make much difference in intake temps but it helped the engine bay cool off a bit!
Definitely not a fan of the gold piping, I'll probably remove it eventually.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 08-16-2022 at 04:37 PM. |
#23783 | |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
| The Following 3 Users Say Thank You to villainous_frx For This Useful Post: |
#23784 |
And the only reason it was as rusty as that was the light haze of paint they put on thin tin. Pretty sure they just ran it nearby the paint stage and what fumes hit it they called good enough.
Much thicker paint on the 86 and not a rust speck to be seen. I get to save $20 in 4 more years.
#23785 |
Weight Weenie
Drives: 15 FR-S
Threw a check engine light and a few codes. Bought a can of MAF sensor cleaner at CT for 12 bucks.
Got lucky! Worked like a charm. |
| The Following User Says Thank You to new2subaru For This Useful Post: | soundman98 (08-17-2022) |
#23786 |
Off to the track!
Finished break in finally. It unlocked the rare 9000 RPM redline!
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
