Old 08-01-2022, 10:04 PM   #1
Frankz54
Drives: 2019 Toyota GT86
Install of TRD Quad Tip Exhaust Finish
Hey Fam,
Has anyone installed or has seen an install video the TRD Quad Tip Exhaust finisher? I have the remark quad exhaust and feel this would complete the look in the back of the car.
Product: https://www.ftspeed.com/part/ms343-1...sher-2013-ft86
Frankz54 is offline   Reply With Quote
Old 08-01-2022, 10:46 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have them on my BRZ and they really aren't that hard. It should come with the instructions and the overlay to measure where they go. At least mine did.
MS, CSCS, TSAC-F, CPT
Old 08-02-2022, 09:54 AM   #3
Frankz54
Do you have to cut or drill anything?
Old 08-02-2022, 10:14 AM   #4
weederr33
weederr33's Avatar
Yep. It’s the only way to make room if you’re gonna do any of the quad tips with the exception of one.
Old 08-02-2022, 10:17 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If you're anxious about doing something imperfectly, all your cuts will be hidden. Don't worry, you only learn by doing. Once you get started it's not so bad.
Old 08-02-2022, 10:32 AM   #6
Frankz54
Thank you guys, i appreciate the feedback. One more question, do you take down the exhaust? Or you have enough room to work with?
Old 08-02-2022, 03:29 PM   #7
Thefalls
Thefalls's Avatar
Drives: Corolla GT
The only thread i found that may help
https://www.ft86club.com/forums/showthread.php?t=15976
Thefalls is offline   Reply With Quote
Old 08-03-2022, 05:29 AM   #8
Sam86
Drives: Toyota 86 GTS
Hey Fam,
That exhaust is made to fit the stock diffuser isn’t it, if you use that with the TRD garnish it’s going to look silly. Pretty sure the TRD garnish can fit a twin 4” exhaust whereas the remark quad tip is probably about 4.5” in total width so you’ll have like 2” of empty space on either side.
If you haven’t bought it yet, don’t and see if you like it how it is, if you want the TRD garnish or already bought it, will look a lot better if you buy new tips and have them welded onto your remark exhaust
Sam86 is offline   Reply With Quote
Old 08-03-2022, 06:50 PM   #9
weederr33
weederr33's Avatar
It's going to look silly with the stock holes too.
Old 08-03-2022, 08:33 PM   #10
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
I have it on mine as well and it was pretty straight forward.
I recommend applying painters tape around the cutting areas and take your time.
I took my exhaust off to have more room to work with.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 08-06-2022, 03:31 AM   #11
Sam86
Found a video of a guy who had previously installed a custom quad tip to fit the stock single exit exhaust (like the remark tip). This is how it looks with the garnish on it.
It also answered a question I had myself, of where the single exit tip would come out if you put the garnish on. This means if you’ve got a removable tip, you should be able to buy one of those tips that have an inlet that goes through the centre of one of the tips with the second tip connected to it, rather than a traditional Y shaped dual exhaust tip where the inlet is in the centre of the 2 outlets.
So if you had a dual exit, you’d want a tip like this to fit the garnish from what I can see
Old 08-10-2022, 07:28 PM   #12
Frankz54
Yeah that looks horrible lol.
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 12:19 PM
TRD quad diffuser and custon quad tip exhaust Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 16 01-23-2015 05:37 AM
J2 quad tip exhaust TheGuyWithTheFireStorm Engine, Exhaust, Transmission 0 11-25-2013 06:34 PM
WTB: J2 Quad Tip Exhaust FRS/BRZ NoVtec Want-To-Buy Requests 1 11-06-2013 11:46 PM
