Old 07-20-2022, 02:25 PM   #323
RedReplicant
Drives: None
Originally Posted by FrickingReallySlow View Post
How well could the stock motor last at 350whp? I thought @CSGmike said that its life was measured in hours?! Maybe the cost of adding pistons and rods and labor was close to the cost of a replacement K24A2 and its not worth it
He was talking about a 300whp NA K24, not a FI stock motor. With that said, 4Piston will sell you a ~300whp K25 with a warranty or if you lower your target to something like 275whp you can have something that'll probably be more of a few season motor.
With FI, as long as you're not trying to make a bunch of torque down low it should live a pretty decent life at 350whp.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
FrickingReallySlow (07-20-2022), Irace86.2.0 (07-21-2022)
Old 07-21-2022, 11:30 AM   #324
Ebush
Drives: 2017 Hot Lava 86
A 350whp turbo k24 with proper tuning would probably last forever in a street car. Mike was referring to max effort NA K24'S, Which would have 400-500whp+ NA.
Ebush is offline   Reply With Quote
The Following 3 Users Say Thank You to Ebush For This Useful Post:
FrickingReallySlow (07-21-2022), Irace86.2.0 (07-21-2022), RedReplicant (07-21-2022)
Old 07-21-2022, 05:33 PM   #325
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Yes, Mike was saying NA under the stipulation that the K24 would be revving to 9k and pushed to the limit on the track. 9k would be a lot. The K20 at 9k is about the same as the K24 at 8,1-8,3k, which seems to be a decently reliable limit, especially for the street.
And the cost of a built FA20 after buying a replacement motor would have been too expensive like $8-10k with a bigger risk than I wanted if the motor blew again.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
FrickingReallySlow (08-14-2022), RedReplicant (07-22-2022), Teseo (07-22-2022)
Old 08-14-2022, 02:42 PM   #326
FrickingReallySlow
Drives: 2015 FR-S
Would there be a need to use the typeS oil pump since the K24 original one seems to be good to 8K and the WHP is dropping off after 7.5K looking at your dyne plots? maybe just porting the original pump with the balance shafts would be a better option for FI setups? you lose some pressure since you have to feed the balance shafts but some porting work or larger pump gear (6 tooth on type S vs 7 tooth in k24) may get you what you need?
FrickingReallySlow is offline   Reply With Quote
Old 08-14-2022, 03:41 PM   #327
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I was thinking on this a bit today as well even for NA application. The question would really be whether the pump assembly fits with the Kpower oil pan and if so does the baffling work as intended?
captain awesome is offline   Reply With Quote
The Following User Says Thank You to captain awesome For This Useful Post:
FrickingReallySlow (08-15-2022)
Old 08-14-2022, 11:32 PM   #328
Irace86.2.0
I had a mild boost leak and fuel limit at redline from not running a return fuel system, maxing out my injectors. Look up other dynos because they can pull well to 9k with gains. The pan would need to be modified, but for sure the baffling would. I don’t know if the stock oil pump has clearance issues with the subframe. It is a nice thought though because 8k is good for now until I build the motor. Ultimately, the shakes aren’t bad enough for me to care.
https://www.s2ki.com/forums/s2000-fo...1180669/page3/
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 08-15-2022, 01:10 PM   #329
FrickingReallySlow
Drives: 2015 FR-S
Thanks didn't know that the baffle and custom pan and height could be an issue here. Btw what does the return system buy you? just more even fuel pressure at all RPM instead of being regulated? or just ease of tuning
Old 08-15-2022, 05:41 PM   #330
Irace86.2.0
More constant pressure and temperature, which makes tuning easier and results in more fuel. A returnless system has unused fuel sitting in the fuel rails heating up, as it waits to get burned, which results in a drop in fuel pressure, I believe, and higher fuel temps. The drop in pressure might be from fuel evaporation leading to micro gas pockets. What I do know if that a boost reference FPR is also needed. This increases the fuel pressure proportional to boost, so 60psi with vacuum will raise to 70psi at 10psi of boost. Why is this necessary? Pressure in the rail is 60psi, but pressure in the manifold is 10psi resisting the fuel from squirting out of the injector, so actual fuel pressure at the injector is 50psi, which means the injector is slowly losing potential with the rise in boost, which is exactly the opposite of what you would want. I was seeing fuel pressures in the mid forties after breaking 10psi, which means my injectors at max duty cycle were inadequate despite other with return systems with a reference FPR making far more power.
RedReplicant (08-15-2022)
Old 08-15-2022, 06:47 PM   #331
RedReplicant
Drives: None
Worth seeing if you can get a writeup out of ML since he repurposed the unused stock line as a return.
Old 08-15-2022, 08:09 PM   #332
ML
ML's Avatar
Drives: 13 White MT FR-S
my setup is a hybid I guess with a surge tank in the engine bay. So the fuel goes to the surge tank and then there is a return from the surge to the fuel cell (re using one of the stock fuel lines). then from the surge tank it goes to a boost referenced FPR to the fuel rail which i guess from there is considered "returnless"
The Following 3 Users Say Thank You to ML For This Useful Post:
Irace86.2.0 (08-15-2022), Jdmjunkie (08-15-2022), RedReplicant (08-15-2022)
Old 08-15-2022, 10:19 PM   #333
Irace86.2.0
I will probably run -6AN lines to something like this. I'll have to research it more when I am ready to make the changes to a new tranny.
https://fullblownmotorsports.com/ful...frs-subaru-brz
Old 08-16-2022, 07:18 AM   #334
ML
ML's Avatar
-6 is what I'm running. that kit seems way overpriced though
Old 08-16-2022, 09:30 AM   #335
captain awesome
Wears Pants
Just saw that Deatschwerks came out with a dual pump assembly. It's supposedly capable of keeping fuel flow below 1/8th tank plus I think it may flow enough for your application.
https://www.dropbox.com/s/bblxuif0w6...eid=236b735dae
Edit: It's expensive. Like really expensive. Also requires return line.
ML (08-16-2022)
Old 08-16-2022, 10:08 AM   #336
ML
ML's Avatar
thats pretty sweet! you can get it without pumps for $430
worst.build.ever.
KPower Industries K24 swap PulsarBeeerz Engine Swaps 1801 04-15-2025 11:54 AM
Irace86.2.0 Build Irace86.2.0 Member's Car Journals 195 03-25-2024 12:29 AM
Turbo or swap Fastend Forced Induction 35 06-11-2020 07:12 PM
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
IRACE86's Build Irace86 Member's Car Journals 25 01-10-2017 04:35 PM
