timurrrr
Old 08-03-2022, 04:21 PM   #407
DylanJZA
DylanJZA's Avatar
Drives: GR86 Premium AT Trueno Blue
rumor has it a certain recent engine failed due to overrev (3rd to 2nd shift) and not because of the pickup being covered in rtv.
doesn't diminish the fact that the rtv in the oilpan is an issue however.
DylanJZA is offline   Reply With Quote
The Following 2 Users Say Thank You to DylanJZA For This Useful Post:
Opie (08-04-2022), Tcoat (08-03-2022)
Old 08-03-2022, 04:29 PM   #408
pq86
Drives: 2023 GR86
it is possible that subaru designed the pick up to tolerate partial blockage so that they could save costs on engine assembly i guess? at least, they could claim that maybe.
has anyone looked at the oil pickups of FA24 ascents?
pq86 is offline   Reply With Quote
Old 08-03-2022, 04:35 PM   #409
OkieSnuffBox
Drives: '23 BRZ Limited
Ye olde money shift.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
DylanJZA (08-03-2022)
Old 08-03-2022, 05:12 PM   #410
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by OkieSnuffBox View Post
I'm fully capable, but not willing. Like you said later, we shouldn't even have to worry about something like that.
I wouldn't worry about it. There are too many unknowns to fret over it. See GRM article....
Does that mean ECM in the new cars is recording and storing all engine parameter and g-load data? Permanently?
I thought most new cars only recorded the last 5-30 seconds leading up to something like a collision?
These are different systems...the EDR, event data recorder records certain info prior to an airbag deployment. Seatbelt use, brake or accelerator pedal application, speed, etc.
There is a seperate system that logs data when a CEL occurs as well. Not sure how long it is stored, I do know dealer service employees cannot access it, but corporate employees such as FSM's can. It stores temps, pressures, MPH, g-loads, and more...The Starlink system stores GPS location...not sure if either of the other systems do as well.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-03-2022, 05:17 PM   #411
OkieSnuffBox
I've already seen it and the Facebook post. I've been a subscriber of theirs for nearly 20 years.
Ahh ok, gotcha.
I'm not too worried about it. When it gets here I'm going to slap my suspension/wheels/tires on it and enjoy.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
Old 08-03-2022, 05:31 PM   #412
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by pq86 View Post
It’s deeply ironic that the redesigned subaru oil pickup, with its nice cheese grater design, probably allowed this issue to slip by standard QA/QC process. With a EJ style pickup this would have blown up engines in QA and been corrected
And that's a great lesson that both unit and end-to-end testing are important. It's a shame they still haven't put a proper oil pressure sensor into these engines, along with a CEL warning if the pressure goes out of spec.
I'm sure if they had that early on on all engines during testing that'd not only catch the RTV clogging sooner, but also they would possibly design a few other things better as well.
"If you care about something, put a sensor on it!"
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
DocWalt (08-03-2022)
Old 08-03-2022, 05:48 PM   #413
OkieSnuffBox
They suspect the car ran low on oil due to excessive consumption caused by it's heavy initial use during the break in period as evidenced by the over-rev data, mph data and g-load data in the car. Engine damage showed obvious lack of lubrication, there was no loose sealant noted during engine teardown.
So I was thinking about this, if it only records parameters during a CEL, how do they know there was a heavy use during the break-in? Since the other things you mentioned were ostensibly only recorded after a CEL became present. Or are they saying there were multiple CEL's that cleared themselves and then reset during a restart event?
Didn't the guy share pictures of RTV in the pick up tube or was that someone else?
Old 08-03-2022, 06:16 PM   #414
mycrors7
mycrors7's Avatar
Drives: zd8 brz
it might be set up to record the first 1000 miles regardless of the vehicle status, much like how c8 corvettes had a hard rev limiter and power cut for 500 miles and the car would automatically let you rev the piss out of it as soon as you touched 500 miles
mycrors7 is offline   Reply With Quote
Old 08-03-2022, 06:27 PM   #415
toeout
On my car(GR86) the oil level was at max mark on the dipstick at the time of failure. I checked the oil level before the event and then after the failure.
I did buy 1 qt of Toyota's 0W-20 about a month before the failure, to bring the oil level back to max. By the 5500 miles, when the engine failed, I had added about 0.75 qt of oil to the factory fill, to keep the oil level at max.
Also, if it matters, the oil temp at the time of failure was about 235deg F. 3rd run on a National Tour.
toeout is offline   Reply With Quote
The Following 2 Users Say Thank You to toeout For This Useful Post:
strat61caster (08-04-2022), Tcoat (08-03-2022)
Old 08-03-2022, 06:39 PM   #416
Everybody is so focused on the high profile case and ignoring the others. There are probably more factors involved then either "just abuse" or "there is crap in the pickup".
The 235 is pretty much exactly where it should be so heat may not be a consideration (thought based solely on that single data point)
toeout (08-03-2022)
Old 08-03-2022, 06:59 PM   #417
RippedManiac
Jedi
Drives: Pikachu BRZ
Originally Posted by Petah78 View Post
There is absolutely nothing else. The closest thing is the BMW M2 which i seriously considered but with the used car prices AND not wanting to pay BMW running costs, that was ruled out quickly.
I test drove a 2018 MT last week after months of pining over it. I was kinda disappointed TBH. The shifter was rubbery and the throw was long. M2 clutch pedal was deep and not as crispy as brz. When I put my foot down it was linear and faster than the BRZ, but it wasnt as fast as I was expecting. You could feel the weight of the car. I guess I was expecting the greatest BMW ever and its perfect with 0 flaws.
Still waiting on Z, Manual Supra, GR Corolla, Kouki GR86
TL DR IMO 2018 M2 wasnt enough car to justify all the money. What makes a sportscar is the light weight.
RippedManiac is offline   Reply With Quote
The Following User Says Thank You to RippedManiac For This Useful Post:
Petah78 (08-03-2022)
Old 08-03-2022, 07:33 PM   #418
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
Over-rev will also cause freeze frame data to be stored without a DTC being generated. Assuming we’re talking about the BRZ posted on the GR86 forum, he over-revved before the 1000 mile break in period.
He did not share any pictures of RTV in his pickup.
removedonut is offline   Reply With Quote
Old 08-03-2022, 07:38 PM   #419
removedonut
Originally Posted by Robertw View Post
From the Grassroots Motorsports article
How does Toyota (one of the largest automakers) not have it's own in house staff dealing with this? lol
This is a special scenario due to Toyota’s very strange relationship in this specific region. In Arkansas, Louisiana, Texas, Mississippi, and Oklahoma, Gulf States Toyota (an independent company) has exclusive rights for authorized sale and distribution of Toyota vehicles in those states. They effectively take Toyota USA’s place in most, if not all decision making, and they are the entity that presides over every dealership in the region. This is due to a stupid ass agreement that toyota signed like 50 years ago.
It’s entirely possible this issue never even went as high as Toyota themselves because of this.
The Following 2 Users Say Thank You to removedonut For This Useful Post:
DylanJZA (08-03-2022), Rustyoid (08-04-2022)
Old 08-03-2022, 08:16 PM   #420
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That makes a lot more sense. I was wondering who this FST was representing.
NoHaveMSG is online now   Reply With Quote
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
