Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-04-2022, 09:47 AM   #15
mr.whiskers
Drives: '22 BRZ
Originally Posted by Stonehorsw View Post
This is not diagnosing, it is guessing. And will be done, as when I drive, fuel goes down
Record a 0-60 acceleration time then do it with a new tank of gas
mr.whiskers is offline   Reply With Quote
Old 08-04-2022, 09:51 AM   #16
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Another aspect to look at is the high temperatures and humidity around your area. But best thing to do at this point is to run all the gas and refill from a gas station that would offer a sort of cleaning additive in the 93 mix, like Mobil or Shell.
Thanks! Will do that!
Stonehorsw is offline   Reply With Quote
Old 08-04-2022, 01:16 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hi,
Car is with 4900 miles, oil changed at ~1300 miles.
Background: This week the car started feeling gutless, specially on low rpm. Less power than my 18 Brz, not able to break traction even in turns.
Did not hear any knocking event or any type of other engine noise that would call my attention.
What I am suspecting: bad fuel quality (filled with 93 from Kroeger this time)
Question: How do I diagnose if this is related to the fuel? Any other had similar reduction of power/torque?
I have had this happen on my 13' multiple times since you can't pump your own gas in OR, they put 87 in. You can see it if you have a way to look at your IAM in real time, I use my OFT to check, usually drops IAM down to .4ish, so only giving you 40%(all other factors removed) of your base timing. Seriously feels like you are down 20+whp, throttle response sluggish.
Old 08-04-2022, 01:44 PM   #18
Xed32
Drives: '22 brz Sport-Tech
I keep a shot or two of "Boostane Shot" in by glove box for these situations. Not all our 94 is actually 94 here.
Xed32 is offline   Reply With Quote
Old 08-04-2022, 03:46 PM   #19
Stonehorsw
Stonehorsw's Avatar
That is a good point. Won’t do a baseline with the bad fuel to avoid engine damage.
Is there anyway to do atmospheric corrections to correlate later?
Old 08-04-2022, 03:47 PM   #20
Stonehorsw
Stonehorsw's Avatar
I did not check yet, but I still have my OFT. Do you think that would read on Gen2?
Also, I have a bluedriver, that may work too.
I will plug and check, thanks!!!
Old 08-04-2022, 03:52 PM   #21
You aren't going to hurt anything. That's the whole point of the ECU logic. If it's bad gas, engine is gutless because it's pulling timing to avoid damage. If it was something else, damage would already have happened.
What are you feeling, ft86? Atticus808 Off-Topic Lounge [WARNING: NO POLITICS] 70 03-24-2016 05:14 PM
Feeling Guilty >,< dvasqu01 Off-Topic Lounge [WARNING: NO POLITICS] 46 02-05-2016 01:32 PM
Feeling like crap right now. How bad is it??? 10Stars BRZ First-Gen (2012+) — General Topics 35 11-05-2015 09:02 AM
Feeling like I just got robbed ..what to do? IgnitionGundam Scion FR-S / Toyota 86 GT86 General Forum 135 03-26-2014 08:23 PM
That wonderful feeling.. Missy Off-Topic Lounge [WARNING: NO POLITICS] 25 01-18-2014 10:16 AM
