Old 08-02-2022, 01:15 PM   #295
mycrors7
mycrors7's Avatar
Drives: zd8 brz
From an owner in japan with a brz
9/21 build date
11k miles. 6-7 track days. 8 oil changes
Motor failed on track and was taken apart by a local shop(not a dealer)
mycrors7 is offline   Reply With Quote
Old 08-02-2022, 01:15 PM   #296
Chev
Drives: 06 Ridgeline, 03 VFR, 03 FLHTPi,
Toyota Brand Engagement Center (1-800-331-4331)
I suggest everyone call. Let these guys know we have a voice and will use it.
Chev is offline   Reply With Quote
Old 08-02-2022, 01:25 PM   #297
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
Kind of glad I waited to nab one… hopefully Toyota and Subaru take this seriously and address it!
Ghost of Akina is offline   Reply With Quote
Old 08-02-2022, 01:34 PM   #298
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by BioRebel View Post
While it wouldn't PREVENT the issue from happening, it would force the re-application of sealant and the removal of "excess" sealant. I feel like its more of a "while you're in there you may as well just add this additional preventative measure".
I mean this whole thing could likely be solved if the dealers just removed the pan and replaced the sealant when they get the car.
Anyone know if installing a baffle plate would void the warranty? MM seems to say the dealer would need to prove that the plate contributed to the failure in order to void the claim.
It may not be just the pan that is the issue. Could be the timing cover too. After the J02 debacle would you want dealer techs dropping engines to reseal them?
Old 08-02-2022, 01:43 PM   #299
Espi
Espi's Avatar
Drives: 17 BRZ
Looks like it's making its way in the news
https://www.roadandtrack.com/news/a4...repair-denied/
Espi is offline   Reply With Quote
Old 08-02-2022, 01:53 PM   #300
What still confuses me is that the oil pan and method of sealing it are identical to the Ascent FA24F and all the newer 2.5 engines. This means hundreds of thousands of cars a year for at least the last 5 years should be exposed to the same risk. There is not one word about any other models with the same issue. If it is just the oil pan sealant then what is different about the FA24D that creates the problem?
I feel there is still a piece of the puzzle that hasn't been found yet.
Old 08-02-2022, 01:58 PM   #301
2
Old 08-02-2022, 02:11 PM   #302
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Maybe Subaru and Toyota want to ensure to offer a true 86/BRZ experience by introducing new owners to the 1st gen woes. You know, to get them up to speed on what it really means to own a twin.
Another thing is that, depending if something like the sealant is not made in-house, it is very possible that a bad lot was sent to Subaru. Which can happen, we see it happen at my workplace quite often. So the problem could be solved by now, and both manufacturers will have to issue a recall based on the VINs that were manufactured using the bad lot.
spcmafia is offline   Reply With Quote
Old 08-02-2022, 02:22 PM   #303
Espi
Espi's Avatar
Drives: 17 BRZ
2
i missed it my bad - thanks lol
Old 08-02-2022, 02:34 PM   #304
Varelco
Drives: '15 GT86 & '22 GR86
It seems that most failures are caused through the higher demands of track use/high RPM running. It may be that because no one tracks an Ascent, it's not a problem as it can get sufficient oil through the other side's of the strainer for normal every day driving.
Varelco is offline   Reply With Quote
Old 08-02-2022, 02:50 PM   #305
You won't be the last!
Old 08-02-2022, 02:51 PM   #306
ninjan00dles
Drives: 2015 FRS
All the other FA24 derivatives have a redline around 6000rpm. The GRZ86 has a 7400rpm so it's operating at higher frequencies. Higher frequency means more oscillation, potential to approach resonance etc. Combine those higher revs with certain "kinematic" events (ie HPDE, drifting) and you are increasing the likelihood of that excessively applied RTV to peel away and clog the pickup. So that's probably why you don't see these issues on Subaru's SUV/CUVs.
Also - not really covered here but is covered extensively on the Japanese forums. There isn't just excessive RTV at the oil pan. It's also excessively applied at the timing cover. So just resealing your oil pan or using a felpro gasket (which kinda blow anyways) wouldn't fix it.
Bottom-line Subaru is still figuring out how to produce a performance motor... I mean they never fixed the EJ series. And the FA20 really didn't get fully fixed until the 17MY refresh. I thought we were past this, but I guess not.
ninjan00dles is offline   Reply With Quote
Old 08-02-2022, 02:52 PM   #307
Originally Posted by Varelco View Post
It seems that most failures are caused through the higher demands of track use/high RPM running. It may be that because no one tracks an Ascent, it's not a problem as it's can get sufficient oil through the other side's of the strainer for normal every day driving.
Possible. But they are also towing and being pushed hard in other ways.
Just tracking should not be a reason. Will have to see if there are many that were not tracked.
Old 08-02-2022, 02:53 PM   #308
Actually if the issue is appearing with the timing chain cover that can also be the difference. The oil pan is the same across them all but the timing cover is not.
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 01:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 04:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 11:11 AM
